Don't laugh too hard, but can wood be bleached?  I have some holly and some maple that has dark streaks in the grain.    Just musing out loud.
I know Tri sodium phosphate (TSP) will take the black water stains out of oak somewhat, but I don't what it would do with other woods. There is also oxalic acid which is supposed to bleach wood, but I've never used it. Maybe the maple is spalted which is a kind of fungal decay. I don't know if that can be removed.
Kurt
Mark: You can bleach wood (I've done it in the past).  The problem is that the end result is somewhat unpredictable.  With dark woods especially, but I suspect even holly and maple won't "bleach true" and will come out splotchy.  Do a test on the maple and see what you get.
Kurt: Good point about the spalting.
You could also try drops of lemon juice diluted in a little water..
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Thanks one and all.  I'll give the bleach a shot as have nothing to loose if it doesn't work.
Don't forget to neutralize it when your done bleaching. I believe baking soda is the preferred neutralizer.
Rebecca Whitman's book "Brightwork" recommends a thick paste of oxalic acid crystals in hot water.
But I've given up on bleaching wood. My new toerails are iroko. I'll post pics when I get them installed.
Harvey
Thanks for the reminder, Harvey.  I'm looking at the wood pile and might have enough holly that is clear for what I want.  I'll do some testing on the 'morrow to see if the rest of the pile is salvageable.  I'll also test the maple as that's my fall-back if I don't have enough holly.
As a general rule, to get Holly that has not been infected with Blue Mold, it must be harvested in Winter and immediately billeted and  moved to a kiln.
Depending on the tree, the wood would then be near white or yellow.  The mold infected wood is light blue or grey.  If the color is not a problem,
the wood is otherwise sound and fine to use.  This is not the situation with Apple.  While far less invasive, Apple that has been attacked by fungus
is mealy and crumbles.  It runs in streaks and is a much lighter color.  I am thinking that for a working vessel as opposed to a showcase flagship, a grey
Holly may be more realistic that the white Holly or Soft Maple, which is close to white.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Good points, Jaager.  But, I'm using this for the gun deck planking on the hull (not deck) to simulate whitewash.
https://www.woodcraft.com/products/mixol-tint-oxide-white-20-ml?via=573621f469702d06760016d0%2C5764234669702d6593003339
Rather than using a destructive chemical reaction - bleaching - why not cheat ?
For $6 you could experiment with a dilute tint.  Try it in 91% Isopropyl rubbing alcohol.
Dries fast -does not raise the grain.  Given scale effect - less intense is better -
something a bit more than a hint of white.  Hard Maple or Holly should do well as the
substrate.
NRG member 50 years
Current:
NMS
Other
I never thought about hydrogen peroxide.   I'll get some and test.
Luckily.. I found a sheet and a half of 1/32 holly that's clear hidden in my wood stash.  I'll use that for now and test the not so good stuff maybe next week.  Just have a bit too much on my plate suddenly.
Hydrogen peroxide is available in several concentrations:
3%  is available in pharmacies - wound care and such
6% - 9% - 12%  ( 20 vol - 30 vol  - 40 vol )  is used for hair care
85-96%  is used as a propellant for rockets, torpedo , etc.  readily
decomposes to steam and oxygen - violent and dangerous in the extreme.
I wonder if 3% would have much effect at all?  My guess is that 40 volume
will have the best chance of success but will also damage the structure of
the wood it contacts.
NRG member 50 years
Current:
NMS
Other
With the last input I started wondering if regular bleach (for washing cloth) would work as well!?
Respectfully
That's the bleach I'm going to test when I get a few minutes..... Life and all that keeps getting in the way.
I'd be careful with bleach straight out of the bottle; it's a strong caustic. We kill most germs known to man with a ten percent solution. Splashing pure bleach on cloth will eat holes. Stop a caustic with some acidic solution. And do it under a hood or outside.
Ken
Started: MS Bounty Longboat,
When I was 15 or 16 I bleached an entire Cedar Barn for my Biology teacher.   It was a great summer job, I ruined much clothing but to answer your question' Yes very much wood can be bleached.
