Hi
Looking to replace my work table light.Need one that is very bright and one that is on an adjustable arm. My table is in a room that I cannot put a large light above it from the ceiling,only on a stand from the table top,or clamp on the edge.
Thanks
Keith
I have two magnifying glass/lights on spring loaded locking arms
One on my scroll saw and one on my work bench
Just push them back for illumination and pull them forward to highlight (enlarge) my mistakes
Edited by AON
Alan O'Neill
Can you mount light on a lamp post so the light is reflected from the ceiling and walls instead of mounting for direct lighting . Much better and very few shadows,  small, movable arm spot lights could be mounted on each end of the table for a bright concentrated light when and where needed.
jud
WOW 400+ dlls for a desk lamp????
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
I found a very inexpensive lamp that clamps onto the work table.  It has a circular fluorescent bulb around the  outer ring and an incandescent bulb in the center.  You can turn on either or both lamps and the arm and fixture are completely adjustable.  I love it.  I also have a separate light, also clamped to the table that has a circular fluorescent bulb and  a big magnifying glass in the middle.  I use it only occasionally for very detail work but don't consider it strong enough to light my workspace.
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Higher quality lamps are definitely not cheap.  I spent a little more money and bought Electrix brand lamps off ebay to save money (I think the 7122 and the 2246 models).  One is just purely a 100 watt bulb, the other has an incandescent and circular fluorescent bulb with a built in magnifier.  I really like them, and haven't found any of the clamp issues that are reported on Amazon with mine.
When I did research on lamps with extending arms, the biggest complaint was that the cheap ones wont stay locked in position.  To me that was annoying, if not potentially dangerous when using power equipment.
Try checking your local office supply store.  They usually sell all kinds of desk lamps and drafting table lamps.  Many are clamp type, others have a base.  They also have different adjustments and bulb types.    I have 4 lamps in my workshop.  One is a utility type under the cabinet (kitchen type) over my lathe.  The other three are adjustable, one magnifier, one with a clamp base at my mill and table saw and the last sits on it's base over by build table.  I can move it where I need it.
I like the OttLite.  I have the basic / original flip up light, purchased over 20 years ago when I was doing a lot of art quilting.  They have a proprietary light bulb that shows true colors, day or night.  Check out the color shown here: http://www.ott-lite.com/t-why-ottlite.aspx
Mine is older and is similar to this one:  http://www.ottlite.com/p-342-13w-folding-task-lamp.aspx
They have many styles available, including clamp on desk version of this lamp with a 3x magnifier:  http://www.ottlite.com/p-59-easy-view-floor-lamp.aspx
Ott lights are like ink jet printers, they're reasonably priced but they get you with the dedicated replacement bulbs.  My Ott light cost $40, but a replacement bulb is $18.  However, I've been using the same light bulb for 20 years.
They have numerous styles available that can be purchased at local retailers or on-line.
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
For a decent work lamp I use a base mounted flexible shaft type. I was wondering would LED lights be any good? I have never used them.
Regards, Scott
Completed builds:
Awaiting construction:
