More enjoyable work has been completed. I’ve dressed the nails on the port side and applied a coat of WOP. I also made and attached the fixed block on the stem. And last but not least, the rudder has been shaped and made the tiller. I’m probably going to make another tiller as I’m not happy with this one.
Best Regards …. Rick
Thank you All, for the likes! Much appreciated!
Question for the group. I’m very close to starting the sticks and strings, and I want to serve the shrouds as I have Chuck’s serving machine. What size and color thread have you guys used for serving? I’ve been reading the build logs but haven’t seen much on the subject other the lines being served. Thanks for the help!
Edited by Freebird
Finally got to spend some quality time in the shipyard today and I again did something I’ve never done before. I made the main mast, bowsprit, the boom and the gaff. I had a lot of apprehension getting started, I followed Chuck’s instructions after some very slow and thoughtful carving and turning on a small lathe, I had 3 of the 4 parts made. They actually came out pretty good. The mast was a different story as the lathe couldn’t accommodate the mast’s length. So it was time look at other logs for ideas and I found a couple that used a clamped hand drill. I have a B&D Workmate to secure the drill with the help of a few blocks of wood I had. To secure the the opposite end of the mast, I removed the tail stock from the lathe and clamped it at an angle to the end of my workbench to match the angle of the drill. The jig setup worked very well. All have a coat of WOP and need to be painted and need to make the various fittings. This model has been a lot of fun and has really built up my skills.
Edited by Freebird
Wow, nice work.  The rigging part was an enjoyable part of the build.  It really changes the look of your model.
Ryland
               - Nautical Research Guild
Ryland, thank you for the accolades! I refer to your Medway log often, lots of great info for this newbie. Rigging is again, something I’ve never attempted, but looking forward to learning the ropes (pun intended). I’ve throughly enjoyed this build, Chuck has done an outstanding job designing and explaining how to create a beautiful model. Cheerful is on deck and then Winnie. I think I have a problem….
Edited by Freebird
Spent some time seeing what my options were for making the mast cutout smaller in the thwart smaller in diameter so the mast would fit better. I managed to bend some yellow cedar to fit the mast cutout but I didn’t like the way it looked. So I decided to make a new thwart with a smaller cutout. One thing I learned many years ago was to never toss out the die cut sheets the same parts came in just in case you need to make replacement parts. That sage advice served me well today. All I needed was 1/16” and 1/32” sheet to make the parts. Fortunately, Chuck provides some spare wood on his laser-cut sheets. It was a simple exercise to trace the shapes and cut out and sand to shape.  Now I just need to remake the iron work again.
Edited by Freebird
I also decided today to finish the rudder. I painted the red and added the friezes. One thing I know about my skills is that I can’t cut something as small as these designs without having some rough lines. While I managed to cut out some that were satisfactory, I wasn’t entirely happy with them. As I sat and looked at them, I wondered if I could gently sand the edges smooth with some new 400 wet/dry sandpaper. I found it’s possible and the result was totally worth the effort. I held the frieze right near the edge and used a very light touch so the edge wouldn’t roll over. In the pictures below, the 2 middle ones are edge sanded. When done, I used a blue pencil that matched the base color and gently ran it on the exposed white edge. Results were excellent. Amazing what a little effort can accomplish.
Edited by Freebird
Nice tip.  I am almost at that stage and will do the same thing.
Deconstruction, and reconstruction has been completed. Mast thwart and iron work had to be remade to accommodate the thinner diameter mast. Many Thanks Chuck for the brass, much appreciated!
Edited by Freebird
When working on a project, I like to have everything possible ready to go. So today, I made the deadeyes using Chuck’s kit. They were easy to glue together and to shape. I remember seeing a post from a MSW build log (sorry I don’t remember who’s idea it was), on how to shape the deadeyes. It worked pretty well. You need a dowel, self adhesive sandpaper, a scrap block of wood and some T-pins. I drilled some shallow indents in the wood that were a little larger in diameter than the deadeye. The deadeye is secured to the dowel using 3 pins that are pushed into the end of the dowel. The pins reside just below the surface of the deadeye. I marked one pin for the bottom hole in the deadeye so the deadeye is always positioned the same. Now place the self-adhesive sandpaper over the indent and push it into the indent. With the deadeye secured on the dowel, twist the dowel and being the sandpaper has a radius from the indent, you get a pretty good rounded deadeye. See pictures.
This build for me has been a journey of many firsts, and I’ve enjoyed every step of the way. I’m almost ready to start with the rigging, another path I’ve never been down. I’d like to start with stropping the blocks, and I’ve made some acceptable hooks and a couple of thimbles. Can anybody point me to a good tutorial on how to strop these blocks? As always, thanks for the likes and help!
Nice work, learning new techniques and doing things for the first time is a fun adventure. I had one after another building Cheerful, all of which came in handy with my current work on Winchelsea. Enjoy the journey.
Regards,
Glenn
Current Build: HM Flirt
Thanks guys, much appreciate the encouragement!
Glenn, Cheerful is next on deck and I have studied your build extensively, lots of great info in your log. And as you know, there’s a lot of other great Cheerful build logs, I can’t wait to get started! Like you, my Cheerful build is a stepping stone to to my Winnie patiently waiting.
Finished up the boom and gaff rigging. Overall, not too bad, l’m pleased. Question though, what glue do you guys use to secure knots and seizings? I’m not happy with using CA as it darkens the tan and how it makes the rigging so hard. Any and all comments and suggestions are welcome!
Chuck, thank you for the info! I’ll give that a try. Does the rigging look correct so far?
Winnie, yup! But first I’ll build (and start a log), Cheerful. I need to build more skills before tackling her, I have to do her justice!
Been  jumping around a little and this morning I tried my Servo-o-Matic. I served one of the shrouds and I was surprised how easy it was. One problem was that the excess line got very tangled. How do you get around this issue? Sorry, no pictures of the mess.
This morning I wanted to start on the shrouds, however I realized that installing the Thole pins would become problematic with the shrouds installed. So this morning became thole pin morning. I turned more than I needed and used the best from the batch. I remember in Ryland’s log that he made a little guide for consistent spacing for drilling the holes in the cap rail. It is a great idea and made for an easier task. Thanks Ryland! I also made a small guide to go over the pins to get a consistent height. It is no more than a piece of 3/16” thick ply with the pin spacing. I left the pins a little on the long side so I could clip them and then sand them flush with the top of the guide. It worked really well.
Thanks to All for stopping by and all the likes, I really appreciate it!
Edited by Freebird
Here’s another oops that I need to fix. One set of thole pins on the starboard side are out of position. The strap covers the forward pin, an oar wouldn’t be able to be used. So the front pin will need to be removed and placed behind the rear pin.
