Dear all, I guess I need help Folks. :)
Can anyone explain to me fore royal and topgallant bracing? I admit Im lost in Underhill regarding this.
Bottom yards are self explanatory but royal?
 I get that brace goes from yardarm to the single block at topgallant hound of main mast.
...but where it is heading down from that block down is mystery to me so far. I cant continue till I resolve this conundrum.
maybe  Rob ? :)
unfortunately EdT young america is not helpuling in this regard as well. At this point net is pretty dense....
many thanks V.
Well Vlad.  Several paintings show several different insertion and block points for both the fore topgallant and the fore royal braces.
Dependent on her modification year.   I think in your case...the fore topgallant inserted and had a downhaul block located at the crosstree base of the topgallant mast on the main, and the royal inserted and downhaul block was located under the main topgallant yard....where the shrouds affixed to the topgallant/royal mast stepping.
I inserted and ran both fore topgallant/royal braces back to their downhaul blocks at the main mast topgallant crosstree base.  These then ran back and down to their respective purchase blocks on opposite sides of the bulwarks to a return block and then to their pin on the rail.
Hope this helps.
Rob
Current build:
Finished build:
Current build(On hold):
Hope this helps.
Rob
Thanks much Rob, i will elaborate on that later. I guess I will have to draw it for myself to absorb it :) V.
OK - braces are pita. worst nightmare.
well im probably overcomplicating it a bit, but untill i grasp matter sufficiently enough I made myself a boundaries not to make it wrong at least i need to perfectly underatand it first.
my vague english doesnt help much i guess so I maybe struggle with few terms and imagination obviously.
first. this is probably later era of bracing, what Underhill describes but its only source i have so here it goes.
fore royal brace
single wire, shackled to the after side of the yard arm band  - perfectly clear
reeved through a single block on the side of the mast at the main topgallant hounds ( or stay , to keep brace below foot of main royal sail. - perfectly clear.
and now -
From the lead block at the hounds the brace goes down -inside the backstay
  and is spliced into the eye of single block for the whip  - ???? (what is whip in this meaning please?
and it goes on:
The standing end of the whip is seized to the main topmast capstay - clear
taken up and thru the block , down through the single bulls eyes fairlead  on no 3 main topmast backstay !!! and belayed on pin 59 in main rail, p &s. -
( this is complete mess for me :))
- i guess i would need it to see it sketched to understand...underhill picture is not helping at all....at least it diesnt show anything usefull...or  corresponding with describing at all. where is backstay fairlead?
 gosh....its PITA.
V.
what is this strange do oduble block ??? pretty advanced drawing for experts. function? looking like?
thanks a milion to bearing with me...
just its really matter for study and experience ....though :(
i would appreciate any as easier explanation as it gets.
i guess id need somethung this easy to understand ...:)
Edited by Vladimir_Wairoa
add
Ok i think i got it. Its same matter with whip as in many thinks. Basically its matter of size of vessel. Bigger the ship, its necessity plof purchase to do the task due to wught of yards etc.
So, we even have photo showing pretty mucj nraces of glory from quite early date.
what is interesting to observe even fore  royal yard has block whip so i assume there is not one needed at the bottom, at the.  deck. i made it this fashion, with topgallant yard having whip at the deck. but to that later as  it is not completed yet. you xan see start of work at yards level now.
Screenshot_2023-11-19-11-21-01-395_com_miui.gallery.thumb.jpg.41f765b19f8b995e59681ebb8713b56d.jpg
Vlad,
I'm not sure if you've worked out the lead of braces from Underhill as yet.
I was looking at that diagram today. Picture attached with an explanation (my interpretation), that I hope makes it clear.
Regards,
Grant.
On 11/26/2023 at 10:29 AM, Boccherini said:
Vlad,
Regards,
Grant.
Grant, thank you.I much appreciate the effort to unpuzzle this pic. Yes I organized it with similar fashion though, I dont hqve it pinned at the deck so it is reall mess with some clips all over. I will post it when done. aso basically from the top to bottom, three yards are done. i had to order blocks for bottom yards meanwhile. V.
Braces.
Thanks much everyone for bearing with me, as I freak out sometimes probably untill I grasp the matter. So finally I finished uoper yards. all pinned and clear. I must say it was easier at the end than seemed at first, and seing order at the deck is astounding me despite of lines that are amassing more and more. For aforementioned whip, I realised its similar matter of choice as with hanging lower yards. Euther there is a whip under at fiferails or above yard for sake of space at fiferails.
If i understood correctly, There is omision possible usualplly for royal yard brace, as for yard being lightweight. But nilot so for lower heavuer yards. goal is to make hauling possible or easier i guess. Correct me if i am wrong here pls. Anyway, as I went for having almost all uper yards braces whipped( purchase) at the upper part, I didnt bother with whipping down at deck level, basically I led those thru blbrace block at backstay position down to the corresponding pin and rail.
This post will be longer and full if pics so I hope it will make a sense and not confusion.
1.
