5 hours ago, toms10 said:
Now I just have to do it 29 more times!!!  These boats are going to end up taking just as long as the Morgan itself!😂
Tom, You know all the time is worth it. Your whaleboats are absolutely mind blowing. Beautiful work. 👍
Edited by John Ruy
I got the appropriate number of colored bands on the appropriate oars so there will be no confusion when Moby appears on the horizon. 😜
Now I need to make a bunch of harpoons, paddles and oar locks and then finally the mast tabernacle, mast and furled sail.
Tom
I have been off from work this week so I am putting a bit of time in the shipyard.  I managed to make the 10 lances for the boats. Originally, I was going to just take a piece of wire and stick it into a wooden handle. I fiddled around a bit and managed to come up with a way to make them as a single piece with a barb from a toothpick. The handle is .040” in diameter and the iron is .025.  They are 1.50” length overall.
I just noticed the one on the right end has a slightly longer iron shank. If we run across an extra fat whale we can use that lance. 🐳😂😜
Tom
Tom
Are the oars different lengths depending on where used on the boat?
Tom
Your small flotilla of Moby Dick chasing whaleboats look great, Good Job!
Don't forget the tholes on the boats (oarlocks).
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Tom
Hi Tom
you are correct
Tom
Hi Ron
Thanks for the compliment. Yeah, oarlocks are on the list. Probably going to do some micro-brazing to make those.  I need to think about those a bit. I just finished making 35 lances.  Lookout Moby I’m coming for you. 😂😜🤪
Tom
Finished making all the whaleboat components and started putting it all together.  There is a lot of stuff in these little boats!  I spent way more time than I guessed I would on these but I think they came out pretty good. 😁
I’ll finish up the other three and put them away for safe keeping until the end when I mount them to the Morgan. Now I can get back to working on the Morgan herself.
Tom
Makes you wonder at how six guys could jump on top of all that stuff in a pitching sea and get sorted and shoved off from the ship, and still be able to successfully chase a whale.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
  • 5 weeks later...
Summer has been busy but I managed to get in a bit of rigging anyway. The fore and main top masts are in and shrouds are rigged.
Also started on the bow sprit rigging. I finally got to use some of the super fine chain I made a while back. I think it does the job nicely at this scale.
I am having fun with the rigging but I keep wishing I was back Sandals Southcoast in Jamaica. Maybe when I finish this ship I will sail her back there. 😜😂🤪
Tom
I reached the standing rigging completion milestone. Well sort of. All the lines are attached but most of the back stays are not secured. This will give me a bit more room to get to the belaying pins.
There are a lot of lines hanging from the blocks under the tops and trees  all coiled up and labeled. It is much easier to thread the blocks when the masts are off the model. It gets a bit scary looking now but since each line is labeled it is actually pretty easy.
I also finished all the rigging on the bow sprit (I think).  Time to start thinking about the jib sails.
And finally I put in the cutting tackle today.
Next I need to start making and mounting sails to the yardarms. Then mount those to the masts. Should be a piece of cake!😂
Tom
It’s been a while since I posted anything. I have managed to get some things done such as all the yards. I needed to take a couple of weeks to make 21 table centerpieces, 80 place card holders for table assignments, and a bride and groom’s table centerpiece for my daughter’s wedding in January. Why did I agree to doing all these things? Oh yeah, I have a hard time saying no to my daughters. Between cutting down birch trees and getting pine cones and everything else I didn’t think I would see my Morgan model ever again.
Now that wedding stuff is complete, I’m back to modeling. Currently working on laying out the sails so I can attach to the yards and then install those assemblies to the masts.
Here are some pics of my various projects.
IMG_2983.thumb.jpeg.206369f6b9e3c89247a3e125b3d6af97.jpegand finally the newlywed table centerpiece.
Tom
Edited by toms10
Rearranged pics
1 hour ago, TBlack said:
Tom,
You aren't the only one who can't say no to daughters. Besides, your work on those items is spot on; now all you have to do is walk her down the aisle!
Tom
Hi Tom
Somehow I think there is going to be more coming than just a walk. There’s always more. 😂
Tom
On 11/9/2023 at 12:39 PM, toms10 said:
Hi Tom
Tom
Tom,
I have two daughters; and it is true there will be more, but it will be fun for you. Remember that she will have a husband, but you will always be THE DAD!
Finished up the silkspan sails except for the main and for courses. Those two will be at least partially if not fully furled so as not to obscure the deck details.
I used 3 layers of 00 (fine) silkspan which I believe is the thinnest. It measures about .002” thick. The center ply has lines drawn with a 3H pencil to simulate the cloth seams. The outer two layers  are painted with Liquitex spray paint (unbleached titanium). I sprayed one side of the center ply with ordinary spray adhesive and applied a painted piece to either the starboard side of the staysails or the aft side of a square sail then rolled it flat with a wallpaper roller. I then trimmed the painted ply to match the center ply.
For the other side, I repeated the process except when trimming the excess, I left .060” all around. This excess flap will wrap over and hide a .010” copper wire that will be used to form the billowing shape. Just an ordinary fabric glue or 50/50 white glue works.
I then glued all the various tablings using Liquitex matte medium.   Aft we all was done i went over the sail with a warm iron to flatten.
Bolt ropes are then glued to the edges using fabric glue.
I believe my build log for the Leopard has a more detailed explanation for making these sails. The only difference is the center ply on the Leopard is regular 20# copier paper. With this project at 1:96 scale, i wanted to make the sails as thin as possible to keep somewhat to scale. That is why I used silkspan for the center ply this time.
I guess the next step is to bend the sails to their respective yards, then mount the yards.
Happy Thanksgiving to my modeling friends in the US. Those outside the US have a great day as well.
Happy modeling,
Tom
Managed to get all the sails except for the main and fore course sails bent to their respective yards. Also made some gaskets and hung those from the jackstays just for some added detail.
Here are pics of the fore sails.
and a close up of one of the gaskets.
Still have to do all the hanks on the stay sails and bend the top gaff and spanker sails to their yards. Seems like their is always something else to do when working with sails.
Tom
Hi John
From what I read, I guess early on they used to carry the gasket ropes up with them when furling sails. I guess somebody got smart and just left them tied to either the yard or jackstay if there was one.
Tom
10 minutes ago, toms10 said:
Hi John
Tom
Thanks Tom,
I had a suspicion that’s what they were. The detail is great. I also like your sails, I am certainly going to try silk span when I get to some smaller scale. I’ll check out your process in your Leopard build log.
John
Managed to get all the lower rat lines
or should I say “rat slats” since these are wooden. The upper ones will be rope so I see many clove hitches in my future. 🤪😜. Actually at 1:96 scale, I think I will do some test lines to see if the knots will look too bulky. The rats will be done with .005” diameter thread to maintain scale but I don't want the knots to be the dominant feature.
The picture is a bit cluttered in the background and there are coils of rope with labels hanging everywhere but you get the idea. 😁
Tom
Do you just use excess line all coiled up?  I’ve been thinking it should be easier to do the blocks under the tops before installing the masts, but I’ve never done it before…
13 hours ago, John Ruy said:
Tom,
Nice job on those battens. They make for really neat Shrouds, but are certainly a Pain to tie. Did you glue yours in place or cross tie each one?
Hi John
They are glued in place. I may cross tie them later just for appearance.
Tom
Hi Brian,
I just cut off enough line to get from where the line starts to where it gets tied off and then add about another 1 1/2” for tying off to the belaying pin.
One end is usually fixed to a block or eye, then run through whatever blocks are hanging under the tops, trees, etc. the loose end is just coiled up by wrapping it around my finger and then putting a small strip of the sticky note pad paper around it to kind of keep things organized. I also write down what line it is on the paper so I don’t have to go back and retrace which line is which.
Tom
On 12/11/2023 at 12:03 PM, toms10 said:
Hi John
Tom
John,
I ended up cross tying the battens just for appearance. I think the knot adds a bit of realism instead of just a flat intersection of the batten and the shroud. The port side is complete!  Only another 268 more to go on the starboard side but who is counting! 😂
Hope everyone has a great holiday season. 😁
Tom
