Getting ready to rig some shrouds.
Rob
Current build:
Finished build:
Current build(On hold):
Rob, consistent, impressive, clean work, as per your usual high standards. I noticed the addition of the exhaust vent. It looks nice. How you get your ratlines so level and evenly spaced is simply amazing. Keep up the great work!
She's certainly coming along nicely, Rob! Great work at such a small scale. I've never seen a better job on a coppered bottom at this scale. You've achieved a compellingly realistic effect. Anybody who undertakes to copper a bottom at this scale should take a close look at your work.
Thanks Rich.  those flutes could have turned out to be many things...but I wanted to match the galvanized one on the main cabin.
I have developed and am blessed to have an extremely (Level) eye.  I set the first ratline and then.....bluuuuuup....I set the next and next..all the way to the top till I'm done.  In the past, I would  rig several masts at a time and the time spent between them gave enough time for the glue to set, so I could go back to the first and keep repeating the process...never having to wait .  Unfortunately, here...I need to wait for the glue to set for each one so I do not interrupt the previous one.  I alternate between the futtock shrouds. when I finish them....well....I find other things to do.
Rob
Current build:
Finished build:
Very appreciated Bob.  If one looks back at that portion of the build...they can see I expedited the process by creating plate and nail embossed strips....using copper tape.  Painting the entire bottom (Over the shiny copper), with a good metallic paint...aided in securing the plates(to themselves and the hull) and transforming the *copper* color to the more realistic color of weathered *Muntz* metal.  Which is what the Glory was covered/plated in.
Again, I wish to thank you for your continued support and encouragement.  Coming from one  with such an experienced background as yourself, is truly motivational.
Rob
Current build:
Finished build:
I received the 18" cleat yesterday for the mounting for Glory.
I muddled over this and I'm going to do something I typically do not do.  I'm NOT going to show you the cleat...or any aspect of the bases construction.
I want you to see it for the first time...complete....and with Glory sitting on it.
I want to hear your responses...without any prior suggestions, without any hints or indications from me.
Now, everyone knows what I am attempting to make with this new base, and many or most, already have a preconceived idea of what it will look like(Good or bad).
I would like everyone to see it for the first time together.....then let the chips fall where they may.....
Rob
Current build:
Finished build:
Teaser! ;) :)  Looking forward to seeing it.  A clever idea you have come up with.
cheers
Pat
Edited by BANYAN
1 hour ago, BANYAN said:
Teaser! ;) :)  Lokk forward to seeing it.  A clever idea you have come up with.
cheers
Pat
Teaser reveal!
I worked all afternoon, milling, grinding, matching hull curves.   A bit of paint and finally, mounted on an antique wood  ornate plaque salvaged from a nautical collector in Puget Sound.  Probably from a local coastal schooner.
I think it is quite convincing in its display characteristics.  I have a few more small items to finish, like felt bottom.
What do you think?
Rob
Current build:
Finished build:
 Rob, I like it. Out of the ordinary but it works.
That’s a nice idea. I’ve not yet committed to any particular mounting method for my Cutty Sark other than not the kit way, and you’ve given me food for thought.
Kevin
Current projects:
Rob, my apologies. I was concerned that a big, bulky cleat would somehow bury your lovely model. Boy was I wrong. I agree 100% with your clever choice. It's a distinctive and classic mounting for a distinctively different Clipper Ship. Your work is so elegant that I believe Donald McKay himself would approve!
Thanks everyone.  I feel it still provides the *Pedestal* look, while reminding us that cleats were actually a functioning part of the clippers working structures.....Glory carried many.  Then to follow up with a unique antique ornate nautical base that is repurposed(My mantra) as a base.....just ties so many individually distinctive elements together.....making a most striking display.....IMV.
Side note:  The base has in itself  nautical origins and a most tragic end, reminiscent of Glory's own sad demise.   I find it only fitting the two are joined to finish their lives reminding us of our rich nautical heritage.  The natural patina of the base adds to the authenticity of the idea being conveyed.
Rob
Current build:
Finished build:
Rich....Mike has been asking me if we are going to do a write up of the models for NRG?  I told him that you were going to do something like that.  He'd like to help if you need any assistance.  He said your email or his isn't working so he can't seam to get in touch with you.
Rob
Current build:
Finished build:
4 hours ago, MrBlueJacket said:
Great display cleverness!
Thanks Nic.  The Display should be as thought out as the model itself....IMV
Rob
Current build:
Finished build:
Rob
Rob, tell Mike I welcome his help. I'm in process of writing it now in anticipation of meeting the April 1st deadline, which wouldn't be published until the Fall. I was wondering what happened with Mike. I thought it was because he was so busy with his book publication that he had no time to email me. Apparently my gmail is full. I've been trying to empty it but I can't seem to find a way to delete all. I'll send Mike an email from my business address and see if that works.
38 minutes ago, druxey said:
Another sceptic converted! Very effective, Rob.
Bringing my vision to life and convincing others it is trustworthy can always be problematic……Even much more if I didn’t/couldn’t pull it off.
Thanks for you confidence and encouragement.
Rob
Current build:
Finished build:
Rob,
How do you plan to rig the head stays on Glory?  It appears on the one photo of Glory, the one of the figurehead from the port side, that the stays set up under the forecastle.  The Flying Fish is rigged the same way.
1 hour ago, Rick310 said:
Rob,
Rick….if you look at this image you will see the three Bolt points for the stays…..mounted just under the Tip of the name board.   The for stay passes through the bees the back to this point.   The inner jib passes through the jib boom back to the martingale and again back to this point.    Same for the jib and flying jib.
Thanks for askin.
Rob
Current build:
Finished build:
Rob, this picture of Glory's prow is one of the most beautiful so far. It has such a graceful "S" curve to her that perfectly matches the vessel herself. I know you were highlighting the mounting points in this pic but I thought you might appreciate knowing I recognize the authenticity of your lovely model.
Wot they said!!
great stuff Rob
Michael
Thanks Rich.   She is coming round.  When I get those jib stays installed she will look magnificent.
Rob
Edited by rwiederrich
Current build:
Finished build:
Thanks Michael and Pat……..that means a lot
Rob
Current build:
Finished build:
After final fitting the hull to the cleat……I had to do a bit of hull touch-up while the cleat dries to the antique base.
Rob
Current build:
Finished build:
