Posts posted by usedtosail
- GrandpaPhil, Glenn-UK, Keith Black and 4 others
- 7
The cannons are assembled and I have added breechings to them. To make the breechings, I first tied a throat seizing to a piece of line to make a loop then seized eyebolts to the ends of the line. I didn't fix any of the seizings so I could slide them to make adjustments. I slid the center loop over the cascabel of a gun barrel then tightened and fixed the throat seizing. I then adjusted the eyebolts to get the length of each side of the breeching right (about 3cm), then fixed those seizings. Here is the first gun installed. I glued the trucks to the deck first then glued the eyebolts into the holes in the bulwarks. I was happy with the way the line played down onto the deck.
Here is how it looks from the outside.
Only five more to install. I have the shot holders ready to install too with the shot inside. I found it tricky to get the shot to stay in the holders when I put lacquer on them to hold them together, but with some persistence I got them fixed inside the holders and reasonably flat. I also added all the interior eyebolts and cleats and drilled the holes for the exterior eyebolts, although I won't add those until I rig the lines that they attach to, so I can do those seizings off the model.
- Theodosius, Keith Black, Seventynet and 4 others
- 7
That is a nice build Rob. Looks like you figured out the signature, too. Well done.
- Keith Black, Dave_E and DocRob
- 2
- 1
Thank you Rob and the likes too. Rob, keeping the builds clean is something that has taken me quite a lot of time and I am still not totally there yet. Do you have a build log? I'd love to see your build.
I have the quarterdeck stairs and side railings built and installed and the cannon carriages are in the process of being built. I thought the cannon barrels looked a little shiny so I gave them a coat of flat black paint. Here is a weird photo of the stairs and railings.
- DocRob, KurtH, GrandpaPhil and 7 others
- 10
Thank you very much Gary and k-mart. It means a lot to me coming from you.
- FriedClams, mtaylor and Keith Black
- 3
I finished the windlass and glued that into place relative to the belfry. I need to put a coat of wipe on poly on the belaying pin racks. I painted the winch with burnt Sienna and used wipe on poly to finish the supports. The chimney is completed and glued in place as well as the kevels, knight heads and bow timber heads.
Further aft I have added the quarterdeck rail and the roof to the tiller house, which is not mentioned anywhere in the instructions that I could find. I am using a lathe tool holder as a weight to hold the roof while the glue dries.
I am assembling the quarterdeck stairs and side railings, then I have the cannons to put together.
- Dave_E, chris watton, Seventynet and 9 others
- 12
I completed the pumps and glued them into the holes in the deck. I added small pieces of brass tubing to the barrels for the dales. I also added the coamings and gratings to the deck.
I added the bell to the belfry with the PE handle. I haven't added the pawls yet until I put the windlass in place. I dry fit the belfry and the bow sprit bitts for now.
The mast coats are also dry fit for now until I put the masts in. I am working on the windlass and the kevels.
- Theodosius, Dave_E, GrandpaPhil and 7 others
- 10
Lots of deck fittings have been added. Starting on the upper deck I added the mizzen bitts and pin rails. I am using the supplied brass belaying pins which I have painted brown. I built the binnacle and glued it to the deck. I did not like the look of the sides which showed the joints of the internal parts, so I glued some thin pear onto the sides to cover them. I shaped the three mast coats but won't glue them on until I fit the masts in place. I added the railing for the spiral staircase using the supplied parts. I like how others have substituted wood posts at the corners but I wasn't confident enough to try it. I also shaped and added the timber heads to the rail. As a reference for future builders, the first picture of these in the instructions shows them upside down. I was trying to visual how to shape them when I discovered this and it was much easier when they are right side up.
On the lower deck I added the two main bitts and belaying pin racks. I have added the eyebolts next to the gun ports that won't have cannons but I will wait to add the others until I rig the breach ropes on the cannons. I also added the ring bolts to the deck, again using the supplied brass parts.
I am currently building the pumps. Assembling the pump handles was a bit challenging but they are done and have been painted black. I am also cleaning up the char on the hatch coamings so should have them ready to install soon.
