Tom those will look great.When you start your filing it works well to have piece of filler rod inside the tube you are filing. and do the filing before you cut it off the main stock. Ask me how I know.
Michael
OK, I'll bite.....How do you know? Regardless, it's good advice. Anyway, I had to order on line. $1.75 for the rod and $8.00 for shipping. Something is out of whack, and it won't get here until Jan 7. I'll work on the boats until then.
John,
I'm looking at the time of your latest encouraging remark, and realizing that there's a 14 hour difference between your place and mine. That means you posted at 6:30 AM? Early riser?
Tom
Edited by TBlack
she looks great Tom.........you've done some really nice detail work to the pilot house.  funnel looks really nice as well ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
A lovely built Oldtimer Steamer Tom
These typ boats have real character, and yours has an interesting hull for shallow Waters, probably a river Steamer
Looks great.
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Thanks for the compliment. Vinal Haven used to sail out of Rockland, Maine servicing the islands in the Penobscot Bay area from 1892 to 1938. She's a typical configuration for steamers of that era.
Also, thanks to all of you for the "likes". I appreciate the support..
While I'm waiting for the turnbuckle brass to arrive, I'm turning to the boats. They're big, 5.25" long, but no interior, as they are covered. I thought I would build them POB style. I think it might be easier for me to make sure they are duplicates.
Tom
Edited by TBlack
Tom with the small tubing if you file it while it is attached it is much easier to hold onto because you need to remove quite a lot of the tube to make it look like the picture you posted and if you cut them to length first you end up losing them either to the floor or to a snag while filing because there is so little tube left by the time you are done.. it also helps to have a small v groove in a block of hardwood for the filing. I will sort out a picture of what I am trying to describe.
Michael
Amazing job Tom , I should be on your Christmas list
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Michael,
This was only my second try, but I think I've gotten it. Sorry for the fuzzy picture, but my camera doesn't do close-ups. The flip side of the turnbuckle looks like the side you're viewing.
The wire in the center (28 gauge) is a good idea if only to stiffen things up while filing.
Also, I decided to paint out the moulding around the boat deck. It looks big and clunky to me next to the moulding around the pilot house, and it's less obvious if painted. Also, the real boat didn't have brightwork up there. I promise never to use bass wood for moulding again!
Looks pretty good to me Tom. Looks like you are getting the hang of working this brass stuff.
Happy new year to you Sir.
Michael
Amen to that, John.
Michael, thanks for all your help on the pilot house, the stack, the turnbuckles. You've gone way out of your way to aid me.
Andy, I think those dentils look pretty good. You certainly can't tell they're plastic, thanks for the suggestion.
And guys, thanks for all the "likes", BTW, Wacko, what are you doing up at 3:40 AM?
If my work looks pleasing to you, a large part of that is due to this website. It inspires me to try just a little bit harder and not to be afraid to throw out a first attempt, or even a second until I've got what I want.
Tom
Fine work on the turnbuckel it goes well with such a fine boat.
Bob
Edited by Cap'n'Bob
Current build:  SS_ Mariefred
all within the art of creation..........I wonder if  'He' threw out the  'first attempt'?    sorry 'bout that.......I just had to jot that one down.
I think you did well Tom.........it gives the build a nice contrast of art work.    your also finding out that different textures of wood,  behaves differently under certain circumstances.   I owe a lot of kudos to the site as well,   but your perseverance to create,  should also be counted.  ;)    you've done an admirable job :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
The first attempt got lost to the floor. I thought, by inserting a black wire in the middle of the tube , that in filing down the outside of the tube I would come to the black wire and know to stop. Actually, what happens is that the flashing from the filing covers up the black wire and you end up filing straight through the tube! Second attempt: file a little bit and plunge the black wire back and forth cleans out the flash and you know when to stop filing. Anyway, all 4 turnbuckles done. But I think I need #3 piano wire for the stays to ensure that they are straight.
In the meantime, I've been working on the ladder and eagle. This is Andrieke's eagle, by the way. A terrific tip and a huge saver!
Tom
I’ve been waiting for the ladder and it looks great.  And the eagle is just right.
Bob
Tom, things look to be coming together very nicely.
Michael
super additions to the helm deck Tom.........whether you try your hand,  or simply paint the eagle gold,  I think it will look perfect  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
January has been a cold month here, and, with my workshop in the basement, the working conditions have not been ideal. Nevertheless, I've been (slowly) working on the life boats. I determined that they are 5.25" long. I got a plan out of a book (thank you Portia) and sized it on the copier to the proper length. Now, I'm just putting them together. They have a canvas cover over them, so I don't need to do the interiors.
The stays, with turnbuckles, for the stack all came out fine. I'll see if I can get a decent photo, but I've got a poor camera for detail work.
Tom
Looks like a lovely life boat to go with your fine Vinal Haven.
Bob
Tom,
You 'snuck' in that eagle while I was away and I missed it completely.  I think it might look nice in gold!
You boat is looking good.  It's always a comfort not to have to do the interiors. :)
John
is that what your doing........making the frames and planking them?   since your covering them with canvas.....sounds like a good simple approach.......looking very good  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Tom,
John
John, That eagle was due to a suggestion from Andrieke (the benefits of community). It comes from a supplier to the model railroad guys. I'm delighted with the result, and a pretty easy solution, too.
Popeye, That's it; bulkheads around a former and then cover the whole thing with "canvas". Here's the real thing:
Tom
Looks good Tom, its a model not a piano.
Michael
I finished the boats. I need to install the tie-downs and trim up the "canvas" covers. The "canvas" is 2 pieces of kleenex soaked in a solution of glue and then draped over the boat to dry.
I've been slow to work on this boat this winter, maybe because I'm coming to the end of the trail, and I don't know what to do next!
Tom
Edited by TBlack
real nice looking ship Tom,
also the two boats look very realistic
Nils
Current builds
-Lightship Elbe 1
Completed
It took you a lot of thought and work but you built a boat to be proud of.  Well done.
Bob
