Dear Gary, I'm very glad to read your messages again, it's such a pleasure to talk to my colleagues and such outstanding Maitres as You are. I'm very grateful for Your attention,  comments and advises. My best regards,  Alexander
 Kortes, beautiful planking. Happy New Year.
On 12/31/2021 at 11:48 AM, Rudolf said:
IFf I may ask, how did you manage to make the planking seams just visible ?
Greetings dear Rudolf I have learned this from an excellent Maitre Dmitriy Shevelev. In order to highlight the joints, I used, just like Dimitriy, a dull needle, and afterwards, on advise of my friend with much experience in this field, i worked on            the joints using a small triangular broach file. But there's one nuance. Before putting the covering I took away a small bevel from the edges of the upper part of each plank. The most important is not to let the glue get on the end face of the plank during the plating .
My best regards
 Kortes, my heart goes out to you and your countrymen. I pray this madness ceases immediately, may God protect you and yours.
У меня был перерыв в строительстве по разным причинам. я жду
вдохновение, чтобы сделать корпус и палубу гвоздями. А пока я решил поработать над элементами палубы. Пока я сделал только деревянные элементы.
Металлические детали пока не делал, сделаю отдельно, потом доделаю, до установки на место.
Edited by KORTES
 Nice to see a post of your usual beautiful work.
 What a neat little piece, Kortes. Both functional and beautiful.
