Nice work on the rigging.  I thought the Wasa had nightmare rigging but the SOS rigging is beyond that.
Hi Vince,foot ropes or no foot ropes,a work of art it is,having a good cup of tea and reading and learning from your blog,also  the tools etc that you use makes a pleasant evening, I thank you sir for your time and effort,have a nice weekend,Edwin
Did ya use paint or gold leaf?
La Nina, Latina - Wood / 1:65
On The Shelf:
San Francisco II, Latina - Wood 1/90,     U.S.S. Constitution, Revell - Plastic  / 1:96 (Remake),     H.M.S. Bounty, Latina - Wood / 1:48,     H.M.S. /Mayflower, Latina - Wood / 1:64,     La Pinta, Latina, Latina - Wood / 1:65,     La Santa Maria, Latina - Wood / 1:65,
Completed:
San Francisco / Cross Section, Latina - Wood / 1:50,     Coastal Submarine, Revell - Plastic / 1:144,     Cutty Sark Wall Plaque, Revell - Plastic / 1:50,     H.M.S. Victory, Revell - Plastic / 1:146,
H.M.S. Bounty, Constructo - Wood / 1:50,     Oseberg, Billings Boats - Wood / 1:25,     Clipper Ship (Sea Witch), Unknown - Wood / 1:46,     U.S.S. Constitution, Revell - Plastic / 1:96,
Man Of War, Scientific - Wood / 1:50,     Robert E. Lee, Scientific - Wood / 1:45,     PT-109, Revell - Plastic / 1:72,     U.S.S. Enterprise, Revell - Plastic / 1:720,
R.M.S. Titanic, Revell - Plastic / 1:720,     Numerous other wooded tall ships and boats from companies named: Ideal, Dumas, Pyro.
Neither. They were bright brass plated. I just polished them and sealed them with clear lacquer to keep them shiny.
It's just a might grayer. :P
Excellent work with the rigging. Just Beautiful. Do you have any hair left LOL. Keep the pictures coming.
I added a feature to the rigging that is left out in the kit. Ships of the period had knights with lifts and halliards for hoisting the lower yards on the masts. This is what they look like rigged. The lift is heavy rope that is attached to a triple sister block and passes through the cheeks below the mast top trees and is lashed to the yard. The halliard is reeved back and forth through the sister block and knight and is secured to a cleat on the knight.
Vince P.
The amount of rigging for this ship with the realistic method and the sails is quite complex. Building the masts off ship and completely installing the yards, sails and starting the running rigging before setting the mast on the ship is critical. Once the foremast is set on the ship, all of the running rigging must be completely finished before rigging the shrouds. As far as I see it, doing it any other way will make it very difficult to get to the pinrails, cleats, and other belay points. This is different from the way I did it with other ship builds, but they did not have the complexity and very tight quarters in working on the rigging. This will hold true for the other masts as well. If you build the kit as the plans dictate, with the abbreviated rigging, there would be no issue, but completing it as I am doing with the more detailed rigging, and adding the sails, makes it a whole different ball game. I am almost done with the entire bowsprit and foremast. I will post photos to show what I mean.
Vince P.
These are crowsfeet. They were used to keep the bottom of the topsails from fouling on the mast tops. The kit does not address these but the SOS had them. I added them as per rigging diagrams of ships of the period.
Vince P.
Hi Vince
Sorry, i have only just caught up with yr build, what a change since we last talked, she looks fantastic, even the armadillo in the background
all the best kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Vince,
With each update your work becomes even more spectacular. Such a beauty. Rigging is an up-and-coming challenge for me. Looking at and reading your notes is a real learning experience. Thanks for sharing....
Michael D
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
This is just a general thank you to all of the modellers that have posted nice compliments on my log.
Vince P.
well Vince,thank you for the teaching you gave me,learning so much from so far,I"m truly gratefull.How can you top the sos,have you decided on your build.Ed(inspiring)
Incredible work!  I love the sovereign it's such a beautiful ship but it looks far to much for me at this point.  You make it look easy.  I love the little details you added as well.  Definitely adds to the ship.
I fimished all of the running rigging from the bowsprit to the foremast and the foremast to the deck. The starboard side has the shrouds of the foremast rattled as well. I added all of the little rope coils to the belay points on the deck and the mast tops. I am having nightmares about making clove hitches and still have to do a few hundred in the port side. :o
Vince P.
I just found another glitch in the kit design. The main mast at its base is 12mm. When it is stepped into the ship, there is a cutout in the keel that that the bottom of the mast sits into. Well I don't know how I missed this but when I placed the mast temporarily before planking the hull, to make sure it would sit straight up vertically and not tilt to either side, everything looked good. Turns out that I must not have pushed the mast all of the way down to bottom in this slot.