- Ryland Craze, Paul Le Wol, KurtH and 6 others
- 9
I wrapped the steering line around the wheel and fixed it with lacquer. When it was dry I slipped two of the 2mm blocks stropped to eyebolts on the line, then glued the wheel standards to the deck and the eyebolts into the holes under the wheel. I then slipped two more blocks on each side and glued them into the holes along the bulwarks. I then passed the lines though the blocks on the tiller and seized the ends to the empty eyebolts near the bulwarks.
I left the ends of the steering line untrimmed for now in case I happen to catch the lines later, so I can re-seize them without having to thread a new line through all those blocks.
I have started adding all the eyebolts around the mast holes. After that will be adding the coaming and railing around the circular stair opening.
- Keith Black, yvesvidal, Paul Le Wol and 4 others
- 7
Thank you Keith and the likes.
I finally got the two 2mm blocks attached to the end of the tiller. They are so tiny but the main problem was they were coming undone when I clipped the excess strops off. I am using Dullcote lacquer to fix the knots in the strops which usually works very well, as long as I give it enough time to dry. I glued the tiller to the hole in the top of the rudder. I also assembled and painted the ship's wheel. Here it is just sitting on the deck as the glue dries to make sure it is flat to the deck.
Next up is adding the rest of the blocks and eyebolts then rigging the line between the wheel and the tiller. I have a short piece of line through the tiller blocks for now as it helps me see where the holes are for the real line. I had to drill these out a bit to get the .25mm line through them.
- BobG, KurtH, Keith Black and 2 others
- 5
Thank you for the kind words Keith, Cathead, Grant, and Christian. I really appreciate them.
- Cathead, mtaylor and Keith Black
- 3
After the rudder I started working on the bulkhead that goes between the two decks. I painted the blue on the inner piece and black around the windows on the outer piece. I then glued the outer piece to the inner piece, then painted the top edge black. I added the window PE trim, the hinges and door pulls, and the decorative crown. I glued the bulkhead to the two decks using weights on either side to hold it tight to the decks and take out a slight curve in the piece. Finally I gave the wooden parts of the bulkhead a coat of wipe on poly.
While I was working on the bulkhead I also assembled the spiral staircase. I gave it a coat of wipe on poly and glued it into the deck opening after I installed the bulkhead. It would have been easier to install it before the bulkhead because I could have seen the tab and the slot that it fits in better, but I was able to get it installed after a few minutes of effort. I also installed the dome canopy base after very carefully removing the char and the some after painting it copper.
Also while doing all that I made up the side steps ands the channels and installed them. I gave them all a coat of wipe on poly after they were installed.
I am now working on the tiller housing and tiller. I shaped the tiller and stropped two 2mm blocks to the end and glued the sides of the tiller housing in place. The next step will be to install the tiller on the top of the rudder. I have also started assembling and painting the ships wheel. I'll have pictures of those components in a day or so.
- KurtH, Keith Black, yvesvidal and 4 others
- 7
After giving the display base a coat of wipe on poly, I glued the stove to the base then the base to the supports on the beams. This completes the stove project.
This was another fun scratch build. Here is the stove displayed next to the capstan and ship's wheel.
And here are the two stoves together.
Thanks for following along. My focus now will be on finishing up the Duchess of Kingston, but I may have another scratch build in the future.
- Keith Black, KurtH, Dave_E and 1 other
- 4
I assembled the three wooden parts of the rudder and removed the char. I glued the straps to each side, using one pin to align the strap to the holes. I rotated the strap on the pin, put glue on the rudder and rotated the strap back until I could see the holes were aligned. I then drilled holes in the rudder notches and glued a piece of wire in each one. I added wooden gudgeons from Syren to the wires instead of the supplied PE gudgeons as I think they look more realistic.
I don't have enough brass pins left to fill all the holes in the straps but I found some brass nails that have a very similar head size so I will use them on one side. I also need to give the rudder a coat of wipe on poly before attaching it to the hull.
