good evening everyone
Day 9 Double bottom floors stern section frame 10- 50
knowing i was going to do the after section, i should have kept the sheets separate
IMG_2981.thumb.JPG.45237d7145d3275183f87cfd813ec9ed.JPGIMG_2982.thumb.JPG.ccd415909aafba8220957551d4cb5b34.JPG
first fit showed no  issuesIMG_2984.thumb.JPG.d1cc47bb4111a276df7c97c95ace32b8.JPG
state of play this evening
IMG_2985.thumb.JPG.1a52a0dfd3b4bc051edfcf6f1928fe1f.JPGIMG_2986.thumb.JPG.c71fda8cacdb135393567de6611934ba.JPGIMG_2987.thumb.JPG.67efa2b809da807f05d909ce7c7427c7.JPG
IMG_2988.thumb.JPG.b00beb7ddbadf6273be6995abc86d0e4.JPGIMG_2989.thumb.JPG.4e91d2ea27a619eb566741fa2764633b.JPGIMG_2990.thumb.JPG.2471ac3290e85247573d7d36c7c10314.JPGIMG_2991.thumb.JPG.888065e0c619c5042513097118a4bf70.JPGIMG_2992.thumb.JPG.bc7f79ed9e11e1c8dd6d0c2b763c4e59.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
20 hours ago, Jim Lad said:
Just that little bit in the middle to do now.
John
yep, just 80 frames
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Day 10 and 11 centre section double bottom floors
thank you for comments and likes
not much to show for about 8 hours cutting, but its getting there
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
What an interesting build log this is!
When I started my seafaring career in the early 1970's the SD14 ships could be seen from time to time, particularly in West African and smaller Asian ports where container ships and the big container bridges were still beyond the horizon at the time. In the mid-eighties I started to work "ashore" and for a while I worked in a private surveying company. During that period I had to conduct a loading / lashing survey on an SD14 in Rotterdam. So, I actually set foot aboard one of those!
As you mentioned in your first post, the vessels were not too expensive, and depending on the owners' budgets some of the ships were rather sparsely equipped in terms of cargo gear etc. and hence were eyed a bit sceptically by folks sailing on more advanced ships. Still, the SD14s did their jobs satisfactorily.
It is now very pleasant to see your dry and clean double bottom tanks develop ☺️; I had my share in tank inspections while I sailed on tankers and bulk carriers...
By the way, I was not aware of card board models this size and that alone is interesting! I will curiously be following this log and your superb work (not only on the tanks, of course)!
Best regards
Uwe
37 minutes ago, Jim Lad said:
Amazing progress on the double bottoms, mate.
Tell us about the book.
John
that should not have been in the post, But, the book about Max is a true ongoing story of a guy, with depression, after a car crash, in pain, and feeling very low, and contemplating taking his own life, however he meets Max a English Springer Spaniel, and takes ownership of him, from there the his world has turned around, and now does a lot of fund raising and candidly talks about the illness,
i bought the book, and it arrived today, but the wife has taken it off me to read for herself
the PDSA awarded max the Order of Merit last year for his work
Keswick's Max the Miracle Dog gets PDSA Order of Merit - BBC News
most days there is a live feed on Facebbok of the daily walks followed by 1000's of people, there are now three dogs Max Harry and Paddy
however as it is true, life goes on and Max now aged 14.5 years has a brain tumour, but still out on his walkies on yesterdays show
Max Out in the Lake District | Facebook
Max the Miracle Dog: The Heart-warming Tale of a Life-saving Friendship
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
21 minutes ago, Oboship said:
Kevin,
Best regards
Uwe
i believe there are more double bottom floor frames fitted on the kit than the real thing, possible to ensure some rigidity
i am not aware of any other kit, this complex in card, by having it as a cutaway, i hope to keep some of this detail for others to see
NOT MY PHOTO
P1030294.JPG.f2422ed56ae70ac7eef0be418eceb7a4.JPGP1030311.JPG.f967e4da821f71bb3048c962b106ee15.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Day 13 centre section double floor frames
still ploughing through these, hope to complete the tomorrow, then its time to glue them in and get the centre line to be a lot tidier, im happy with the progress,
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Superb work Kevin,   take my hat off to you  for doing such an amazing job  with such delicate parts.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
This build literally boggles my brain both in size and detail.  Carry on, Kevin, I salute you.yellow-smiley-salute.gif.31dd6956b942a750e6c4c5640abb69cf.gif
22 hours ago, Oboship said:
Are you saying the frames are not glued in yet and that you will have to repeat the same process all over again?? :stunned:
I very much envy your patience and skills!
