Evening! So I decided another small built is in order. I wanted to be thematic to the history of my hometown. The plan was of a diorama of a venetian galley exiting the port of Chania, circa 1640. 1/700 was very small, so I went for around 1/350. I used the plans of "La Dracene 1675" although I mixed and matched other earlier plans I had, after all, the waterline hull at 1/350 left little room for specific details. In any case, the galley was of the heavy 2 masted version or "Capitana" Unfortunately I ommited photographing many steps of the built. Also, although the ship it self is basically finished, I revised my initial plan to have it exiting the port, and quickly built a simpler sea-base. So technically it is not finished yet, as the original plan is still feasible.
The lower hull was easy enough, considering it is only a waterline model, and the galley has very little freeboard. It will be recessed into the base, and so only 2-3 milimiters of freeboard for the model. As for the materials, it is made mostly with card and thin plastic strips. I used my usual method for decking, drew planks in the PC, printed them in A4 black and white, and painted them. First with acrylics then with a coat of matte enamel.
Edited by GeorgeKapas
Here is how the deck initially looked, although I made it again a bit later to correct the warping. I guess the photos of the built are limited...
Here was the original plan for the base. It is still possible to do it, but for now I use a simpler version. It would have the fort to one side, the lighthouse on the other, and a chain, lowered, for the galley to pass.
Making 60 oars in 1/350 was not a pleasant process that is for sure. Here is with some test-masts that were later replaced with proper ones.
I was not happy with the central gangway and remade it. The bow superstructure was also finished here, as well as the stern deck and awning supports. The masts are now properly done. Unfortunately I took few photos from this stage to the finish...
As for the sails, I did a lot of tests... in the end, I used A4, drew the lines with pencil, and glued some strips of additional A4 on the edges and in the midle. Then it was painted with acrylics and coated with matte enamel varnish, just like the deck. The edge was lined with black thread.
Unfortunatelly this was the last photo before the "finished" ship or at least the current state of the diorama. I made a simple base with only sea. The rigging is seen almost finished. I used thread and melted spruce as well, especially in the deadeyes, which were also made from scratch. The guns are from my stash.
Beautiful work, especially at that scale!  Can't imagine trying to make those oars.  We've been to Chania and I remember lunching at one of the restaurants opposite the lighthouse on the breakwater. Lovely city and we had a great time on Crete!
<edit>  ps Also got up at the crack of dawn in Chania to go on the Samaria Gorge hike. Memorable experience too.
Edited by Ian_Grant
So for a test built it went fair enough. Many firsts for me, and many back and forths. A lot of improvement happened, and as usual, the next built will improve on the previous one. Here is on my hand for scale. I may revisit the thread if I make a new base as originally planed.
Beautiful work and result.
12 hours ago, amateur said:
That is a nice little model.
I know it is asking for the impossible, but in a diorama-setting, did you consider making 200 (?) oarsmen? From the foam in the sea you can see some rowing is going on, but the benches are empty...
Jan
300 oarsmen in fact  I dont know how I can do such a  thing without looking terrible, and without taking too much time..
300, even worse ....
No, I also haven't a clue how to do so many men at such a small scale.
I knew I was asking for something impossible :)
Btw, I like the sea surface. How did you do that? Paper, plaster, putty?
Jan
Perhaps each bench to be a single paper cutout of 5 men from the waist up? Their arms might be formed from notches to the paper bent at a 90 degree. I didn't like some tests of this though. But this reduces the pieces to be made to 60 "groups". In any case, I will have to return to her sooner or later, with the original base plan. Yes , the sea is soft paper with woodglue, painted with acrylics. This time I ommited glossing it, and it does look better more matte at this scale.
Congratulation George!
Excellent craftsmanship and  a very beautiful work...icon_exclaim.gif.3238a13901e299562ec7dc86fa5b5963.gif
Thx
