HMS Pegasus 1776 by Mirabell61 - FINISHED - scale 1:64 - 16-gun sloop
Have to do the first two and the last two gunport doors, will try to get the hinges functional working...., here first try (the 1 mm round bar shall be cut to fit later on)
the small parts from the etched sheet are soldered to the 1 x 2 mm Tube, then cut off...
here also the Counter hinge part that goes to the hull above the gunport, the small Pivot rod is 1 mm
will AC glue the Long hinge parts to the gunport door (have to do the doors first and fit them in...)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Share on other sites
the first of the four gunport doors is attached, functional with hinges
I let the Pivot rod go through both hinges, this gives more stability to the function, although I was intending to cutawy the rod in the middle space
here open...
In one of Danny`s last Posts (Vulture 1:48) he mentioned the scuppers for the Manager pit. I had not been Aware that there had to be some although it`s quite Logical to catch the dirt and mud on the anchor cable behind the hawse hole, and for rinsing reasons.
I set the brass tube scuppers in about 5 degree declining downward from Managing pit (deck) to the upper Portion of the wale, above that Little decor
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Build log part 33
here the Messenger cable (dummy Black) goes round the front Posts in the bow
continuing with the functional gunport lids, here the last one on starboard
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Shes looking great Nils, the stove is a really nice contrast.  I love the feeling of depth that you are acheiving by leaving some of the decking open, especially some of the earlier photos showing the view onto the hold throught he main hatch.
Cheers,
Jason
In the shipyard:
Link to comment
Thank you very much Jason,
I like your comments and thanks for following this build. I have`nt looked into the Amati plan for some time now, because I get so much Inspiration from builds of other members, and then there are so many ideas I would like to intigrate and that are not shown on the plan. I wish you much pleausure with your own HMS Snake model, it is a fine built vessel
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
really looking very nice Nils.......I like the idea of the movable gun lids.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Popeye,
due to the fact that there are only 4 gunlids shown on the plan and therefore done, it was not much extra effort to make them moveable, it was a bit tricky in soldering those mini-hinges
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you B.E.
I`m hesitating for putting on the quarter deck and the forcastle deck because the guns underneath, as well as the anchor rigging would have to be installed permanently before. I think I`ll do the anchor- messenger rigging next, when I get the appropriate ordered ropes. Also the upper bulwark portions of the welldeck and the swivel gunposts Need some attention
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Who knows ?
here rises the question...
the downleading stairway (not shown here yet) from the Quarterdeck will be landing between capstan and the next downward starcase, interferes full with the gundeck capstan, if it should be operated with 360 ° turn.
does the Quarterdeck stair have to be fitted moveable with hinges, for instance to be hauled up against the Quarterdeck from beneath, to allow full capstan operation ?
Nils
The downward stairs from the Quarterdeck interferes full with the capstan Operation....
Current builds
-Lightship Elbe 1
Completed
Link to comment
the more I see....the deeper in awe I get!   truly awesome work!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Popeye
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils, according to the ffm the capstan bars were 8' long = 38mm at scale, and when in use gratings would cover the hatchways. I think the Quarterdeck ladder would be removed when the capstan was in operation, I doubt there was room to swing it up beneath the deck beams.
B.E.
Thank you B.E.
for your explain on ladder a capstan. I was a Little bit between the Options of putting on the Quarterdeck ladder, or Fitting the gundeck capstan spars, so theat These could be visible through the Quarterdeck outcuts from above.
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Build log part 34
concentrating on the Quarterdeck
the deckbeams arecready to take on the deck
the uncolored figure is 25 mm hight...
the painted figure is 28mm hight
the cutaway of the Quarterdeck allows sight to the inside
gratings, capstan, Skylight housing and deckframe for ladder added
Build log part 35 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Setting the tiller for steering either for Manual direct, or for steering with tackle rope and wheel. In raw shaped condition, Needs to be fine tuned...
here the tiller parts
tiller mounted to the Fitting socket
tiller upwards curve for Manual steering
or in downwards mode for rope steering (via blocks and wheel)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
some more pics for the steering....
acc. to plan and etch parts the wheel is soldered together from 5 individual parts plus drum and shim disc at the aft side
tiller shortend a bit and eyelets for the Tackling set
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
very nice Nils........I like that tiller socket.....nicely done.   very nice ship's wheel assembly  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Popeye,
there are so many of These small deck Fittings to be done, I am trying to get the binnacle cabinet assembled and completed today. All the Fittings go in row and there is hardly space to get all in line.
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
I can relate to that  ;)   bet the cabinet looks sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
a Little update for the Quarterdeck..
Little binnacle cabinet
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
thank you Popeye.
Bob, thanks for your words,
i can only give back the compliments for your beautiful Essex build
Thanks Crackers,
we can be thankful that today we can get all sorts of chilled Drinks on board a ship...
Nils
Here a short update on the assembly Arrangement..
I am thinking of doing some structuring to the raw swivel gunposts
would have to tacle guns and anchor cables, all that goes underneath the Quarterdeck before putting it on permanently, am always a bit anxious that something could be forgotten to Mount as Long as there is Access there
would now Need to get the forecastle assembly Status to the same Level..
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nice words Tom, thank you,
I`m glad you like the arrangement
the Quarterdeck will be permanently attached when all the Fitting out below is done. Otherwise I would have to spend more Details on the cabins Fitting out below, like furniture, etc. But the outcut of the deck always allows a look into the ship from the outside.
BTW I am curious to the keellaying of your "Le Gros Ventre" Project, sounds very interesting
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
the swivel gunposts are shaped octogonal in the upper post-portions and the Ends secured with a metal ring.
The guns still Need to get handles to operate...
the metal gunpost rings shall sit slightly above the roughtree rail when it is mounted
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Beautiful work Nils, I like the tiller socket . The detail work is fantastic, great job
Best Regards,
Pete
Edited by pete48
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Thanks for dropping in Pete,
and for your comment
the solution with the tiller socket was just an idea when I thought of how to avoid a weakening the rudderpost, together with the squaretube that goes around it
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
It looks realy good , and a great Idea to make it work and still be asthetically pleasing to the eye
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Build log part 36
gunposts still raw shaped...
additional pillars beneath the Quarterdeck beams, and gunposts octogonal, with metal collar.rings, as well as Center hole to take up gun-brackets
swivel gun prototype mounted. the rail shown here give riged reinforcement to the gunposts in opposite to the (later to be mounted) roughtree rails, that Need good support
prefitting anchors (Position check) on the foremast cannels
view aftwards beneath the Quarterdeck ( four new pillars fitted)
view beneath the forecastle
Build log part 37 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
