(Sorry for the mix up, I put it in the wrong category by mistake!)
As the lockdown continues here in the UK, I have been steadily working on my Jalouse. Just finished the Ballahoo a few weeks back.
Here are some pictures of both. I do hope this log can help future builders of the Jalouse as there seems to be no logs at all on this beautiful ship.
Cheers,
Tom
Here is Ballahoo and the beginning of Jalouse:
Hi Tom,
I am under the same impression. Jalouse is a beautiful ship and really worth building. The hull of your model looks very good and I am curious on your progressing.
I was also looking for a build log and finally arrived at this friendly forum (signed up only last Friday).
Similar to you, I built the Ballahoo and bought the Jalouse thereafter. I started with the kit last year late in September and I am currently working on the deck fittings. I will probably start a build log shortly, however I began taking pictures only after first and second plankings were completed. I guess it will be very nice and interesting to compare our kits and exchange hints (no competition intended).
Take care!
Uwe
47 minutes ago, thomashd said:
I am really confused as to why no one ever did a log on this ship. Beautiful lines and perfect for a second/third model.
There are several models in the Caldercraft lineup that don't seem to have caught on as well as others, for whatever reason. Jalouse, Cruizer, Snake, and Mars are all wonderful single-gun-deck subjects, but we hardly see them in the forum. Lots of build logs  for Sherbourne and Victory, their bottom and top end kits, which makes sense. The Amati Fly and Pegasus kits were huge hits and probably stole the thunder from some of the earlier Caldercraft intermediate-level entries. At least that's how it went for me -- I was all onboard with going for Snake as a fourth POB build until Fly became available. Someday I may even finish it!
looking good mate!
Remember to clean the copper plates after every session if you have sweaty hands.  I learned the hard way... Some of my tiles still have finger prints etched into the metal even after polishing.
This is truly one gorgeous build. I LOVE the woodwork and finish.  Flawless!
On the bench:  Vanguard Models 1/64 HMS Speedy
On Deck:
Vanguard Models 1/64 Zulu,
Vanguard Models 1/64 Fifie,
Victory Models 1/72 HMS Bellerophon
Nice work!!
Your coppering looks fine to me, but I'm not an expert as I've not coppered any hulls yet😏
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
You're Cruising right along with coppering. Looking good!
You didn't all that coppering in one day? Amazingly accurate!
I have tried coppering so far only once, and that (HM Schooner Pickle) ended -also for other reasons- in the waste bin. So I decided to paint my Jalouse white...
The beauty of being on a holiday... I think future ships will also not be coppered I find it excruciatingly annoying and rather unpleasant for the overall aspect of the ship
Jalouse is not dead, I have just been on a research trip in France for my job! I finished the coppering which is now looking nice and green. The patina is really growing on me. Started the deck fittings, my favourite part of the model. If anyone has a trick to rig guns fully without losing their mind, let me know...
Any parts more frustrating than others? I’m currently at this stage and doing it for the first time following two references from build logs. Both have helped me immensely, but there’s no getting around doing it 🙂
H.M. Cutter Alert by Blue Ensign
HMS Speedy by Delf
Both have great insight.
HMS Speedy by Delf
The gun tackles are a bit problematic, I cannot seem to find the right tension and then there is the serious issue of making a proper rope coil at the end.
I hope you're not trying to make these by using the actual ends of the tackles themselves? That would be a nightmare! What I do is tack the tackle to the deck with a spot of CA and then trim the excess line. Make the rope coil off the model and then glue it down to the deck, being sure to cover the tacked end from the previous step.
Are you doing this on the model or have you made a jig off the model? It may be easier off the model if you can.
I'm starting to think that I might not include the coils and go for a look like the second picture in this post (assuming the link works):
https://modelshipworld.com/topic/22783-hms-speedy-by-delf-vanguard-models-scale-164-master-shipwright-edition/?do=findComment&comment=731381
