I had a thought about your spar deck planking.  Since you want to show off the gun decks, but still need some sort of surface, on parts of the spar deck, for other stuff, why not use plexiglass or acrylic in place of wood planks for those areas?  Put some decorative lighting in between decks, and that ship would ROCK!
You have set the standards!
Jon
Thank you Peter. I really like the idea of a transparent plexiglass/acrylic deck. I never thought about doing this because I had never heard or seen it before, but I loved the idea. Later on another model I will use this idea, it would be really interesting. :)
Edited by mtbediz
Using the plexiglass for the spar deck sounds like I great way to show off all the work you put into your wonderful gun deck! My question is, would you cut it into planks and plank it like a normal deck just clear. Or would you try to make it in just one peace.
I was also thinking of the admiralty models where they leave sections of the deck with no fittings open. You could use the plexiglass there instead of leaving it open and that may reduce some of the dust falling into the gun deck. It would also give a good surface for the fittings and guns to rest on.
I've never worked with plexiglass. I had dreamed of cutting the deck as a whole from plexiglass. Of course, cutting it into strips and gluing them can also be considered. But since the plexiglass is transparent, I do not know whether the adhesive layer to be applied will cause a bad appearance. I think that if we cut and glue the deck as a whole, we can more easily camouflage the stains that will arise from the glue.
Edited by mtbediz
When this discussion of using plexiglass for the spar deck planking was raised as an idea, I thought it had some merit, but I, too, was curious whether one would cut it as one full sheet or as individual planks.  And, as Mustafa questioned, as well, if cut as individual planks, how would they be secured and would any visible adhesive (once dried) have any effect on the appearance?  How would that also affect any faux-caulking applications between planks and its appearance? Very cool idea, but not sure it's ever been done for deck planking before.  Doing a search for plexiglass on MSW, and you get 19 pages of posts regarding display cases, but none of the posts deal with deck planking.  But, visualizing how it would look, I have to admit I'm intrigued.
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
If the intent is to be able to view Mustafa's masterful craftsmanship on the gun deck from above, a single sheet of plexiglass or acrylic, or possibly multiple smaller panels (call them windows?) would seem to adequately suffice.
It makes no sense, in my view, to try to make plexiglass strakes.  There's absolutely no way that that could be made to look good. And it would most likely simply muddy the "window pane".
I say, go for one large panel or several small strategically placed windows.
Edited by Der Alte Rentner
Typo
It is time to prepare the carronades that will be placed at the aft of the ship. I painted and varnished the carronades. I cut the capsquares from brass sheet, shaped them with the help of a simple tool I made, drilled the necessary holes and blackened them. The next job will be to secure the carronades to the carriages.
When everything is put together they will look like in the last photos.
I produce the breeching ropes myself with my homemade ropewalk.
Edited by mtbediz
The eyebolts look really good, Mustafa!  And really look nice after they are blackened.  When making them, did you bend them first and then create the loops, or first make the double loops and then bend the end?  Which did you find was easier and more accurate for you?
Gregg
Thank you Greg, I created the loops first and then bent them. I didn't try the other way you mentioned, It could be easier, gotta try it.
The carronades are looking really sharp in place, Mustafa!  How are you securing the carriages to the deck? Simply by using PVA glue?  The spar deck is really taking shape! 🏆👍
Gregg
Thank you Greg. I glue the carriages to the deck with CA because I prefer it to dry quickly. I apply a small drop of CA under the truckles.
Great looking model!
Jon
inspiring work, as always.  I'd love to see some photos of the technique you use in rigging the carronades.  I assume you do the seizing (right term?) before you glue the eyebolts in.
Thanks Peter, yes I do the seizing first then I install the carronade on the carriage and I glue the eyebolts in the holes I drilled at the bulwarks earlier.
Edited by mtbediz
Great work on the carronades, Mustafa!  And it is exciting to see how the view of the gun deck is coming together, even as you add these carronades to the spar deck.  Have been curious how that was all going to look.  Very nice, sir! 🏆
Gregg
Thanks Greg. I actually hadn't decided how much to cover the spar deck until I reached this stage. At first, I thought of covering only the areas where the carronades would sit in small pieces, but when I tried it, I saw that this disrupted the integrity of the model and did not create a pleasant appearance, so I gave up and made such a planking. This provided the model with a nice appearance and also allowed the gun deck details to be seen. By the way, I was planning to cover the centerline of the spar deck, but I'm not doing that either. I leave it as it is.
Wow - that really holds up to scrutiny!
hamilton
Spar deck is really coming together.  Starting to get a better feel of how it will look.  Excited for you!
Gregg