Apology for amateur pics with undesired objects in backround. We can see order and outcome. Red arrow points to main skysail yard brace, its surprising it ends at very top  if mizzen mast where it is quite weak but I followed gpory photograph we have. Also Robs and Mr. Mjelde plan helped me a lot with braces. As well as EdT. I didnt compare others. green arrow is Main royal brace and blue arrow poins to main topgalland yard. Violet poijt to fore royal and yellow to fore topgallant.
White arrows are for mizzen yards braces  heading forward being manned abaft main mast.
2. preparations.
Various blocks had to be installed beforehand to recieve brace leads.
E.g. for nlmain togallant yard there are two lead blocks under crosstree andcthere us yet missing block anaft mast at stay that woupd lead brace downwards. one side of  purchase blocks are tied to forestay and another will come from yard.
here we can see it secured. orqnge arrows shows oje aide of purchase tied to forestay then purchase and free side of rope goes into leadblock under the crosstree and down ...
lanyard than goes down thru brace block at corresponfing backstay and ends at main rail p&s.
on its way it copy backstay line just goes under, and it should go thru hole at crosstree. I dont javd such hole at crosstrees so I mafe small eye to bring it closer to backstay. ....
here we can see leading block and backstay block. Goal is to bring lanyard abaft mast so it wont interfere with yard when hauled uo ..
here are all three brqces heading to rail at mizzen mast.
Now. Back side or fiferail  of main mast is quite busy as it receives braces from mizen mast. ....
these are managed thru double blocks at capstay, anf under crosstree of main mast.
red arrows point to blockscat main mast top  receiving mizzen lower yard purchase.
all lijes goes diwn to back side of main fiferail where theybare pinned.
its all full now at this point. ...
what else should be added now. I already received bigger boocks for remained three yards down which are manned quite differently so I look forward to it. Yes enda is near but there is still a lot of small works and cleanups. :)
funally this us enjoyable part but its challenging sometimes run thread thru hole. Tweezers and hand drill are my maij tolls now.
I will add few hopefully interesting pics I tried to take from rather unique and interesting angles from person view sky up from the deck as being at real shipm irs full of lines but there is i hooe brautifull symmetry to all that at p&s side.
Thank you very much for looking in. I dont post that often and there wil be orobably two or three more posts before im done. its been 4 yeads now folks..:)))
IMG_20231201_205946.thumb.jpg.a0512ebc427d5ca9c967e4a6ebff7777.jpgIMG_20231201_205834.thumb.jpg.265bdc6e4a9d9280b654973dcf70dcc1.jpg
IMG_20231201_191357.thumb.jpg.c0c1595ea6a483c069169e1f271bce45.jpgIMG_20231201_191335.thumb.jpg.a2237425f65513b203df84f171297686.jpg
IMG_20231201_191321.thumb.jpg.cb9cb30d4ff61c8ee583a0a1a2391986.jpgže ich by miIMG_20231201_191216.thumb.jpg.847bbab024205059994066956f28e711.jpg
end :)
Mizzen mast yards braces are done. Hooray.  only 12 more to go.
Main mast top & cap are getting crowded as 3 pairs of braces added. low upper topsail yards are crojack.
red arrow are biggest single blocks for crojqck under top andgreen abaft top are smaller for lower topsail.
now all braces up. cap is raking double block for upper topsail yard braces as they ate purchased with whip so lose end is tied to mizzen topgallant forestay and thru purcjase to double block and down to rail.
niw its full down.
overall pics. spider net :). IMG_20231203_144725.thumb.jpg.f6b713b83c849fb20209b0cae60fbd0b.jpgIMG_20231203_145104.thumb.jpg.7224da2730396d9854ce98f6d14bb951.jpgIMG_20231203_144704.thumb.jpg.95126db9903758f53ef767c50591f7c0.jpgIMG_20231203_144815.thumb.jpg.daaefcf1a69fd0719225e36782914dfd.jpg
now mizzen yards stand shipshape in one line ....although i have to redo topgallant footrope that went loose.
After this phase I will skip again as there is place for hands and tweezer to do small cleanups and important things like attaching ends of ropes to fiferails, installing some rope at deck and attaching lower mast sheet blocks...
before last braces.
thanks much for any comment till then.
V.
add
Rigging completed.
Braces are completed.
I cant quite believe all rigging is behind me.
ouch.
There will be one more last chapter, rudder and flag from here. What a relief.
few pics from tidying up fife rails. . . thank you all for looking in,  etc
IMG_20231211_171413.thumb.jpg.b1795bd79fc70cfceec0c4c12d401639.jpgIMG_20231211_192615.thumb.jpg.84fa45adfe92c4c5c056b5fcc3d8a4c2.jpgIMG_20231211_190854.thumb.jpg.9683d1929dc951ae99408ff46982e46e.jpgIMG_20231211_180142.thumb.jpg.8d5df3d12e6293c5768b6f2fd6ea50a9.jpgIMG_20231211_174431.thumb.jpg.aabacc110865a5e89404b08691e9593a.jpg
. braces continue...overal forward pic
foreyards braces
down: standingend of lower topsail brace shown at the front of the top tied to eye.
whip detail.
detail at yard.
down: blue arrow upper top brace - standing end goew toain topmast sray
red arrow lower top brace - standing pend goes to top of main mast
green arrow - lower mast
all three heading  to bulwark front of main mast shrouds....
foremast lower & topsail braces end blocks  at bulwark ...
down: inside look ....
