We're modelshipbuilders.  Patience goes with the territory.  :D  :D :D  :D   Ok... so much for that.  Now where's the sawdust?
well i made a start, a few days away from making sawdust though
1x cherry planking
2x pear framing
1x sycamore-don't know what for (forgotten)
1x maple decking
also bought a chuck for my lathe, was fed up not being able to centre the lumber
and a couple of proxxon blades for the fet
i may purchase the brynes sander for crimbo
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
That's a nice pile of wood, Kevin.   Time to tune up the table saw and scroll saw I guess. :)
i contacted Jim Brynes tonight wrt to the
i await his reply for the shipping costs to the UK
i have also included the drawplate
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
silly question time
what glue to stick the templates to the timber
i have never heard of this glue which is quoted in the Assembling frames tutorial- is this copydex
quote"
Cut paper-form glued on the timber, here components for different double frames,
so marking with the number of the frame is important in order not to mix them.
You see also the special glue ( a rubber cement "Fixo Gum" by Marabu)
I used which is possible to remove afterwards without any rests on the surface of the wood!
(Highly recommended glue and many thanks to Jim who sent me this tube ) "
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
There are a number of topics about that - no consensus, people use different glues. I use paper stick glue, then scrape away the paper. A bit of sanding is needed anyway, and it removes all traces of a glue completely.
I used rubber cement and rubbed off the residual glue after peeling off the paper.  I still use this method.
Wow Kevin,this went well under my Radar :D As for gluing your patterns to the timber,you can't beat good old fashioned Pritt-stik in the UK ;) Apply to the wood,carefully lay the paper template on and smooth from the centre outwards with a bank card,plastic offcut etc.I find it is best to leave a couple of hours before commiting to the saw,then you don't end up with the paper lifting.Removal is easy with a wet cloth and the adhesive residue is easily cleaned off and leaves no discoloration :) .
Anyway,I wish you all the best with your build mate and will be following along
Kind Regards
Nigel
Currently working on Royal Caroline
I have found that a Elmer's Glue Stick works great. Used for kids art projects, patterns stay in place and leaves little residue that cleans off with a damp cloth.
I'm sure they have a similar product in England.
Pictures of new tools and a stack of wood, does life get any better than that?! ....I think not ;)
Sincere Regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Hi Kevin,
Looks like a great start.  I am considering the Triton cross section also so will look forward to following along.
What are the dimensions of the wood you are and how do you plan to cut it to size? I would think the proxxon saw would not be able to handle the size planks you have shown.
I have the Byrnes saw and am also looking at his sander but am not sure whether hooking it up to a shop vac will keep the dust down. I work in a room of the house and need to exercise some constraint about sawdust :-)
Richard
Edited by rtropp
Richard
Member: The Nautical Research Guild
Hi Kevin,
Richard
Good morning Richard
I dont have all the answers yet,
i have a band saw, scroll saw, bench sander, wood lathe, proxxon saw table and drill press
i also have a thicknesser but is to big to do this work (i believe) and has metal blades (damaged)
i await Mr Brynes for a shipping cost of his thicknesser to the UK (even if it was to arrive tomorrow it is NOT going to be opened before Chritmas) - LOL
the wood I purchased is mainly 2"x 2"x 24" so i am going to see what i can do with what i have available
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
just deleted  a load of stuff
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
On the pattern gluing question, one trick I picked up reading a scroll saw forum was to apply blue Painters tape to the wood first, then stick the pattern on top of that. The painters tape is low tack, so removal after cutting is easy and virtually no residue to clean up. You can buy the Painters tape in a variety of widths in you local hardware store. The glue you use for the pattern then doesn't matter. I prefer to print on sticky label paper, but some prefer a spray adhesive.
Hope this helps.
i received the quote (p&p) from Jim Brynes for the thicknesser - paid , so hopefully it will be here before the big guy in red arrives
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
You're going to love that Byrnes machine Kevin. In six months you won't remember the price, but you'll still be in love with the machine! :)
Well i have had a go, used some crappy white wood from under the work bench, measurement wise it is spot on, so im happy
now to try with my purpose bought wood, is this enough to be granted access to the next set of drawings, please?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
well after the 4th attempt i got it right, well i did on the 3rd as well but cut the 3 length the wrong size
i wanted a darker wood for the false keel so used some from my scrap wood pile
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you Juergen
not much to show but that was a big fence for me to jump hopefully as I gain more confidence with my tools I will get better
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Nicely done.  Clean, crisp and looks great.
I am itching to move forward, lol (i must wait for admin)
what did I learn on Day 1
Well all my tools don't cut straight, which i was aware off, but in real life it didnt matter, since dinner time yesterday all the cutting guides are checked with set squares, wow what a difference
Also - it may look right on the first attempt, but would it look better on a second one - in my case yes
Don't be frightened of the tools, treat them with care, and remember they will bite, but they were bought for the purpose just have to learn what that purpose is.
Do wear eye and ear protection
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
I've found that always square up the machine tools and adjust/calibrate as necessary.  Seems they have a mind of their own when you turn them off and leave the room. :)
