I've used mine for over 8 years . As Jim says, mount with jig, ruler and stop, and repetitive cuts, deck planks for example, can be reproduced 6 or 7 at a time . Single cuts can be produced quickly and accurately. Those in the USA should appreciate how cheap they can obtain such tools, (Good luck to them). Even at 3 times the price (I paid) very worthwhile.
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
I had one once.  But found out I could just as well on my modeling table saw.
15 hours ago, Jim Rogers said:
I picked up almost the exact same saw at Harbor Freight for $25. I mounted it on a jig with a stop to make repetitive cuts faster and more accurate.
Jim,
Same here -works perfectly - and looks identical to the Micromark example.
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
UK source:
https://www.ebay.co.uk/itm/100001-Art-Craft-Mini-Cut-Off-Machine-Steel-Cutting-50mm-Mitre-Saw/292743524367?epid=6031289762&hash=item4428dfb00f:g:r-UAAOSwyulbqig~
I was interested to hear the good comments from owners. The ability to set angles with confidence makes it tempting. Maybe later.
Bruce
STAY SAFE
current builds:
I just ordered the Harbor Freight version, whose price has soared to $33 plus shipping 😉
Has anyone tried thin wall brass telescoping tubing with this? I use that for the tuning slides on the Irish penny whistles I make, and I haven't found a terrific way to cut it cleanly without deforming the tube.
Brewerpaul:
A fine-tooth, metal slotting blade on a modeler's table saw will do it.  Just don't try to cut the full diameter in one pass.  Set the blade height at about 1/4 the tubing's diameter, hold the tube in place on the cross slide and begin the cut.  Then, without advancing the cross slide any further, rotate the tube to finish the cut.
I suppose this technique could be used in an upside down fashion on a cut-off saw by partially lowering the blade.  I don't have a cut-off saw so I've never tried it.
In spite of the small size of the cut, the chips are hot.  Protect your eyes.
If the inside of the tube was filled with a tight fitting dowel, the brass may not have the opportunity to bend.
Close examination of Jim's first photo in post #7 shows two or three points for this unit:
It does need to be fixed to a base.
The bottom of the vise clamp is higher than the right side of the cast metal base.  If outboard support of the work piece is desired, the right side flat surface needs to be higher and the cast base surface is not dead flat, so doing the table extension is tricky.
The vise can rotate but the gauge is not exactly accurate.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I do this all the time.  The cut edge needs to be cleaned up both ID and OD.  A wire wheel works fine for the OD and either a file or a knife blade for the ID - keep a blade just for this type of work - you don't want to try using the blade for a fine cut after using on the tube.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
