P-51 B/C by Egilman - FINISHED - Revell - 1/32nd scale - Rub n Buff finish test build; Experiment Completed
Ok my friends... Not going to go into a lot about this airplane.. It is my first attempt to build a Bare Metal Bird using the techniques needed for applying Rub n Buff... I've posted pics of what this material can do for simulated Bare Metal finishes on aircraft models here, and it looks spectacular when done...
The aircraft I'm going to be modeling is P-51B-10 42-106638 - 376FS, 361FG, 8AF, it wore the unit designations codes E9-R named "Impatient Virgin" & E9-B named "EVOI" (with malcom hood conversion) I will be attempting to do her as Impatient Virgin... (I ordered the decals for it) She crashed during the war in a farmers field and was buried as unsalvageable... She was recovered sometime in 2007 and restored... This is what she looks like today...
23635800628_150cfbc0af_o.thumb.jpg.f2e9452789bbcd9e9e0090362e4b524b.jpg010.jpg.79c3f5f01b21bda6e1ff29c085f31a3f.jpgscreenshot_20.png.6c00b4154efaecaa42a40789b0cf04c4.png46000700155_bac63f70db_o.thumb.jpg.c37eb9661887f55bfb1e87f0f2f1cb5e.jpg
This is a fairly decent representation of her aside from her Malcom Hood conversion it looks like the same aircraft... Unfortunately this is close to what she looked like in WWII but not really...
She is painted in aluminum paint.... During WWII she was a typical bare metal fuselage, Olive Drab horizontal top surfaces & anti-glare panel.... She did have invasion stripes but they did not rise above the national insignia nor cross the top of the wing... The bottom of the wing was painted aluminum....  And of course the Nose was insignia yellow... A very nice combination of colors...
Here are some images of her in WWII...
media-29366.thumb.png.6e4fdb5cfddfb39b30eb7618d3f887e4.png2da814a223fb22c36b06fce2e53a7917.jpg.9436d6edf12bfda05eda579b07ebd866.jpgmedia-24749.jpeg.69ddeffc73037010a739f4701d2f4d32.jpeg
You can see the color changes and canopy modification with the designation change....
The kit I'm using for this is...
It's a relatively simple kit only 57 parts of which is a complete Packard-Merlin which has to be installed cause it carries the propeller shaft so the prop can turn... The cockpit is fairly basic using a decal to represent the instrument panel and some side panels that are a little light on the detail, the seat is very basic... So I will be closing up the cockpit...
This is basically going to be a quick build to get to the finishing aspect so I'm not going to get into anymore history on the bird......
The coloration I'm going for is Yellow Nose, Bare Aluminum Fuselage & Tail, Olive Drab on the top of the wings and horizontal stabilizer, and painted aluminum under the wings... Invasion stripes on the bottom only of the fuselage and wings as she was during the war...
This will involve a number of techniques of using Rub n Buff to achieve the effects of bare aluminum and painted aluminum...
I will be doing the details where they will be seen, but I will not be adding any...
So here goes, will be gluing parts in a bit.... (and planning the paint sequence)
EG
Quote:
Same as Ken, it's going to interesting to watch you test your BMF on the Mustang
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank Ken & Ed, I think it's a technique that needs to be put out there...
Well I've been throwing this thing together and to be honest, I've gotten spoiled on more modern kits... This is a '69 kit, a 2019 molding.... The newness of the molding doesn't make the kit any better... {chuckle} But at the time it was the only 1/32nd scale P-51 around... Now being a '69 designed kit, I forgot about rivets, this was the age when they were finally doing away with the humongous raised panel lines and before the humongous recessed panel lines... So, what they did to delineate panels was cast lines of millions of tiny rivets...
I forgot about those... So I have a choice, sand them all off, (which means I'll have to cut all the replacement panel lines) or just go ahead and proceed like they aren't there...
I was reading the Squadron Signal walk around for this, and in the back in the modeling section it tells you what you have to do to build a nice and accurate P-51 B/C out of this kit... Get the Eduard cockpit set, get the old Hasegawa P-51D kit, and break out the surgery tools....  Nah, I'm not putting that much into this one, so I'll go with it like it is....
Well, looking at this pic, they really aren't all that obtrusive, but I wonder how it will effect the laying down of the RnB... I think I'm going to just go for it.... That's what this is, a test...
Tomorrow I've got to go to HL and pick up a can or two of OD for the tops of the wings and horizontal stabilizers, probably another can of the super shiny testors gloss coat for the fuselage... Then at least smooth the joints, I had the dickens of a time pulling the left fuselage half back straight... It's a 1969 designed kit, did I mention that? {chuckle} Brings back memories of when I was a kid....
