Today, I finished planking the Hull, did some light fairing and built the Cradle. Next will be to complete fairing the Hull. Here are the results
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
A sweet looking hull Pete.
Michael
Thank you Michael, I am happy with the way she is turning out
Thank you David
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
After a day and a half of Fairing, I got the Hull sanded to 600 grit , and sealed the inside of the Hull with Titebond III ( waterproof  glue ) next will be to coat the exterior of the Hull with West System epoxy. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Well, It seems that I had missed a step, ( before sealing up the outside of the Hull ) so Today, I layed out the deck cut it out and installed it . After I faired it to match the Hull. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
She's looking really good Pete.
Current build:  SS_ Mariefred
Thank you Cap'n'Bob, I appreciate it,Your Friendship sloop is looking really good as well .
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
After some long contemplation, I decided that I would Varnish the Hull, With Epifanes . and rather than showing it being sanded and another coat being applied. I would show it after 4 coats have been applied sanding with 400 grit in between coats, and waiting 24 hours between coats . I will do one more coat and she should be ready to go . I will more than likely do a flat white bottom paint with a blue waterline. the slot for the tiller has been cut into the transom. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Patrick, 1 more coat should do the trick
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, before I finish the final 2 coats of Varnish on the hull, ( I decided to go with a varnished Hull no bottom paint or water line. Kate said you don't want to cover up the wood do you ? she wins ) I started by trimming the deck edge where the Cockpit coaming meets the deck, I then sanded the deck to 400 grit sandpaper ( starting with 220 ) I then applied 2 coats of semi gloss white to the deck . Here are the resultes
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Better all the time.
Bob
Thanks Patrick, Kate is always right
Thank you Cap'n'Bob
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Super looking hull Pete,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils, She is starting to take shape
Hey Patrick, True that
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Sweet, just sweet.
Michael
Thank you David B. you gotta love the Herreshoff designs
Thank you Michael, She is starting to come together
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, before I sand and Varnish the Hull, I decided to add some birch ply to the forward Cockpit bulkhead and the rear deck Cockpit station and stained them a cherry red. I started by laying out the ply using the plans, I then cut them out and glued them in, and then stained them Next I cut out the floor and cut out birch ply for the rear deck. And lastly I cut out the seat benches. Next will be to sand and varnish the Hull. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Patrick, I am pleased with how she is coming along
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
What a clean build with sweet lines, Patrick.
Thank you Mark, Herreshoff  designs have the most beautiful lines I have ever seen
Thank you Yves, I like the color combo of natural wood and the stained red ( it's pleasing to my eye )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
I finally finished the Varnishing of the Hull, it took 6 coat's of Epifanes varnish to get the result that I was looking for . now that the outside of the Hull is complete I can turn my attention to the inside ( Cockpit and rear deck ) Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Picture perfect finish on a picture perfect planked hull.
