HI all. My name is Paul Smith and I live north of Toronto.
I have been building and flying RC aircraft for a while and recently switched over to building my first ship.
I picked up the Latina Bluenose II as it was local and looks like a decent kit.
First impressions:
  • Kit packaged well and the fittings in plastic boxes is a nice touch.
  • Wood looks good although the plywood hull has some warpage.
  • No instruction book as they are on a CD. Who uses CD's these days. Had to get my old laptop out to print out the instructions.
  • No scale plan that I could find so placement of parts might be a little hard to determine.
  • Rigging instructions lacking but I think I can deal with it.
So far I have the hull together and Deck planked and am starting on the planking of the hull. I am using my covering iron and water to bend planks and it is working well. Also I am doing a light sanding after each plank (personal preference)
Later I will take some pictures and start a build log.
I am having a lot of fun and working slow and it looks good so far.
I dont have much in power tools. Scroll saw and a dremel and a hand held drill. I also do have a Prusa MK3 3D printer and am making use of that for different jigs which helps.
I currently have my eye on the Model Shipways Niagara as my next build also and am wondering how good that kit is.
I will close with a picture of the scratch built Sopwith Pup I made from plans.
Paul
Current Build: HMS Winchelsea 1764 1:48
Completed Build: HM Cutter Cheerful-Syren Ship Models 1/48
Completed Build:  Artesania Latina Bluenose II
Completed Build Lady Nelson
Niagara is a fine kit. This is an older Model Shipways design, and MS kits usually require builders to essentially scratch-build components using kit-supplied materials; in newer kits, many of these same components are built from laser- or CNC-routed parts. Choosing one or the other style is a matter of personal preference, and based on your beautiful Pup model, it certainly looks like you would not be thwarted by the MS design philosophy.
Welcome to MSW, Paul.  The Pup looks great.  Looking forward to your build log.
Paul, welcome to MSW. Stow your gear in a build log and enjoy your stay.
Edited by Keith Black
and welcome for the other side of the country as well, nice looking pup.
Michael
