Great Pics and article Kurt!
So I am ready to fit the mast ring. Can anyone advise me on the proper way to anneal it? Never done that!
Thanks !
Take the piece of brass and put a flame to it.  Then drop it in some water.  This will anneal it for you.
David B
Yes, heat it red hot and drop it into water.  It will bend very easy then.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Be sure to clean it up afterwards...a little wire brushing...some time in a vinegar bath.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Here are some photo I took at Manitowoc I think these will help you on your build it i coming along nicely.
David B
Good Evening All,  I had a chance this afternoon to go through and read this blog from the beginning.  There were several interesting points that I wish I had been able to comment on at the time.  I hope that you won't mind if I interject a few thoughts here as I am sure that there are other gunboat builders that may be reading this.  First of all, there was a comment and a question on "two books" on the Philadelphia and I did not see an answer to that.  I am guessing that the two books in question are John R Bratten's "The Gondola Philadelphia & the Battle of Lake Champlain" and the other would be Philip K Lundeberg's book "The Gunboat Philadelphia and the Defense of Lake Champlain in 1776"  Both being worthy companions to a build.
I have attached a couple of pictures here, the first concerns the hawse pipe.  In talking to a old shipwright, he explained that often the hawse pipe back in the day was a lead pipe that was fitted into a hole in the bulwarks and then the ends were hammered and peened over the edges to secure it.  I decided that a bunch of barn builders and detachments of army soldiers probably would have done something expedient just like that, so I used some brass tubing with solder on the ends and just hammered the edges over with a pin punch, the painted it with Vallejo Oily Steel.
I wanted to add a comment on cannonballs also (Particularly in a larger scale as the Philadelphia is.)  Below is a picture of an old shotgun pellet training tool or paper weight depending on usage.  My point being, that there are printed cards, etc that show exact sizes of shotgun pellets and one shotgun shell of the correct shot size will certainly arm at least a small brig with more than enough cannonballs!
(PS  I read somewhere in my research that the bottom planks were tarred, so I did just smear on a thick coating of that tannish tarry color that you see on sun baked asphalt roofs, but was still asked in Manitowoc if that was a water line model..........)
Enough of this for the night.  Sam
Sam,
    There were several PHILLY builds going at the same time.  Sometimes the discussions shifted from one to another.  I believe I discussed both books in my log.  I also covered them as well as "Benedict Arnold's Navy" in my scratch PHILLY build log.  All excellent resources.
Chuck Seiler
Sam,
I, for one, would like to see your posts on this any other discussion in it's own place.  It a) deserves it and B) it won't be lost in Steve's build.   Can you be persuaded to put your tips, tricks, methods into say... here:  http://modelshipworld.com/index.php/forum/24-wood-ship-model-kit-questions-and-reviews/
If the moderators think it should be somewhere else, I'd hope they will move it.  But you do have some seriously excellent suggestions, ideas, and methods.
Here are a few pics.. my humble offering! Been so busy with our new album..(I am a jazz drummer). Say Chuck, we are getting a lot of air play on KSDS 88.3 in San Diego. We are working to get down there soon for a gig!
Anyway, working on the rope coils, getting set to get some rigging started.
Steve,
    Looks good.  You will get plenty of opportunity to practice those rope coils before all is said and done.
Chuck Seiler
Steve,
    On Philly 1 I ended up lashing the rungs to the shrouds.  The attached pic is not all that clear, since I wasn't taking pictures of the rungs.  I'll get some better shots Monday.
Chuck Seiler
Your Galley is really coming along, Is that a stain or jobs I see or LA that the finish,It looks wonderful.
David B
post-13761-0-60054800-1441248692_thumb.jpgpost-13761-0-47939900-1441248604_thumb.jpgpost-13761-0-28946700-1441248605_thumb.jpgpost-13761-0-27294900-1441248606_thumb.jpgSo I decided to make real bricks as in Kurts article. It was actually fun to do. I removed the wooden bricks and used it as the mold. I even sprayed with cooking spray after testing one with and without. The spray works great. I used ca glue to assemble the cookstove. There were enough bumps etc to elevate the bricks for the morter. I used Sculpey terracotta clay for the bricks. For the morter Liquidtex modeling paste. I added a drop of walnut stain to the Liquidtex and was happy with the color. I simply "caulked" the bricks. I wll add the burnt wood etc.
Good time on that project!
Edited by Steve.Y
The stove looks great!
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
