Everything posted by thibaultron
I would say, no more than half. A quarter would not allow much adjustment on the real thing.
- 90 replies
- finished
- Midwest Products
Converting a Backyard Shed into a Model Workshop
thibaultron replied to Hank's topic in Modeling tools and Workshop Equipment
When you finish repairing the siding, I would suggest putting some of the mobile home vented skirting around the bottom, to prevent rain splash from getting on the bottom of the siding flooring joint, and wicking back between them. I dont think the latice will do an adiquit job. -
Ship Building Workshop
thibaultron replied to Castos's topic in Modeling tools and Workshop Equipment
I don't remember if you have or planned for one, but a porch roof over the doors. This would make unlocking, and opening them in the rain more pleasant. My shop has just enough roof overhang to drip water down my neck while I'm doing this. -
I would put the thickness sander in the corner, and the band saw in the middle to give you more elbow room when sawing.. Buy a rolling toolchest and mount the lathe on it. This gives to storage for a lathe tools, chucks, measurement tools etc. -
Might I suggest cualking at siding to floor beam joint? Can the lattice easily be removed at this point to do this? -
Many Chesapeake Bay workboats are and were painted white, including the decks. Plain wood slabs were then set over the most abused areas, to protect the decking.
- 72 replies
- Chesapeake Bay Flattie
- Midwest Products
Need CAD type program
thibaultron replied to Sambini's topic in CAD and 3D Modelling/Drafting Plans with Software
Thanks for the warning about the newer versions! -
I've used DesignCAd for a couple decades, not nearly as long as the others. It is a reasonable price and offers discount on future upgrades. I generally upgrade about every 4 years. It does have a steep learning curve, but so do the others. I started by just leafing through the manual and seeing what each command could do, then start simple. -
When I was doing my smooth bore I did find one ship with ports on the weather deck guns. The plans were from a well known author, but I have since lost the info. So I built mine with the port lid, but with line rather than chain rigging.
- 31 replies
- carronade
- model shipways
I'll be watching your tutorial! Always want to learn new things! Wonderful work, and in just a week!
Before you continue with the bottom, you need to finish the roof over the loft. Trying to get insulation and some type of panneling, or drywall up will be much more difficult if there is "stuff" in danger below you. It would have been better overall to have done it before the loft floor was installed. In my shop I added an additional row of studs on the inside walls and put in a double layer of insulation. This has greatly reduced the heating and cooling costs. Mine is 16X30 shed. My rafters were 2X6s and I double insulated the roof by screwing 2X2s to the bottom of them. so two layers of R-13 batts give me R-26, top and sides. I also made provisions for a half bath, as I've gotten older I find I need more frequent use of such, and having to go back in the house disrupts the work. It will also be easier to wash my hands if they get paint or something on them, rather than again going to the house, with the added risk of transferring said stuff to the house doorknobs or interior. -
When I made my smooth bore model, I condidered the deck/bulkhead as a setting for the model, rather than a model in itself, so just made it look good, not highly detailed.
- 31 replies
- carronade
- model shipways
You might concider silkspan sails rather than using the material supplied, which is both to thick and too course a weave. Search the forum for info on making them.
- 90 replies
- finished
- Midwest Products
I saved the chain for another future project.
- 31 replies
- carronade
- model shipways
Waterway! Wish I had thought about that when I built mine. It never occurred to me. I built the deck pretty much from the instructions. I did add hooks to the gun control lines and used the stropping line instead of the chain for the gun lid rigging. Could not imagine them having a chain constantly rubbing on a closed lid.
- 31 replies
- carronade
- model shipways
The general rule of painting multiple colors is that the lightest color goes down first, progressing toward the darker colors.
- 61 replies
- crabbing skiff
- finished
- (and 2 more)
I might suggest repainting the inner bulwarks red. On my Smoothbore Cannon, the fittings and accessories sort of disappeared in the black back ground of the inner bulwarks.
- 31 replies
- carronade
- model shipways
Don't stop your build because of this, a little sanding, and try again. What paint were you using for the red?
- 61 replies
- crabbing skiff
- finished
- (and 2 more)
Check Amazon for Landstrom;s book. I recently bought a used copy for $16 US plus shipping. Good read.
- 45 replies
- egyptian
- bronze age
