I was recently "gifted" with a ship model with the hope I would be able to do some restoration on it which as can be seen is rather extensive. As far as I can determine, it is about 40+ years old. I have tried searching for something similar but without success. It measures about 36" in length and about 24" from keel to top of the masts. The name plate on the four-masted is "Fullerton." The square sails on the foremast and triangular on the other three masts is a setup I have not seen before. if anyone has some clues to offer about this model, I would certainly be most appreciative.
I did a Google search for four-masted barkentine Fullerton.
I found a number of articles referencing the Fullerton - a court filing detailing a collision between a freight car ferryboat named Transit and the Fullerton, which is described as a four-masted barkentine 235 feet in length in this article and as a ship of the same configuration acting as an oil freighter operated by Union Oil in another article.
The articles hint at available images but I didn't go very far down the rabbit hole.
The court document is very interesting reading.
Oh, and welcome aboard!
Edited by VitusBering
 Al, welcome to MSW. Nice model. Glad to have you aboard.
Welcome aboard, Al! As Vitus mentioned, your model is a four-masted barkentine (sometimes spelled barquentine), a ship that is square-rigged on its foremast and fore-and-aft rigged on the remaining masts. It is quite likely a scratch-built model, perhaps built by a former crew member or someone who was familiar with her (would be nice to know, wouldn't it?), which means it's a one-of-a-kind model and definitely worthy of restoration. Some of our members are knowledgeable about this kind of work and will be able to give you some guidance.
Cheers!
Welcome to Model Ship World Al, the virtual motherlode of knowledge and guidance with respect to ship models.  That is one interesting project you have on hand.  It sounds like some reference material is available for you to mine for information.  Please start a build log if you endeavor to proceed with the restoration so we can learn more about the history of this interesting vessel.
Best regards!
Edited by HardeeHarHar
Welcome to MSW, Al.  That looks to be a excellent project of a rare model.   Feel free to open a Restoration log in the Scratch Area.  By doing that, you might get more info and also help as needed and we get to watch.
 A big thank you to VitusBering. Using several search machines, I have come up with some history and documents on this ship. Still trying to find where she may have been built but the journey is just getting more interesting. I will definitely start a log  to record what I find.
Sorry, not sure why the above is in boldface. Tried to change it but no go.
Edited by Al Litchfield
As Chris suggests, the discipline that you should consider following is to repair and restore this model to its launch state as closely as possible.
It should also be given a protective case.
Any impulse to do "improvements"  should perhaps be given to a new scratch build of another model.  HAMMS has plans for a 1902 four masted barkentine with spars and rigging plans as well as lines.
The price of copies from The S.I. is fairly low.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Sorry to butt in -- HAMMS is the Historic American Merchant Marine Survey.
 They're a branch of the Smithsonian Institution (that's the S.I. part).
https://sova.si.edu/record/NMAH.AC.0240
https://americanhistory.si.edu/archives
The Institution is a great resource.
:piratebo5:and welcome to MSW.
It would be nice to see what you do with the model.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
