Hawker Hurricane Mk IIc by Lt. Biggles - Hasegawa - 1/48
Nice job!  Those seatbelts look amazing!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Share on other sites
On 12/29/2020 at 1:21 PM, Old Collingwood said:
What I found real useful with Vallejo putty  is you can also use a cotton bud or piece of rag and wipe over the gap being filled, or even a finger   - its that plyable.
OC.
Using a damp cotton bud has worked a charm thanks! Basically leaves it to dry already perfect and probably hardly needing a sand if at all!!
Link to comment
Hope 2021 is treating everyone well!
ive been busy covering everyone’s shifts so they can have a holiday so haven’t done much on the hurricane. But put the carburettor intake together.
and using a bit of spare PE from my HMS POW ship build added the grill.
next is the radiator fairing and then the brass gun bases and basically ready for the base prime... whenever I get to that point!
Link to comment
So glad it worked 👍
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Day off today and it’s too hot to go to the beach so did some more work on this. Did the radiator intake
tucked away and probably not seen again, but if anyone does have a sneaky peak it should pass the test!
used streaking grime to get the reddish tinge it seems to have and then a thick black wash and highlights
I’ve replaced one of the cannon bases with the brass one... 3 to go. Didn’t know the outer cannon stuck out more than the inner. All the small details you only learn when you have to work on it
Edited by Lt. Biggles
Spelling
Link to comment
Doing some experiments with the landing lights.
ive drilled out a similar size hole and have filled it with gloss varnish to see if it dries clear even when in a big blob.
if it works will will probably use it as the bulb. Once the lights on the wings are sorted ready to prime as I tried out using a canopy mask for the first time ever! But!!! I forgot to make sure the inside of the glass was clean from dust or finger prints before I glued it on so maybe it will have to come off if there is anything awful on the inside 😂
Link to comment
The wing root filling looks fine. No surface details seem to be lost.
Regards,
Dan.
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
  • 6 months later...
So it’s been awhile since my last update, she says in my cupboard for a while between little bits and pieces. So thought I’d do an update.
planning how to do the camo was what caught me out and it just sat there.
primed and then some base work by airbrushing through a sponge.
then grey coat of paint.
took awhile how to work out the best way to mask so it has a slight feathered edge. Tape would have been a last resort. So using ziplock bags traced the camo with a pencil.
then traced it to paper
cut them out and stuck them on with Tamiya tape turned on itself to be double sided, took a few days!
I then redid the base effects
and applied the green top coat
Link to comment
Good to see you back  -  hope life has been serving  you well?
OC.
Current builds
Completed works.
Link to comment
I use the same technique for scale feather edging brother... Except I use long thin strings of modeling clay or blue tack, (think spaghetti like) to hold the masks above the surface... It's a simple solution for tight feather edging and makes the spraying easier....
Nice work....
Quote:
Link to comment
Lot of work on the camo. Just one comment about the feathered edge camo. RAF used rubber mats that once laid on the aircraft surfaces were used to delineate the areas to be sprayed. Hence, the resulting edges were more likely sharp than soft. At any rate, your model looks good whatever the the look of the edges will be.
Good luck and best regards,
Dan.
Link to comment
Nice work....
Hey, yea I had seen bluetak used before but was worried it would rip the paint off! It can be really sticky!! I have been thinking how best to do it for many many weeks! Just bit the bullet
Link to comment
Dan.
Thanks mate, yea you are right they did have hard edges it’s more a personal like. Just found a hard edge in the small scale was to violent. I went for a very subtle feather and seeing as it’s the base coat will get a few more layers to soften it all up. Here is the feather it has.
the blue shade really pops out against the green. Thanks for the info on the rubber mats as a mask!
Link to comment
5 hours ago, Lt. Biggles said:
Hey mate, yes all going well. Lots of Astro really enjoying it. Thought I better pop in for a little update. Hope all is well with you too?
Yeah   we are ok mate.
OC.
Current builds
Completed works.
Link to comment
I just buy the wide masking tape and cut at will ;)    I think yours came out really good........should look really neat over the whole plane!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looking fantastic Biggles!  Not sure if you're aware of this, but I saw that NeOmega Resin makes a really sweet catapult for the 1/48 Hurricane.  I have their catapult for an upcoming Walrus build, but this one looks really tempting:
https://www.neomega-resin.com/cam-ship-hurricat-catapult-section-997-p.asp
collect.asp?site=neomega&serverid=14&rnd
cam-ship-hurricat-catapult-section-997-1-p.jpeg?v=1
Mike
Link to comment
I believe there is a kit of a Japanese plane on a catapult.........don't recall the maker though.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
