I am part way through the Cross Section build, and will put up all the pictures I had. The text will have to be reduced to a few notes. This is my first attempt at scratch building, and all the timber used is cut down from what I have in the shed. Mostly recycled native timber beams, or logs that have been drying for several years. I have been working on this now for about 18 months.
Sanded to thickness.
Home built thickness sander.
Ready to start cutting.
Yeah, I have some the pictures I have taken but none the text. I know when I started the build I spent several hours going through all the past build logs and getting information.This was a great help. I figure others will do the same.
Frames cut out and seperated into each frame. I used two colors to tell the front and rear parts for each frame.
Sanding the outside radius. This sander I built with a motor from work that was going to be thrown away.
Sanding the inside radius. I have since upgraded the drill press so would be a lot easier no do now. The old one had a wobble in the chuck.
Snowmans
I was watching your build before the crash. How I will be able to continue watching. Thanks for re-posting the build. Looks good.
Ron
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
It's looking really good. Glad to have you and your post back here. B)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
This log is making me look like I can build at speed. Normally I only get a couple of hours a week in the shed after the kids are in bed.
Slight gap. this is the one I remade.
Glueing the keel.
Slot cut with the corner of a razor blade. I saw this on someone elses build log and thought I should try it.
I like the razor blade cut. I will have to try that also. Is the blade held in place with hot clue?
Ron
All fixed in place, and treenailed.
The next lot of timber is cut and sanded so I can continue working in the evenings. Recycled Rimu wall panelling and Kauri offcuts.
Home built bence saw run by dremel tool with a 50mm blade.
Nice work. I like your mini saw. Is that a piece of angle iron you're using for the fence?
Ron
Russ, the wood will be a lot darker once I put a finish on it. The rimu and kauri will have more contrast against each other.
Ron, yes the fence is a length of 25 x 25 mm angle I had in the shed. I think it is a colour sample from work.
Very nice work there. you're moving right along!
Rusty
This is a quality build.Enjoy watching your build   Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Nice work.  Very clean and I like the different shade of the planking.
Nearly up to date with the older photos. Made a zero clearance insert for the bandsaw and cut the timber for the lower deck and gun deck. All put through thethickness sander and finished to the correct size. Now I am able to do the next few stages in the shed during the evenings. The wood is a piece of rimu that had been used a paking for a larger order of timber. I saved a few off these while I worked at a building supplies company.
Ripped down with the bench saw.
Resawn with the bandsaw. Finished with the sander after this pic was taken.