Main mast yards braces ....
Lower yard ends up like this here...
all three braces - arrows point at whip joining single end going from yard. uoper topsail & lower topsail& lower brqce
lowef &upper topyard brqces end up at the front end blocks of mizzen channels leading rope over bulwark into main rail p&s.
among blocks there are two standing ends tied to eye. ( lower & lower topsail- upper tops. is tied to top )
main mast topsail  yards blocks end up at mizzen  channel p&s leading rope over bulwark into main channel p&s.
two whip details.
add
She is looking very nice Vlad.  What have you considered to do with her when she is complete?  build a case..?  Put her in a place of honor in your home?
Rob
Current build:
Finished build:
Rob
Thanks much Rob.
You know I was thinking.
I want to build nice case but she is not completed yet. I dont wish to keep her. I was not building her with that purpose in mind. I  dont think she belongs to me here, I never kept any model I bulit so far. I dont have this posession goal, never have. when im over I pass things on and go to another work. I learnt a crazy lot on  vesides, there has been substantial research.. its american ship. I guess even if i never built american ship I did quite a bit for americas maritime history even building this vessel. So I will try to pass her on to whomever wherever possible .... :) ...its probably closest as it ever gets to original McKays...thanks to You, Richard, Druxey, Michael Mjelde, and more.....I dont want to spare anyone. Working and learning together with You guys on her was for me far more valuable experience  than model itself. Mind you, I like looking at her very much. I gave her my best. :))) Id like she end up in usa somehow, or Australia, where she had its routes and history as well... so could be seen by people... but it doesnt depend on me at the slightest...just thinking and dreaming loud...or i could sell jer for laughable fraction of effort to buy another mode... etc.... who knows :)))
add
Looks great Vlad, nice job on the rigging.  So, if you wish hard enough, or leave the appropriate enticement, the Christmas elves may find time out of Santaa's workshop to finish it for you ;) :)
cheers
Pat
cheers
Pat
haha , lets hope :))  Appreciated Pat.
will let you know after holidays ;)
I put no faith in the little ones...accomplishing any real work un beknownst to me.  Thus far, they have been a dismal disappointment.  I've left my Clipper Donald McKay build sitting, clearly exposed, on my work bench...and not one attempt has been made to progress its construction.  I even left treats.
I'm looking forward to your completion images.
Rob
Current build:
Finished build:
Looking spectacular Vlad! An amazing achievement!
Regards,
George
End.
ride is over folks :)new year new projects.I cant believe that after 3 years, its concluded. I wont post many pics as everything is in log.
I just wish to thank among all others who were looking into this build Rob and Rich,  without whom would this never materialised.
That collaboration holds special place in my inner side, and brought me quite a eeal of satisfaction and joy. hanks everyone and be inforemed that if you want you can look into my new build of my first period advanced attempt. french frigate.
peacefull 2024 to eveyone.
Id like ti change topic header to FINISHED but cant see how. probably android phone not showing all buttons ...anyway...cheers everyone.
IMG_20240102_120706.thumb.jpg.35fd6fa4205e8f43dbf7b493de9bcee1.jpgIMG_20240102_114422.thumb.jpg.959fdd452b96fc29d97b0fe7abd21d31.jpgIMG_20240102_112705.thumb.jpg.bca1908e8a272a9d9aa901e800e42c44.jpgIMG_20240102_114446.thumb.jpg.41a2ef71db016c32cd58804248a6db6c.jpgIMG_20240102_120556.thumb.jpg.2a3a354d10bd720c20c19dbc4f9cc4e9.jpg
add
You have to use the edit option in post #1. I'll cover this one for you. Congratulations on your fantastic model!
  A  masterpiece !  ... a fine example of true "Museum Quality".  I think she'd be a fine acquisition for a Nautical Museum.  I'll pick my jaw off the floor and only dream of emulating your skill and craftsmanship.
Congrats Vladimir,
a wonderful model, you can be proud of. It certainly will be very inspiring and also a benchmark for other clipper fans...
Nils
Current builds
-Lightship Elbe 1
Completed
1 hour ago, Chuck said:
Really beautiful model!!  It may have taken a while but the results speak volumes.   Well done.
Thank you folks. many of it certainly is part of your supervision under winchelsea aprenticing learning project. :))  as well as  part of learning to be humble and to use tighter tolerances.:) many thanks ;) V.
Congratulations Vladimir.  I have very much enjoyed following your build, especially watching you overcome the hurdles you met along the way.  That is a very nicely detailed, cleanly finished model.  You should be proud of your efforts on this one.
cheers
Pat
cheers
Pat
Thank you Pat and everyone. Youve been great help and support along.
Vladimir, congratulations on finishing Glory of the Seas. Beautifully done! Completing such a project must be like watching an old friend leave town. Looking forward to your next build.
Best Regards……..Paul
