Marked the waterline with the included waterline marking jig.
Next I masked off the waterline with rubber pin-striping tape to more easily follow the contour of the waterline.  This was an awesome tip a follow forum member provides during my last build.
Next I used normal masking tape to mask off the remaining above water portion of the hull.
Finally I painted it copper as a background layer for the copper plating which will come next.
Finished the copper plating on the main hull! Although a pale shadow of some other models on this site I am actually quite happy with the results. A vast improvement over my previous work on the Revenue Cutter.
E3A0399E-AD77-4BF1-87F0-15A40360B1CE.thumb.jpeg.c1dc63295a924ac11282753de685215b.jpeg3BF9BAAD-AC0F-44AE-B59D-5D582FEF308A.thumb.jpeg.8bc12077e17ea8a2845dc64cb27c083e.jpeg441A8FE0-798F-44D2-8235-B0C1B568FCDA.thumb.jpeg.d3b614dd197975d8b89502656b814fed.jpeg35EC202B-3F86-4C18-A2D2-A9BC1282B73E.thumb.jpeg.77e720733dfe05a5d147510ec2850044.jpeg1A3896AD-47C5-4996-9E6E-3A5E224D4C2B.thumb.jpeg.70ce82d9702abce3f234cafea7d4ab55.jpeg
Next up are the forcap rails general bulwarks detailing. Also, I need to copper plate the rudder as well.
On another note, Bluejacket sent me a new instruction manual with the previously indicated errors fixed which I thought was really an awesome customer service gesture! Especially at no cost
7 hours ago, sjanicki said:
Another night with slow progress. Just had time to paint the copper base layer in the rudder. Next up is (what I anticipate will be) the last bit of copper plating on the model. I am still amazed at how much better this plating turned out than my last attempt.
Just proves what practice can do!
After examining the hull again I realized that one half of the waterline was in the wrong spot :(
This resulted in me needing to remove a couple rows of plates, re-mask, paint, and re-install with new plates another row. A little frustrated at my mistake but it’s fixed now. A624F7AB-0C86-4088-9E95-7A23B5CDDAC1.thumb.jpeg.07c0c91fbee5db811229c8abdf8935e1.jpeg
On to making progress again! :)
  • 4 months later...
Looking forward to the resumption of this project.  It should be moved to the 1801-1850 forum - presumably it was mistakenly placed in 1901-present because of the various USS Perry's launched in the 20th century.
Andrew Bodge
Finished:  Muscongus Bay Lobster Smack (Midwest / Model Shipways)
Finished: Maine Lobster Boat (BlueJacket)
Finished: Yankee Hero (BlueJacket)
Finished: Emma C. Berry (Model Shipways)
Finished: Northeaster Dory (Chesapeake Light Craft)
Finished: Schooner Bowdoin (BlueJacket)
Finished: US Revenue Cutter "Joe Lane" (Marine Models)
Missing and presumed lost: Friendship Sloop (Laughing Whale)
  • 5 weeks later...
@ahb26 Thank you! A number of crazy things this year but hoping to get back into this project over the long weekend! I haven't forgotten about it
Finally back at it!
Spent a little time getting up to speed at where I had left the model and just getting myself re-acquainted with the plans.
Next I installed the cap rails and inner bulwarks moldings.
Next I collected a number of pieces I anticipated needing to prime and primed them.
A slow day but back to making progress :)
Started off by installing the trim molding on the stern of the ship as well as the cabin windows.
Next up was assembling the ladders. I primed them after this picture.
Finally I mounted the various deck grates and long boat. I also assembled the long boat decking. I also mounted the various eye hooks for the cannons.
Next up is just continued work on the deck fittings!
Wow, you have made great progress since the last time I checked in! I'm impressed with your copper plating - that is something I have not tried yet.
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Thank you! I am actually quite proud of the copper platting on this ship.  My first foray into copper plates was on the Revenue Cutter and learned a lot (read made plenty of mistakes).
Going to try and continue with the regular progress!
Made some more progress this afternoon!
Assembled, painted, and installed the cabin doors as well as the stairways.
Next I removed a number of laser cut components and primed them.
I also primed and painted a number of cast metal deck fittings including the windlass and skylight roofs.
Trying to keep up the slow steady progress!
Made quite a bit of progress today!
Painted and installed the gun port lids (both the open and closes ones). The hinges that are included actually look great. I test fit the cannons and carronades to see how they looked.
I installed both Main Deck Fife rails as well as the Forecastle Deck Pin Rail. I also installed the cat heads. I actually cut them in two pieces to avoid cutting through the hull.
I installed all the channels/pin rails as well. This took a while to clean out the slots where they penetrate the hull. I was somewhat careless when painting and paid for it here by having to sand out the slot larger.
I also installed the forecastle ladders, windlass ratchet, chain scuttles, and anchor chains.