Best regrads
Uwe
all put in loose, i would glue them but some need attention around the centre line
OC.
Thank you OC
im here to entertain
12 hours ago, Jim Lad said:
I go away for the weekend and you almost have the double bottoms competed! :o
Sorry
John
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thanks everyone for comments and like, very much appreciated
Day 14 double bottom floors are in
its just a task now to remove each pair and adjust them to fit nicely
the gaps are where the three sections overlap, i have about 10 to put in when they are joined up
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 15 fwd /aft tank top logitudinals
day 16 fixing middle section double floor frames
removing batches of 10 of the floor frames, trimming if necessary to fit over the bottom plate longitudinals and gluing into position
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you so much for comments and likes
day 17 double floor frames are in and fixed, well about 95% rest will be done when joining the sections
also started forward section tank tops
IMG_3037.thumb.JPG.5c22fcfb262267414884c2270bb1814b.JPGIMG_3038.thumb.JPG.2d144b0626021bed19302eb818e73586.JPGIMG_3039.thumb.JPG.a63dab3bc8bb87782b3d675e0847fc22.JPG
here is a fwd section from the last time i attempted this kit, it wont be used as the colours will be altered, i will salvage the lighting and begone
IMG_3029.thumb.JPG.fdd70936f1a2b17ff1eb437aa5214fe7.JPGIMG_3032.thumb.JPG.1d721f8c77439d8abd9da699c3595837.JPGIMG_3033.thumb.JPG.a1e06602b7994147697a2bd8abbe7c3c.JPGIMG_3040.thumb.JPG.b2fb2c3d8594f9bf454ee85ee012be09.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
11 hours ago, Jim Lad said:
Seems a shame to cover up all that lovely double bottom framing.
John
i intend to leave some open, but finding it difficult to decide what bits to leave open
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
build log day 19
forward section tank tops and lower forepeak
good evening everyone thank you for comments and likes
i should have just continued doing all the tank tops, but its nice to show the sections in different stages of development (well i think so lol), the lower forepeak was a bit of a change away from cutting slots
the red is Halfords rattle can red primer, but i may go to a red/brown using the red primer in the airbrush, a hairy stick is out of the question
the middle missing plate behind bulkhead 164 goes in when the pillar is put in
the double bottom floors exposed are being left that way, as i make my plans for the cutaway sections
IMG_3050.thumb.JPG.cec24ebf701516ce80422fe2c82bd1aa.JPGIMG_3051.thumb.JPG.bda35a62117626e443f9223ca8515ace.JPGIMG_3052.thumb.JPG.f4cfbefd48eb38be834928ed6e869682.JPGIMG_3053.thumb.JPG.f389cba9bf34a8c33972051e28cf7970.JPGIMG_3056.thumb.JPG.af886b3e8181a6d6de618f25709b6739.JPGIMG_3058.thumb.JPG.bb8d8df096303814db695e680a158092.JPGIMG_3059.thumb.JPG.20ba5fef848b3184ddb01478f47fbd29.JPGIMG_3060.thumb.JPG.988059ef621d5582cd628278c53f60d8.JPGIMG_3062.thumb.JPG.8dee11b0f0406887b28fd442e8b8acbb.JPGIMG_3063.thumb.JPG.eecdc899b91335d163c94ec990aad07f.JPGIMG_3064.thumb.JPG.75504e76f775350f835f3f82a226fe60.JPGIMG_3065.thumb.JPG.6f6b6cd8642e8d945e2f4cb832f5ebd0.JPGIMG_3066.thumb.JPG.326f465657f2e5d186d06d132fb41fe0.JPGIMG_3067.thumb.JPG.558452ca58ce664e87474a48f5923e13.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Wowzer .........  I wont talk to loud  incase it  destroys all your fine work  Kevin  - Amazing Work mate.
