good evening everyone
thank you for comments and likes
its been a strange couple of weeks, with real life getting in the way, only doing a bit here and there, but it all kind of fell into place today, here she is as off tonight
after welldeck made stronger
upper structures glued to the hull and wiring extended to light then
quite a lot of work is required aft, extra cabins scratched for use by the medical staff
after plank sheet on, primer used to stop light bleeding
30045607_IMG_5018(1).thumb.JPG.c0a809635e8b0517e34f51d0895b8238.JPGIMG_5021.thumb.JPG.ba170c1b4b8713ac2ba703ce4283e4d8.JPGIMG_5023.thumb.JPG.a4a77451cba82547d785400891dd51ae.JPG
waterways, metal work and railings
IMG_5024.thumb.JPG.4d918f18a35f8e013ab770533753e999.JPGIMG_5025.thumb.JPG.d120782ab696fc4eadb9fa41cd03bffd.JPGIMG_5031.thumb.JPG.47ba99f84c2efd728be2cb5505071975.JPG
after raised deck with also raises the after steering position
IMG_5032.thumb.JPG.6f78d26db90da9d7a6e053118299dd86.JPGIMG_5033.thumb.JPG.b473d379aea91929186be7bb155ee4fd.JPGIMG_5034.thumb.JPG.6580a1451e5eec94ed92648da63bc653.JPGIMG_5035.thumb.JPG.bbed79696fc4ea2f7c9b654b63768e55.JPGIMG_5036.thumb.JPG.8b6392f0f4ae86578a26550710d65a42.JPGIMG_5037.thumb.JPG.3c293151ded5cb32a2c1dafeac8d9f61.JPGIMG_5038.thumb.JPG.26e8c4a2aa205ca23c59d62eb98a8812.JPGIMG_5039.thumb.JPG.bd41ac7bf9f920a35d5ebc4980acfa37.JPGIMG_5040.thumb.JPG.8eefd5d6fb2653f325f842794ce671cf.JPGIMG_5042.thumb.JPG.2516fa819a858bdcb7304f3f656377a9.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you for comments and likes
its nice to get back into the swing of things, and so I have another update
pretty well everything on the after deck is scratched, but i did take the two lifeboats of the kit as i need to purchase or obtain more
the supports for the after steering positions is 2mm evergreen rod, other plastic mouldings are available, the white box on the stern is the morgue still very much wip
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looving your updates  Kevin  - really nice  work,    so much  fine detail  my friend.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good morning everyone
after decks continued
light bleed is still an issue on the after deck, i have managed to correct it in other placesIMG_5049.thumb.JPG.32624f1bc364e9fbee70c6b2ffb4205a.JPG
light bleed, is more of a major hemorrhage
IMG_5051.thumb.JPG.96db3d5675c23770767c1efdef803bda.JPGIMG_5053.thumb.JPG.00d75946bf942c58a85783e48673967c.JPGIMG_5054.thumb.JPG.15dd9faecb4f514bbe08dd3196236a30.JPGIMG_5055.thumb.JPG.04d131154907f1f936cdb917bf14a7a4.JPGIMG_5057.thumb.JPG.674bdf50fa80d35a551c24f56ae60aeb.JPGIMG_5058.thumb.JPG.082e7e8cfb4b5c879076580532379026.JPGIMG_5059.thumb.JPG.490c5c6ea188a92e241f54b696d57a4f.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
she's coming along splendidly Kevin..........some very nice work!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you
are you ready for another update?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening, everyone
After lifeboat rack
well i am having to use the grey matter now, and possibly failing miserably
without any plans, only a walkthrough i am having to interpret what i see, (not necessarily what there is to see, i have taken as few shots of the programme, and the 7 boats on each rack seem to be on at least 4 levels, mine are on three (please dont tell anyone)
the racks are still slightly oversized, but too fragile to make them in scale, this has taken me two days and about 7 different versions, but for now they will do, if however the next set is better then i will come back to this for the redo
shots from the walkthrough
IMG_5067.thumb.JPG.aacac6866c993a7c29432d0d02e20a92.JPGIMG_5068.thumb.JPG.7571fecb4ed01c2638304edf83f17bd4.JPGIMG_5092.thumb.JPG.c11bcc8e05c3c02094dd0899a50ed003.JPG
first failed version
IMG_5080.thumb.JPG.f19ffa05035cf5b913344d54820a282a.JPGIMG_5082.thumb.JPG.57cb4518d80a2b913f321f3febc3f86e.JPG
version 8 i think
IMG_5084.thumb.JPG.6e322f8945afb1e31a65602b35f7cd53.JPGIMG_5085.thumb.JPG.3321351d5b39274c2e64434dc173ccf4.JPGIMG_5087.thumb.JPG.d919e9746b06cc2607410848655b0585.JPGIMG_5089.thumb.JPG.a102a2a95de8ff84ee11655a1219f316.JPGIMG_5090.thumb.JPG.f61b152615945a89cfe29ac3ea544f4c.JPGIMG_5091.thumb.JPG.9eba73d270a1af446f22c3c131986df9.JPGIMG_5093.thumb.JPG.0b182407e58a5b5f4c7cd53668b66ead.JPGIMG_5094.thumb.JPG.98339bc495aeaed293b50a774db12e31.JPGIMG_5095.thumb.JPG.3841338535499e3fbfdaeb01b6f9afbb.JPGIMG_5096.thumb.JPG.5506092683900b04bc33959816872477.JPGIMG_5097.thumb.JPG.57b111af9d92ba96e4e52d1ba5450c3f.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kev! Looks great. I had to look online, but yeah, that looks basically like how they were stowed. Have you thought of sourcing some Evergreen “I” beam or “C” channel?
