Deck beams..
Preview gratings..
Steering position..
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Thank you very much Louie da fly and FriedClams. I try to be hard on myself ..:default_wallbash:🧐
I started making vertical beams that protect the side when launching boats. Base milled, but precise grooves created by the files ..
Installation of klinkbout on the sides..
Ondras.
On 7. 9. 2020 at 20:20, Backer said:
Great work Ondras
Thank you very much Backer, it's a compliment from you..🧐
Machined vertical beams glued to the supporting part ..
The front pillars, where the head will be carved, gave the most work..
I also have beams ready for the first carving test..
As a basis for the head, I used a drawing from Derfflinger's plan, RL is unusable..
Test whether pattex adhesive sticks to the waxed surface - OK!
Simple beams glued. Pins and wax are waiting..
Ondras.
Surrounded and waxed. The pins finally hold the wax-glued parts firmly..
I'm starting to make railings ..
Waxed gratings of the main deck ..
Ondras.
Thanks for the like..:)
Due to the need for dyeing and the need to create all the parts that will be dyed, I started making Knee of the head. I studied the construction of Knee of the head, it is nicely covered in the Czech thread by Doris Obručová for its construction Sovereign of the Seas ..
https://www.modelforum.cz/viewtopic.php?f=177&t=43575&p=882705&hilit=klounová+paluba#p882705
A study of Dutch ships, I found that the grate of the deck drawn from the folded slats is from a later time, historically more faithful is the grate of longitudinal planks, as in the plan of the Pinas Vitsen by Ab Hoving.
Production of Knee of the head..
Delivered paints and accessories to the airbrush..
Ondras.
Really like your design of the figures. look forward to seeing the finished figures.
Current build: Great Harry, restoration
On hold: Soliel Royale, Mantua
Completed:
Bluenose ll, Artesania Latina
San Francisco llArtesania Latina
Chris Craft barrel back triple cockpit, Dumas
Chris Craft 1940 double cockpit, Dumas
Santa Maria, Artesania Latina
1901 Scow Schooner, scratch built
Hannah, Continental Navy, scratch built
Candelaria bomb ship, OcCre
Pride of Baltimore, Model Shipways
17 foot Chesapeake kayak (2, one scratch), Midwest
USN Picket Boat #1, Model Shipways
Kobuksan, Turtle Korean ironclad, YoungModeler
HMS Revenge, scratch
NY Pilot Boat, kit bashed, Model Shipways
USS Monitor, scratch
Nuestra Senora de Afortunado, 1926 Popular Science plan, Resoration
Martha, CBMM,
Puddle Jumper, scratch stern wheeler
Lady Sarah, kit bashed Constructo Victorian launch
Thank you very much Boxbuilds!!:)
Thanks to new information on the construction of Dutch ships, the Knee of the head was repaired..
and Beams shaped..
Ondras.
Remarkable precision
Completed:
Martha, CBMM,
Thank you very much Boxbuilds and Louie!!:stunned:
I continue to produce parts that will be painted..
And I'm already training dry with an airbrush..
Ondras.
Ondras, your model and the craftsmanship you put into it is an inspiration. Beautiful!
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
On 10/14/2020 at 12:53 AM, Louie da fly said:
A real pleasure to watch your progress. Beautiful work.
On 10/14/2020 at 10:28 AM, Backer said:
Indeed, beautiful work 👍
Thank you very much and I really appreciate your words friends..:):stunned::imNotWorthy:
Knee of the head hips reinforced against twisting..
Made a spray box 1 meter wide from a paper box and discarded kitchen hoods ..
After training outside the boat, I start spraying ..💣
Ondras.
I have already finished the white one, a lot of layers were needed for the dark wood. But the result is beyond my expectations..💥
Another question, on the German plan from the book "Risse von Schiffen des 16./17. Jahrhunderts " and on my Czech adaptation, is a different shape of geometric shapes. But the Czech one has a simpler square one, so I'll probably use it..😇
Ondras.
I'm starting to masking .. ..🧐
Edited by Ondras71
Ondras.
Thanks for the like..:stunned:
Two days spraying colored strips..💣💥
Unmasked, a few places to repair, but satisfaction..
Now I have the most demanding belt with blue and green cubes waiting for me..:default_wallbash: O.
Ondras.
I have full confidence in you for a successful finish👍
Thank you very much Backer!!:)
I'm starting with the diamonds on the front wall, I want to find out what they will look like ..:unsure:
Preparing for the green ..
Ondras.
I went green. When choosing colors, I tried to catch the shades of Vasa colors..
But the green is too dark after spraying..:default_wallbash:
I will have to order a light..😲
Ondras.
On 11/19/2020 at 8:49 PM, Landrotten Highlander said:
You can make your green lighter by painting over it with a very thin wash of white with a dab of yellow.  A wash is basically a very diluted pint (i.e. 20 parts white spirit with 1 part paint).
Thank you Landrotten Highlander. I have already ordered a lighter green, after the adjustment the sides would not be the same. Ondras
Hips ready for blue ..
Ondras.
Blue done, only a few retouches ..
I choose the green color ..
Ready for green color..
Ondras.
I'm fighting green. The first did not cover at all .. :default_wallbash:
I had to use the darker one. At the same time, the front wall was redesigned..
The result is not so bad..:stunned:
Retouches are still waiting for me and matte lacquer comes on top..🧐 O.
Edited by Ondras71
Ondras.
The dyeing is already finished after two months, the retouches have stretched a bit. Red sprayed somewhere again. I damaged the acrylic paint with alcohol ..:default_wallbash:
Spraying with matt clear lacquer is also not without problems, semi-gloss paints do not want to matte. I'm studying how to do it..:stunned:
Edited by Ondras71
repair
Ondras.
Czech modeler Doris Obručová advised me to use an external matt spray topcoat. I tried matt Vallejo varnish ..
Tests outside the ship have shown the best way to pour a horizontal layer of paint ... Bingo
Then dry with a hair dryer and .. the surface is matte! Ship finally unpacked ..:36:
I will not edit any more..💥 O.
Ondras.