OC.
Current builds
Completed works.
22 hours ago, Jim Lad said:
Now it looks a bit more ship like!
John
OC.
thank you for the comments, been gardening today, so not much done on the beast, just prepping the tank top plates for the middle section, update tomorrow
OC lol you make as much noise as you like, me boats fine
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon everyone
on a new build of a 1960's cargo ship, what colours would have been used, this is for internal details,
bilges
frames
tank tops/decks
bulheads
etc
was thinking of white bulkheads, green decks and red frames
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good evening everyone
Day 21 fwd section 1st cargo hold bulkhead
midships tank top going on
stern no progress
making up the first Bulkhead bulkhead, scoring the card on different sids, allows the shape to be obtained
IMG_3078.thumb.JPG.be60fb470cd66aee204110a391c527da.JPGIMG_3079.thumb.JPG.68987030ed67566c28e8450c6aa74100.JPGIMG_3081.thumb.JPG.802ce8efc6ce7e0f01cdf600ff379cbc.JPGIMG_3082.thumb.JPG.b32f5c8c62ce2d4a2167f9c308457be4.JPGIMG_3083.thumb.JPG.56565ead5e9ab58b94cde388e46c89e9.JPGIMG_3087.thumb.JPG.c41a6eda7dc7764d13c6aefb862e6102.JPG
tank tops going on the midships section
forming the box girders to keep the fwd bulkhead in place
IMG_3089.thumb.JPG.f0f744a7388305bccb20a0007fdcea64.JPGIMG_3090.thumb.JPG.005d96c3b6fc4866a4e9942618d94c50.JPGIMG_3091.thumb.JPG.f19bd7ec10e739094d530caae96ca25a.JPGIMG_3092.thumb.JPG.72ca396b5940bfd98c262239c47a5237.JPGIMG_3093.thumb.JPG.9a6019527215cdb93bea5b256ae7318d.JPG
and now its getting to big for the work bench
IMG_3094.thumb.JPG.5b84bee9c70a9f82f94277038fff398a.JPGIMG_3095.thumb.JPG.617288525df67bebcbe2908ba3361cf2.JPGIMG_3096.thumb.JPG.dafc4ea8059174900814cd4a1aa60d0e.JPGIMG_3097.thumb.JPG.9a4dc58250edd025b3cc9044588035f5.JPGIMG_3098.thumb.JPG.79449fe0e876a04de4dcbe0f65b12372.JPGIMG_3099.thumb.JPG.89e7f29a5b56df7a4e8ed5f1b64a2bbf.JPGIMG_3100.thumb.JPG.2db91700564b77cda256a6c360eac333.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looks very much like the real thing!
The construction of the corrugated bulkhead is also very interesting. Great build!
As for the colours I found cargo holds (incl. bulkheads) on General Cargo Ships painted in medium grey, and frames etc. in double bottom tanks were / are painted red (shop primer). Tank tops (which are the bottom of a cargo hold) were also usually grey but the paint would vanish after a while due to chafing, so tank tops appear(ed) rather in dark metal. On modern container ships the holds are entirely in light grey.
Decks are painted red, green or grey, sometimes even black.
Best regards
Uwe
Yes, Keith - not much attention was paid to the actual colours in the hold - something pale to add to the light, which could be pretty dim down there with just a few cargo clusters for light.  Many break bulk cargo ships had a permanent wooden covering (ceiling) over the tank tops and portable wooden battens lining the frames, to keep the cargo off the frames.  The Battens can be seen in this detail image of a cutaway model of the "Kingsville" in the Norwegian Maritime Museum at Oslo.
John
John
now thats exactly what i would like to do with mine
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