- Dave_E, KurtH, Keith Black and 2 others
- 5
- albert, FriedClams, gjdale and 5 others
- 8
I finished adding the quarter gallery photo etch pieces, as well as the PE gun port frames.
Having the holes and pins to align everything worked really well. Later I added the scupper covers to the hull too. So far I have only lost one PE piece, the cat head end, but @chris watton was kind enough to include two extras with the kit. I thought I had lost one of the scupper covers, and there are no extras included, but I found it on the bench while installing the others. I was greatly relieved. I also touched up all the nail heads with gold paint, even though the brass color blended in pretty well. Next up is assembling and installing the rudder.
- chris watton, Theodosius, KurtH and 6 others
- 9
Mark, your stove looks great, as does the rest of your model. Your picture got me thinking though (not always a good thing). The references I have been using have the stove installed with the spit at the aft end. This would make it even tighter with the doors, which I think go between the bitt pin and the stove on this model, so the way you have it would make more sense. Lavery shows a stove in the orientation you show, although it is not labeled fore and aft. Is the stove orientation something that could go either way do you think?
- Keith Black, Dave_E, mtaylor and 3 others
- 6
Over the last few days I have been getting everything ready to assemble. I rounded the edges of the bitt pins and standards and blackened some nails for the bolts that hold the standards to the beams. I also rounded the edges on the cross piece and filed in the round indents using a half round file. I also made the hooks and eyebolts that hold the cross piece to the bitt pins. I used 28 gauge wire for these and a larger piece of brass rod for the bolts. I also made square nuts from some brass strip. To hold the hooks to the bolts, I soldered a piece of brass to one end of the brass bolts, then rough cut it to a circular shape, chucked the rod in the lathe, and rounded the brass with a file. I placed the hook on the rod, pushed it through holes I drilled in the bitt pins, and glued the square nut to the other end to hold it all together. I then glued the eyebolts into the cross piece, lining them upon with the hooks.
Today I have finally started to assemble the display for the stove. I started by gluing the bitt pins to the cross piece, clamping them together while the glue dries and clamping the bitt pins to the beam they will sit on to make sure they will sit flat to the beam.
And here is a closeup of one of the hooks and eyebolts.
Once this dries, I can start gluing up the beams and carlings, as I now have the spacing of the bitt pins which everything else will be based on.
Thank you Bob and the likes too. Much appreciated.
I spent today adding the phot etch decorations down the sides of the hull. It was a tight fit for a few of them but mostly they went in without any problems. I did have to touch up the gold paint on a few of them for spots that I had missed when I first painted them. It is very hard for me to see gold on brass when I was painting them but the light I had over the model when adding them made it easier to see the spots. I again used thin CA to hold these down and the longer pieces I did in stages, which helped a lot.
I still have to do the trim around the quarter galleries and the gun ports, so that will be next.
I finished up the bow section today. This entailed the catheads and their brackets, the head rails and their brackets, the hawse bolsters, and all the photo etch decorations that adorn them. I started using floor finish to glue the flat PE parts but switched back to CA as those that I glued with the floor finish had a tendency to fall off. I am not sure if I was not using enough or not holding them long enough so they set right. In any case the CA works great and holds the pieces nicely so I'll stick with it for the rest.
The next step is to add the rest of the PE decorations down the sides of the hull.
- Dave_E, CiscoH, chris watton and 5 others
- 8
Alan, most of the reference drawings and images I am using are from The Fully Framed Model (TFFM) series of books by David Antscherl.
I also have a sheer plan of a similar ship that shows the shape and location of the bitt pins and standards.
- Keith Black and mtaylor
- 2
Duchess of Kingston by Usedtosail - FINISHED - Vanguard Models - 1:64
I have stropped the lower shroud deadeyes and added them to the channels. I don't have any of the included brass nails left so I used some others I had around which are a little thicker, so I drilled out the holes in the strops to fit them. I did this when they were still on the PE sheet. I really liked the PE strops as I found it very easy to fit the deadeyes into them after opening them slightly.
I am now working on the masts, starting with the tops. Here I am gluing the two halves of the top platform together. Today I started gluing up the crosstrees and trestles.