On the real airplane, those rivets would be sticking up a half an inch...
Oh well, this is the fun of modeling... Learning new things... And it doesn't have to be super accurate, at least it will look like a P-51 B/C...
EG
PS: why do I call it a B/C? because there is only one difference between a B model and a C model... The "B" model was built in Inglewood CA and the "C" model was built in Dallas TX.... That's the only difference between them... Onwards...
Edited by Egilman
Quote:
Thats a great start  - nice and tidy, doesn't look bad for an old kit.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
cool....you can't have enough subjects to test your theories on ;)   especially when most P51's were bare metal to begin with.  good to see you decided to take a walk down Nostalgia road with me  ;)   if you really want to go down the hole.......the Atlantis kits I bought had rivets that you could cut your fingers on :D   as said,  there are plenty of upgrade kits that you can get to spice them up......but they can be aggravating to install.  these are nice kits though....no doubt that you'll do well with her :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Geeze!!! WOW!!! Thanks Brothers for following and all the likes... It's GREATLY appreciated!!!!
It's not too bad OC could have been a lot worse... There is one issue I'm not going to be able to fix cause of the amount of work it would take...
The cowl line, it was either recut the part of try to fair it in, either way it's not going to be right...  I guess that is why they recommend replacing the entire nose with a Hasegawa P-51D nose...
Closeup...
UGLY..
Well I guess I could sand on it for the next two days, filling and sanding, but it will never correct the obviously incorrect profile... Hopefully the OD anti glare panel will hide it some... So, I'll just take this as far as getting it up on it's wheels presentable, looking like an airplane, but, It's not my best work.... Heck it is only an experiment anyways...
But, they are ready for Grey Primer...
The landing gear doors are tacked in place for masking and painting the invasion stripes after priming... White block first, then two black stripes... (on each wing) Then they get gloss coated... (leaving the wing tips in flat primer)
The upper wings are already painted Olive Drab awaiting the fuselage primed and painted...
They will get glossed along with the rest of the parts...
Ok a little knowledge will help explain what I'm going to be doing...
1st the airplane, ALL P-51's had Aluminum painted wings, NO EXCEPTIONS! They ALL did (all 15,000 of them) A P-51 with polished metal wings is not correct... (USAAC specifications for corrosion control) A lot of modelers make that simple mistake... Camouflage was usually painted in the field and at first USAAC spec was OD green over Aircraft Grey, later in the war they dropped the painting requirement when it became clear we were controlling the skies...
They were shiny, hard shell painted and initially waxed but they did wear for a while and seldom were repainted...
The paint job needs to be shiny bare aluminum on the fuselage painted aluminum on the underside of the wings and stabilizers and OD green on top of the Wings and stabilizers...
Now Paul's process is using RnB to do both the bare metal polished aluminum and the aluminum painted surfaces... (although there are plenty of aluminum paints around today that are very very good)
Here is the message Paul wrote outlining his process...
Quote
Good evening everyone
not having sufficient knowledge of the English language, I'm going to talk to you about rub n' buff in French
knowing that in your entourage or through translation on the net, you will manage to understand me much more
easily than if I pass this message through translators who demolish our interpretations a lot!!!!
here are the different ways to use the rub, which correspond to the desired finish;
golden rule: whatever the instrument used, the less you put, the more beautiful the result will be!!!
Passage with a round brush in a swirling motion so as to cover the plastic well, taking care to remove any excess
on the brush with absorbent paper before application, we will obtain a semi-gloss finish and if you are looking
for a duller aluminum, just apply this finish with matte testor varnish.
We can have another finish, aluminum paint this time by replacing the matte varnish with glossy varnish and we
obtain a very nice paint finish without the disadvantages of pigmentation, totally absent in the rub N' buff. To
represent different panels, you can tint the rub n' buff with enamel: the only drawback is that the mixture dries
very quickly and you have to renew these mixtures often...
We obtain a polished aluminum, by passing it to the finger with the index, but there too it is necessary to spread
very little product on the finger at the risk of making over-thicknesses. we pass it by pressing quite strongly so
as to spread the product well and once the product is well spread, it is enough to rub moderately to have this
beautiful polished aluminum.
If you want to make different panels it is essential to mask the brushed or varnished panels because it is almost
impossible to mask the polished finishes ((however, take care to remove the excess adhesive on the tamiya strips
by first applying them to another support, come on, let me tell you a secret (for those who don't know it!!!!) I
apply the Tam band on my forehead and there I have no bad surprise for the application on the model!!!!)