If you can find a small enough size, it might give you that fine profile of the racks. Going by this photo here: Lifeboats_of_HMHS_Britannic.jpg
Otherwise, looks great!
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Andy
i may have to Andy as it dont look right
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
You’ve probably seen it but somewhere on the web, I believe with Titanic info, there is an interesting animation of Britannic sinking.  It includes launching of her lifeboats.
If you have a modelmaker’s table saw and fine toothed blade, you can purchase small brass tubing and rip it into angles to be soldered into more scale like racks.
Roger
Edited by Roger Pellett
Good evening everyone
thank you so much for comments and likes
as @realworkingsailor suggested i went and ordered some more suitable I frame (3 different sizes) and today made another attempt at the after Boat rack (Evergreen 272 and 1mm brass wire, i am real pleasd with the result
whilst waiting for the strips i also did other bits like detailing the after stack
IMG_5115.thumb.JPG.5f4ad0aa1dcab52803098fae6b419f66.JPGIMG_5116.thumb.JPG.6f985affee309df85968883c70ce781d.JPGIMG_5117.thumb.JPG.8b2eb6b43444676a723f67c0ca5b0d91.JPGIMG_5118.thumb.JPG.8022b9b520d563dba5e62500977e1a14.JPGIMG_5119.thumb.JPG.4920b8054589cdd588950375ebcbb7c8.JPGIMG_5120.thumb.JPG.e047e205f125d1a7f910b3b4edf4786d.JPGIMG_5121.thumb.JPG.c3365ce39ed070c472ce323a588213d3.JPGIMG_5123.thumb.JPG.dd3b58262e2eb3c370c818f3d773d2f7.JPGIMG_5124.thumb.JPG.e074e831ed7f50e34761a3138f9f660c.JPGIMG_5125.thumb.JPG.35563ddd40e450194d02c5f7c19f9b54.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Awsome work  Kevin.
OC.
Current builds
Completed works.
2 hours ago, Ian_Grant said:
Impressive work with the i-beams and brass!  But tell me (maybe I missed this earlier in your log?) why did they pile the lifeboats up like this? And how would they sway them out if needed? Thanks.
On my tablet at present, britannic was a much modded Titanic and to allow for the right amount of lifeboats 8 sets of massive davits were to be fitted, the war got in the way, and she became a hospital ship, 5 sets were still only fitted at the time she was sunk by a mine, will post a photo later
As a post war liner it was intended for more of the racks to be fitted, and none down the sides
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
been a busy couple of weeks, and i have not been doing as much on the forums as normal, like many others, we have been making life easier for ourselves and finding ways to keep ourselves warm but at the same time not restrict what we do
we made the decision that during the day if possible, we would both work from my mancave, keeping that warm and comfortable would mean not having to keep the temperature up in other rooms, that has worked very well so far, however the mild weather here in the SW has helped a lot
2nd set of boat racks has been made up today, i ran out of 1mm straight brass rod and substituted it for .8 wire, which is ok but seams a lot flimsier, getting it straight was harder than thought, but once painted and in its place, it should be ok
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
11 hours ago, yvesvidal said:
With so many life boats, they seem to have learned their lessons, after the Titanic fiasco.
Britannic had plus boats stored on those racks, because it converted to a hospital ship. After the Titanic tragedy the outdated BRT/boat rules was changed to 'boat for everyone' rule, but Britannic had extra boats too, more than needed. Check out the Olympic refit: she sailed without those extra boats from 1913 until she scrapped. (1922 pic below)
Too bad that Britannic's boat racks would be useless in case of emergency (no time to move the boats from lower positions) and fortunately the ship was empty when sank.
Edited by Veszett Roka
typo correction
this is how she would have looked as  RMS Britannic with 4 sets of the double gantrys and no boats on the upper decks
this is a screenshot from the Britannic Patroness of the Mediterranean programme
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
12 minutes ago, Veszett Roka said:
Kev,
i'm afraid the aft staircase skylight is 90degrees rotated. The dome should be parallel to the center axis.
vasilije-ristovic-titanic-tank-top-01-we
well spotted, lol thankfully it's not fixed yet
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
First of all, your model is beautiful and your doing a great job turning Titanic into  Britannic.
I have one quibble!  Like Titanic, I assume that Britannic’s fourth stack was a dummy.  If so, would the dummy stack still have the relief valve piping running up its forward side?
Roger
5 hours ago, Roger Pellett said:
Kevin,
Roger
good question, i will check, however Trumpetr and KAMK1 add detail to that stack
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
