I am sorry if I missed an earlier post, but I would like to know a bit more about your carving as it is so beautiful. Are you marking your pieces, with ink, marker pen, or something else?   Are you carving the bone with burrs or chisels or something else?  Last, what type of adhesive do you use for the bone on wood?
Thanks Michele, your log is a pleasure for all of us to follow.
Allan
On 8/9/2022 at 12:49, allanyed said:
Scusa se mi ero perso un post precedente, ma vorrei sapere qualcosa in più sul tuo intaglio perché è così bello. Stai segnando i tuoi pezzi, con inchiostro, pennarello o qualcos'altro? Stai intagliando l'osso con frese o scalpelli o qualcos'altro? Infine, che tipo di adesivo usi per l'osso su legno?
Grazie Michele, il tuo log è un piacere per tutti noi seguirlo.
Allan
Hi, sorry you that I only just read your question.
For the Commerce de Marseille, I chose to make all the carvings in bovine bone as an alternative to boxwood, drawing on the old arsenal models exhibited at museums where ivory and sometimes bone were precisely used for white-painted decoration at that time ( late 18th century/early 19th century).
The carving is done with cutters and I must say that they work very well. Because it is harder than boxwood, you can create small details with less risk of breakage.. It can also be worked with mini files for small details, whereas for gouges I find it too hard.
The only drawback is that it is white and therefore very light and you can't distinguish well, as in wood, the details you are carving as you work. With a little practice, though, you get used to it afterwards. The time to make a carving is also longer, but the results are great. Then there is also to say that only small bone cuts are commercially available. In this 1/72 scale it is possible for me to make all the decorations, which I could not do in a larger scale.
Instead, to cut thin pieces such as frisate I use fretwork. While with boxwood I start with a thicker board and once cut I bring it to the desired thickness using the mini grinder being very but very careful. With bone, the plates I used are 8/10 of a mm thick and it would have been impossible to cut them without breaking them. In this case I glued a wooden board underneath ( if you look at the third and fifth photos you can see it), which I removed at the end of the job.
What can I say, I find it great in some respects. With that natural, warm color it gives the model a unique visual impact, certainly a material to consider for certain cases.