I am now starting construction on the main mast and again placed it in the hole to make sure it was true but I could not get it down far enough without tilting it slightly to port. I figured that the decks were slightly off, so I started filing the hole to get the mast straight. As it turns out, it had nothing to do with the alignment of the decks. They were right on. The damn slot in the keel is only 9.5mm and the mast is 12.0mm. So, I had to shave off both sides of the mast base about 10.0mm up so it measures 9.5mm across. Now the mast fits correctly.
If you are going to build this kit, fix the slot by making it 12.0mm before constructing the hull. :pirate41:
Vince P.
Wow!...
That is quite litterally a rat's nest of lines :o ... how you ever managed to keep that straight is beyond me... :huh:
It looks impressive... and that's only the bowsprit?!
Best of luck with the rest of the rig. She looks amazing
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
I bought this little work table made by Dremel to hold the ship on the table while allowing it to be moved around and rotated for access to the rigging and such. The keel clamps inside the gap in the table top and I made some custom chocks to cradle the hull. It holds the ship quite securely.
I saw this little table on Anja's build log and asked where she got it. She gave me some info. It seems that Dremel no longer makes this, but the TGM Shop from Amazon still sells them. It came all the way from Germany.
This will make it much easier to get all around the ship for the rigging.
Vince P.
Hello Vince,
It's great you finally got your Dremel workbench.
And the added custom chocks to support the ships are a neat idea.
Have to think about that one myself.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Here is the Union Jack raised on the bowsprit pole. The flag provided in the kit is not authentic in that the Union Jack was not correct for the time period. The one provided was a later version flown long after the SOS was sailing. I am not that efficient in English history to know that, but my friend Denis is from the UK and picked up on it right away. He was nice enough to have some correct flags made and he shipped me some for my ship.
The first photo shows the incorrect flag and the second the correct one.
Vince P.
Edited by Vince P.
Half cleats. I am constructing the main mast and two of the fore stays from the mizzen mast are lashed to the main mast. While the kit does not address these, cleats were needed to keep the stays from riding up under tension.
Vince P.
Edited by Vince P.
Constructing the mainmast. Since this is the tallest mast, you can get an idea how big this ship will be. Like the foremast, I will build the entire mast including the yards and sails and all corresponding rigging before setting it on the ship. Next up is installing the needed blocks to the trees.
Vince P.
Installing the blocks for the lifts and jeers on the mainmast tops. Also the lift and sister block for hoisting and lowering the lower yard, and the forward halves of the mizen stays.
Vince P.
For those of you that might build this kit from Mantua, here is some info on errors in the plans:
After I set the completed foremast on the ship, I started looking into the mainmast. The plans call for cutting the lower section to 360mm. I set this piece down into the ship temporarilly and something did not look right. According to other completed models and some drawings of the actual SOS, the lower crowsnest of the mainmast should be slightly higher that the same on the foremast. The top rail of the crowsnest on the foremast is about even with the tree on the mainmast. With the mainmast section cut to 360mm as detailed in the plans, the crowsnest is considerably lower than the foremast. In order for the mainmast crowsnest to sit at the correct level, it was necessary to increase the lower section to 407mm from 360mm.
Along with this, it is necessary to adjust the mizenmast to correspond to the change in height of the mainmast. The plans call for the lower section of the mizenmast to be 320mm. Increase this to 385mm. Then all of the mast tops are in correct alignment.
Vince P.
Hi Vince
Lovely work,and I must say your rigging is very impressive.I think it may be a year or so before I get to that stage.
Kind Regards Nigel
Currently working on Royal Caroline
Since I am completely assembling the masts off ship, I wrap the lower shrouds to be rigged later on the ship. The shrouds are wrapped in pairs. One piece of rope goes around the mast top from fore to aft to make a pair. Usually the pairs are wrapped starting on the starboard side and then the port side and back to starboard and so on. This ship has 10 shrouds on each side which is 5 pairs to a side. Later when rigging them to the deadeyes, they must be rigged in the correct order starting from the starboard side, pair 1, then to port, pair 1, and back to starboard pair 2, and so on. Also, the shroud in each pair that wraps from the fore side of the mast must be rigged first and then the other in the pair. This is necessary so the shrouds do not bunch up and cross each other at the mast top. You will really see the mess when rattling towards the upper end of the shrouds, if it is not done this way. I simply number the pairs on each side as they are wrapped, and make the forward one of each pair a little longer. Later when rigging them just take them in numerical order and the longer of each pair first.
Vince