I explained all this many times on forums or exhibitions, but I am quite disappointed to see very few results and
I will put this on the lack of perseverance of the model makers who get discouraged too quickly, because to obtain
a result like the B29 (which I built about fifteen years ago!!!) I started to apply rub n' buff in the early 70s
and still today, I learn everyday how to handle it...
I wish you all good results
Paul Coudyrette
That's it, after three full days searching that's all I could come up with... He did mention how he got the colored bands on his F-100 tails, he uses pastels mixed into the Rub n Buff before he applies it...
He also mentioned that painted sections of the airplane like Anti Glare panels, Invasion Stripes, colored noses and tails, etc...  Are painted on before the RnB is applied and masked off...
So that, like my experiments before is what I'm going to be doing...
Once the primer is dry, I'll be doing the pre-painting of the invasion stripes to match the airplane...
Then we are going to hopefully have some fun... One thing I haven't decided is that I do have some Testors Aluminum plate in Rattle can, it's an absolutely wonderful aluminum paint goes down thin and covers well... I may do the wingtips in that rather than try to replicate aluminum paint with RnB...  It's just easier that way....
Onwards my friends, getting closer..
EG
Edited by Egilman
Quote:
It's definitely a blast from the past brother... Todays models seem to fall together compared to the work that goes into making one of these old designs presentable...
Quote:
Hi Guys, I went ahead and decided to aluminum paint the wing bottom in flat aluminum plate... It's the way the original aircraft was done and allows me to mask off the invasion stripes and rattlecan them before gloss coating it...
I probably should have bought a cheap F-84 to do this with as it was all aluminum but this is to see how RnB works for a realistic representation so that's the focus of this little jaunt... I won't be wasting it on something that can be done easier with a spray can... The fuselage is going to be tricky though cause of the compound curves....
In scale the stripes are 9/16ths inch wide, My debate now is do I do the full round the fuselage stripes or just the bottom of the fuselage as represented after the invasion... (after abut 3 months they started to remove the white invasion stripes as they were no longer needed, they retained the two black stripes so it was easier for the bombers to ID them in the air, the P-51, especially the B/C models resembled the Me-109 so much at a distance in profile that even veteran Luftwaffe pilots would sometimes confuse the two in the air)
We are almost there... Ready to mask the stripes, first a white block to represent the white stripes and then two black stripes over that... Then gloss coat the whole thing... I think by tomorrow we will be rubbin and buffin the fuselage....
Another thing I've decided to do is black out the canopy... This a Revell kit with an operating opening canopy... Of course we all have grown beyond such toy like features today but in these older kits we have to deal with a lot of that... The canopy has huge lumps on the inside to function as the "hinges" for the opening panels, the only way to eliminate them is to grind them off and polish out the resulting damage... I'm not going to do that and so they are minimized as much as possible, the only option is to black it out...
Cruisin now... these older designed models go pretty fast once you figure out the build sequence...
Onwards...
Edited by Egilman
Quote:
The cowl bump on the nose is huge. Looks like the noses of some Me-109Gs.  Best of luck hiding it with anti-glare green.
Model on...
Ken
Started: MS Bounty Longboat,
Model on...
Yep it is fug UGLY for sure.. but I decided I could at least afford it a bit more rough work, so I ground some of it down... I used Mr Surfacer 500 to fill the gap and spread out a base to work on.... I then sanded the edge into a gentle curve kinda matching the cowl curve... Then spread a bit of Testors surface putty over that with a hard plastic edge...
About to give it a final sanding and another shot of Tamiya fine primer... It's going to look a lot better, (smoother) but still inaccurate...
Thanks brother, something about it didn't sit well.... (and I had to fix it)
EG
Quote:
When I built this kit as a kid, it looked awesome cool. It was the first 1/32 kit for me and the first that I completely brush painted (RAF grey/green camouflage with invasion stripes). Now of course it looks different. Nevertheless, it is going to be an interesting experiment and a trip down memory lane.
Looking forward to seeing more, 👍
Dan
Dan
Thanks Dan, yeah it's a trip down the lane alright, I forgot how hard it is to mask when you have rivets all over the place... I think I'm gonna pick up a Hase or Dragon "D" model to do one up right for the shelf...
I'm thanking god this one was relatively cheap.. {chuckle}
Quote:
Well an update...
Masking rivets... Well the invasion stripes are painted off...
