Back in those days, there was no regulation to govern such things on working vessels. The Bureau of Navigation wanted to make sure they had the name clearly visible on the boat, that they had running lights etc., and that they had a current license issued by the customs collector.
Russ
I have been following your build with much interest. My grandfather grew up on the beach at Bay St Louis in the '20s and was an avid sailer of schooners and cat boats. He spoke fondly of the commercial Biloxi bay schooners he saw all around him.
Just a question of terms.........auto correct is objecting to my use of sailer with an "E" rather than the "O". But I think I am correct in this usage.
Edited by michaelpsutton2
Drown you may, but go you must and your reward shall be a man's pay or a hero's grave
Michael:
There were many schooners working in the Bay St. Louis area back in the 20s. Most of them probably shrimping and/or oystering for the Peerless Cannery or Dunbar-Dukate's local cannery.
Your father was a sailor, but he sailed schooners and catboats. Best I can do on that. :)
Russ
Adding my wee voice to the chorus of praise, I have to say that not only are your skills in joinery admirable, but your historical knowledge as well.
Always a pleasure.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Always a pleasure.
Cheers,
Martin
Not to mention spelling and grammar.  :)  :)  :)
Steve
  • 2 months later...
Finally, an update. I have been wrestling with the chainplates and deadeye strops. These are still just hanging there, not yet aligned and permanently attached. The assemblies will be painted white. They are rather rough looking, but they are an improvement as far as scale size.
I have been working on getting the pieces down to something close to scale, and also how to connect the strops and the chainplates. Note the bolt and nut used to connect the strop and the chainplate. These are from Scale Hardware.
Russ
they'll look better with paint Russ........nice!   the bolts give a detail you don't usually see.   looking good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Russ,
Marvelous detail on those deadeyes. Those strops look really smart!!!
Carl
Nice to see the progress Russ
michael
Russ
Your "work" paid off.  They're looking good.
Bob
Current build:  SS_ Mariefred
John:
Thanks. It is tight quarters for soldering. The bolts are .5mm in diameter and the nuts can be difficult to deal with, but once you get the hang of it, they work very well. Much better than gluing the pins for sure. :)
Russ
Elia:
Thanks for the kind words. I know they look awful right now, but as you say, they will be painted and that will help push them into context. What really makes these work is the bolts and nuts from Scale Hardware. I have already laid in a stock of various size bolt and nut combinations for a future larger scale build.
Russ
Kudos Russ.  When I did mine I used brass rod the right diameter and press fit it .  Yours look great.  I never heard of Scale Hardware.  Those bolt add to your assembly and really do it justice.  I wish I had some of hem would have saved me alot of grief and time.  Too late now.  Well done.
David B
  • 4 months later...
Russ -
It was good to see you at the Wooden Boat Show in Biloxi earlier today. Also nice to see this little gem of a model schooner.
Everyone -
Photos can't do justice to the intricate detail in this build. Too bad I didn't have a magnifying glass  :)
Kenneth
Kenneth:
It was a fun day. We got to see some great boats and talk with some really nice people. Even managed to plank a model skiff hull as well. Not a bad way to spend the day. :)
You are far too kind about the schooner, but I appreciate it.
Russ
It has been a while since I had a real update, but it has been busy, both in the shop and out. Work gets in the way, but I have also had several commissions of late, some of which I will bring to your attention in time.
Here is a look at the wheel. The close up looks rather nasty, but once it is on the deck it blends in quite well.
Russ
Edited by russ
I have been working on some metal pieces as well. Here is a shot of the band at the top of the topmast. The entire topmast will be painted white, as will this band.
Russ
Edited by russ
One challenge that I have been working on is the mast hoops for this model. At 1/48 scale, I have been trying to come up with a way to make them small enough to blend into the scale of the model. I need 22 hoops, 11 for both mainsail and foresail.
Here is what I came up with. Brass wire is soldered into a loop and the piece cut off with a tail. The piece is then fitted over a dowel that acts as a jig to make sure that the hoop is circular and that it can be filed up with no problem. Once the tail is cut off, the hoop is filed to remove the evidence of the joint and then it is filed all around the outside to make that side somewhat more flat.
The last thing will be to chemically tone them with Bluejacket's Brass Brown. Once sewed to the boltrope and in place on the mast, they should look enough like wood at this scale.
Russ
