HMS Snake was launched in 1797 as the only member of her class of brig-sloops. She captured or destroyed two French privateers and one Danish privateer. She also captured numerous small merchantmen, but spent time escorting convoys to and from the West Indies. She was sold in 1816.
Scale: 1:64
Length: 910 mm
Width: 350 mm
Height: 910 mm
And now the build begins.
Looking forward to the show. 👍
STAY SAFE
current builds:
Again a little update.
The gun bulwarks are in place.
It was a little tricky but it goes better than I thought.
A few minutes soaking in hot water and the job was done.
Also placed the stern facia and stern facia knees.
And the stern counter facia.
The first plank can be placed.
Enough talking so time for some pictures.
Sjors
Thx Mick,
Welcome back then 😃
Aggy was a while back and this one is a little smaller.
So maybe i will finish her sooner.
And do you have a build?
Sjors
Thank you Sjors.  It’s good to be back and I have started my Caldercraft Granado again and I also have a very old Mantua Endeavour model.....I will try and make something of that as well.
i also caught up on your other build....the Nuestra Senora....but it looks like that one is causing you some problems...?  I hope you can succeed with it.
i look forward to your updates.
Best Wishes.
Mick
Hi Mick,
The Nuestra don't give me much problems but I have to finish it for my wife.
And it is always a little difficult to go further on something that is done for a big part.
I'll be making ratlines on that one. but almost finished.
Sjors
After a few weeks of planking and a little bit more sanding the hull is smooth!
A smooth substrate  for the second planking.
That will start in a few days....
For now pictures.
I don't make any stealers or drop planks because you don't see a thing about it!
Just the easy way 🙂
Sjors
And a little update again.....
Thank for the likes and the visiting.
Second planking done and after a few hours of sanding I'm happy how she is.
It is so smooth the I can not trust my fingers 🙂
On the picture it looks otherwise but that's the light I believe.
I have now a good underground for the paint nd the copper plaates.
But first the inner bulwark and deck planking.
Sjors
Thanks Mike,
I will slow down 🙂
At the moment I can take a look with wat you are doing en make a copy of that .
So please hurry !!!! 😄
Thanks for the likes.
Deck is planked and have the first coat of Danish oil.
Bulwarks are painted in the colors by Mike_H 🙂
Make the waterline and place also a plank so I know where I can put the copperplates.
Sjors
looking very nice, are you both well?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1 hour ago, Sjors said:
Thanks Kevin,
We have no Covid-19 😄
And you and the Admiral?
Sjors
everything is fine here as well, both the admiral and i have had the 1st jab, 2nd due soon
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I 'm not that fast Mike 🙂
Coppering of the hull is done!
The starboard side is with glue en the port side with double-sided tape.
And that works just great!
No glue on the tiles.
No glue on the fingers.......
Sjors
2 hours ago, Mike_H said:
Good progress Sjors.  Double-sided tape is interesting, did you apply it to the hull and then stick on the tiles?  On another point, I'm thinking of buying some Proxxon tools, and I can see you have some.  What do you recommend?
Mike
Thanks Mike,
Yes I apply it to the hull, then take off a part of the paper and lay down a tile.
I will show it to you tomorrow when I'm doing the rudder.
All my tools are Proxxon.
There are 4 things that I use the most of the time.
That's the lathe 250DB for tapering the masts.
The disc sander.
The mini table circular saw
And the bench drill with the  Micromot 20 150 cross table.
And for the lathe ,see if you can find the extension.
I will post a picture of that tomorrow.
Sjors
hey there Sjors.......thought I'd take a peek and see what my good friend is doing ;)    moving pretty quick on this one.........look'in really good! :)
no Covid.......we've both had our shots!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis,
Thank for the good words.
We have both the first shot and wait for the second one.
Anja is working from home and i don’t work for 4 months now.
I have colitis ulcerosa....nasty disease but i can live with it.
Sjors
Mike_H,
First the copper plating of the rudder.
The first picture you see the under layer of te tape and above it the layer with the paper still on it.
The second picture you see the copper plates.
Easy to work with.
Then the lathe.
You see the extension bed and the total length of the lathe with the extension bed.
I mond the bed is difficult to get but mine was bought in the UK.
Don't ask me where because it was a gift from Mobbsie.(also a member of MSW)
More questions then just ask.
Sjors
Edited by Sjors
Hi Sjors
Thanks so much for the details of the coppering and of your tools.  Have you used double-sided tape this way before.  I would worry a little that over time the adhesive would go brittle.  If not, then this looks like the future to me: quick and clean is what we all aim for.
Your list of tools is pretty exactly what I’m thinking about (though that would be news to the admiral!).  I’d be tempted by a chop saw, but I’ve not looked much beyond the lathe and bench drill.  I think you can get extensions in Australia, and we spend quite a lot of time there when there isn’t a pandemic.  Let’s see how many tools I can sneak in the house!
Very sorry to hear of your colitis - though glad it’s not too debilitating.  Perhaps being off work explains your progress!
best wishes
Mike
I should confess I stole that colour scheme from @Beef Wellington...