IMG_0038.thumb.JPG.5843a5e81b4c61c14b3daf8a174a84b6.JPGIMG_0039.thumb.JPG.10c1c11849b0b26e1aba3770457948dc.JPGIMG_0040.thumb.JPG.8e20f7263e9cb83b7d3d0480948ff2be.JPG
Not my best masking job but then it is what it is...
About time for clear coating and Rub n Buffing the fuselage... That's the whole point of this quick and dirty experiment...
Onwards...
Quote:
Another update:
All parts needing it are gloss coated... The fuselage of course was the last one done so I'll have to wait for it to fully cure before doing the RnB on it...
Natural light...
Bright light:
So it will be the Wing assembly tonight, Fuselage RnB tomorrow night.... I know it's a longer slog thru a relatively simple build sequence and the point of doing this comes near the end, but it can't be helped if following Paul's RnB sequence... We want it shiny so it has to go over a gloss coat... Which makes it one of the last parts of the process and besides, I got a bit too close to the air intake and it developed a shallow run which will have to be polished out as well... Friday the decals should arrive so I want to be ready for them by Saturday so we will know by Saturday morning how it turned out...
Onwards... I'm getting there, thanks for the patience my friends...
EG
Quote:
Excellent work  - love those stripes.
OC.
Current builds
Completed works.
it's hard to do striping,  unless it can be done with everything apart....I get the similar overspray and seepage here and there.  ya did good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Research takes two things... time and patience (and sometimes cash).   So don't worry about the time it takes.
OC.
Hey brothers, Well the wings didn't come out too bad, but the fuselage, well, my excuse is compound curves... (I know not really an excuse)  I probably should have marked the panel lines and shaved off the rivets...
I know this, next P-51 I do will be a Tamiya "D" model done up as a red-tailed Tuskegee bird... Thankfully won't have any stripes and everything they forgot with this one, (drop tanks anyone) will be there... Best part? NO RAISED RIVETS!!!! and metal landing gear! (of course it will take about 4 times longer to build)
I appreciate it my friends, trying to move along quickly to get to the real point... A workable BMF Finish...
Thanks for the support it's appreciated..
Quote:
I appreciate it my friend, I like to do the research as well, but sometimes I get cross tracked, thank you for the vote of confidence...
Quote:
Another update my friends, (and a taste of what's coming)
I've proceeded to get the rest of the construction finished...
Minor things taken care of so when the finish is done it's a short assembly sequence to the finished bird...
Landing gear installed, the inner doors are retracted cause that is the way they were parked... The Landing Door sequence goes like this.., #1 Inner doors open; #2 Landing Gear drops taking the outer door with it; #3 Inner Door closes... There are pics on the net of this aircraft sitting on a tarmac with the inner doors open and hanging down, but if you keep searching and find a pic of a just landed aircraft, the doors will be closed... You can also find pics of recently landed aircraft where the doors are partially open and at different angles side to side... It would take about 6 hours, but the hydraulic pressure would bleed off without the engine running and the hydraulically operated doors would sag down to the open position, the same happened with the flaps and control surfaces as well....
So what I did here was glue them closed, not so much as a recently landed aircraft, it cause the kit left no way to mount them without making a huge mess right in the middle... Also, I don't expect this model to last too long on the shelf, the landing gear is so thin that I doubt they will support the model for any real length of time without breaking....
Also the Propeller and blacked out Canopy are in process as well...  But while waiting for those first stages to dry, I though I would give you all hint of what I hope is to come...
The under wing radiator intake, part of the fuselage and in BMF....
Gloved finners... I use gloves for the RnB, saves the cleanup afterwards.... (and works better in my opinion than a bare finger)
Rub & Buff...
IMG_0047.thumb.JPG.adc148e2da2269fd4008cf78998c49a2.JPGIMG_0049.thumb.JPG.5e4e2bb781b69956302a5670e59e6b46.JPGIMG_0050.thumb.JPG.39e387e68551793e129d6e7c5d331752.JPG
Well a taste, I'm pleased, very pleased.. if it comes out this well on the fuselage, I'll be a very happy camper....
Just a little more work on the Propeller and Canopy, and I feel we are going to see something good... (need to assemble and mask the canopy so the frames can be rubbed and buffed along with the fuselage)
I'm hoping everything goes as planned...
EG
Quote:
I built the 'big beautiful girl' some time back........didn't end up as the intended model,  but it still looks good.  I have the inner gear door open......if I had known that :wacko:    always liked this plane.......looks good no matter how you dress 'em up  ;)   those gears are more resilient than you think.......dropped that model a couple of times........the gear doors came off! {go figure}  she's a little dusty,  but I did the paint with a brush.
I remember the days when there was no rivets at all.........or panel lines.   the plastic was a silver laced gray.......white......a sort of turquoise....black..... .and a cream color........oh,  and red {I just recalled one model I did}.  your process looks a lot smoother......great job  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
On 3/10/2022 at 7:34 PM, FriedClams said:
That’s a nice looking result Egilman!  Looking forward to seeing it applied to a larger area.
Gary
Thanks Gary, Trying not to push it too fast, letting it happen is difficult when you can begin to see it come to life... Anticipatory speed tends to retard the modeling skills... {chuckle}
15 hours ago, Canute said:
I think you've got the method to an NMF bird. Very nice..
Thanks as well Ken, I think I've found it, trying desperately to not hurry it into a disaster... but it's looking good right now...
Edited by Egilman
Beautiful bird, classic fighterplane lines.. need to dust it off every once in a while Brother... Mine, which is the 2017 release of this '69/'70's tooling, actually warns you about the weak landing gear as does every build review I've seen... they may have changed it for the "D" model release... And I don't have to deal with that brittle, tough to cut, silver plastic... Relatively simple model it is...  Hoping mine comes out ok... Doesn't need to be spectacular, it will go on the shelf until I replace it with a "D" model myself... Hoping against hope I don't flub this one...
Thanks for the vote of confidence...
Quote:
Well my decals arrived today....
Since this will be the WWII bird before they removed the Invasion stripes, it will receive the stenciled letters and numbers... The solid versions is for the current incarnation of the plane doing the airshow circuit... I will be using the stenciling and insignias from the original model as well......
Had to take a break today, the Admiral had an impromptu trip to the the local dispensary for a prescreening before her visit and stay next week... So I was unable to get much done on the Impatient Virgin today...
And last night I ran into a bit of a problem with the canopy... Now I did have it glued together, and painted it with micromask, and it fell apart in my fingers when I went to cut the masks... That was my third attempt to assemble it as a single piece... (the last one with Testors Liquid cement cause Formula 560 doesn't seem to want to hold on this stuff) As usual, when using liquid cement on clear parts, I got the typical crazing in places and UGH! a glue fingerprint... I'll have to buff that out and paint it with future... but another issue presented itself, the Micromask didn't want to stick to it either!!! I've never had MM not stick to anything I've used it on before!
Since there is no 3rd party canopies for this bird I'm kinda stuck with what I have... This is part of the problem....
Aside from the issues with Liquid glue and clear parts, take a look at the windscreen? on the other side it is sitting in it's position groove, on this side, it is 3/32nds short... Right now only the aft windows are glued, the side window is just sitting there and the windscreen is positioned against it... The forward curve of windscreen to side window match....
The windscreen is too narrow/small...
So pretty much all day I've been figuring a way to get around this... The only thing I can come up with is strip the paint off, glue the side panels to the aft windows/fuselage, paint the insides, then glue the top hatch to the side panels and fuse after painting the insides... From that point centering the windscreen and gluing it into position matching the curve of the other panels and calling it good... At that point hand painting the ribs in aluminum...
When I built this as a kid decades ago I don't remember the canopy being such a difficult piece... Of course that was my tube glue days before the revelation of liquid cement and glue fingerprints wasn't an issue... (chuckle)
I'll get it figured out.... And we will be buff sometime tomorrow... (gotta remember, she is impatient)
Ever onwards hanging on to my sense of humor I hope...
EG
Edited by Egilman
Quote:
Ok Brothers, judgment day is here... She's Buffed! (and futured)
It does retain some reflection after sealing... Yea Team!!! The rivets were a pain requiring multiple applications to fill in between... The reflectivity is quite nice....
Lets see some more...
IMG_0055.thumb.JPG.49d291e336e73bb9479f332b9a4901ef.JPGIMG_0056.thumb.JPG.8b6bfd6f2d7c448b7e780a4bd7837cc5.JPGIMG_0057.thumb.JPG.72a3708a1fa47382b6582ac00cd66442.JPGIMG_0058.thumb.JPG.44b420097e35a4025737540476d91d56.JPG
I think it is a success, but I should have taken off all the rivets first, you really can't get a good polish on it with them in the way... What you see here is about the best you can hope for with a non smooth surface...
So, tell me what you think?
EG
Quote:
That looks excellent  brother.
OC.
Current builds
Completed works.
Looks great from here, Egilman.
