Everything posted by jwvolz
I think I'll be about an hour or so from you Bob. We are visiting my wife's parents in Stuart. My goal is to golf as much as humanly possible and just be outdoors enjoying the (relative) warmth.
- 682 replies
- halifax
- lumberyard
Hitting the home stretch Bob. I'm headed in your general direction Tuesday-Sunday. Make sure that Florida warmth is present!
- 682 replies
- halifax
- lumberyard
The 4mm x .6mm should be fine. Assuming you are going on over the lime first planking, that should come pretty close to the thickness of the walnut. I used 4mm width, can't recall thickness, but it was close to the walnut.
- 421 replies
- caldercraft
- granado
You can get the beeswax from Model Expo, though the stuff from Michael's is likely fine.
- 81 replies
- naval smoothbore
- model shipways
Run the rope over some beeswax. That will help relax it, and reduce some of the fuzziness as well.
- 81 replies
- naval smoothbore
- model shipways
Thanks. Any questions along the way, don't hesitate to ask. It's the sharing of knowledge that makes MSW so great!
- 421 replies
- caldercraft
- granado
Ah, Caldercraft kit, OK good Bob. You'll enjoy it, it's well done. Good move on the gun carriages, I wish the Syren ones had been around when I built my Granado. The one big knock I had was how bad the outer walnut planking was. It was very splintery and I'm glad I substituted boxwood above the waterline.
- 421 replies
- caldercraft
- granado
You are much better off trying to get some proper hobby paints, rather than "craft" paints. They are weak in pigment, and it is also larger in particle size so they just don't lay out smoothly. As you found, they are also thick, and when you have to thin them to brush or airbrush consistency they get weaker still and don't cover well. I'd recommend Tamiya, Vallejo and Model Master acrylics. All much better options.
Nice start. I'll be interested following along to see how it differs from the Caldercraft kit, which I thought was very nice.
- 421 replies
- caldercraft
- granado
Nicely done. Congratulations on a fine build Dave.
- 242 replies
- bluenose
- model shipways
Thanks guys. Mike: The coamings are walnut with Minwax natural stain.
- 136 replies
- caldercraft
- Cruiser
Congrats on the build, she came out terrific. I really like all the attention to fine detail you manage.
- 67 replies
- philadelphia
- model shipways
Just enjoyed reading through your log Dave, and really enjoyed it. Great work. You may have me inspired to build Bluenose for my next project.
- 242 replies
- bluenose
- model shipways
Thanks guys. OC: The color is Poly Scale TTX Yellow from their railroad line with a little bit of white added. The Poly Scale paints have been gone for a few years, but I still have a bit of a stash. They were among the nicest acrylic model paints ever, particularly for hand brushing.
- 136 replies
- caldercraft
- Cruiser
Nice work on the windlass Bob, those octagons can be tricky. Looking forward to the masting.
- 682 replies
- halifax
- lumberyard
Time for a long overdue update. I didn't get a lot done on the model over the summer, but have been busy of late. All of the aftermarket Caldercraft carronades have been assembled painted and installed on their sleds. I substituted small pieces of round styrene rod for the rollers, rather than a simple square of walnut as Caldercraft suggests. I also added breech rings from brass wire. Rather than blacken they were airbrushed with an off-black color, and then brushed with powdered pencil lead to give it a subtle metal look that I think came out rather nice. Breech ropes were then rigged and carronades installed. The two six-pounder chase guns (not sure of the source, they were in my spares collection) were installed on Syren carriages and rigged with 2mm Syren blocks. I've also completed the chainplates, which took a little effort. Caldercraft supplies the lower link and toe link as a photo-etch pieces but the middle link is open and just slips on. I had an issue with that not looking realistic, and with the angle of the chainplates they really needed to be of varying lengths, which they were not. I therefore bent some brass wire around varying sized jigs as appropriate for the angle of the chains and soldered the middle link closed. This to me looks much better. I have a Syren order inbound with hooks, so I can complete rigging of the carronades.
- 136 replies
- caldercraft
- Cruiser
Great milestone. She's looking good Tom.
- 1,348 replies
- constitution
- model shipways
Looking spectacular Bruce. Love this build.
- 67 replies
- philadelphia
- model shipways
I'm building the Cruizer now (modified) and the one negative you might find is the instruction book. As I'm on my sixth build I don't really use it, but it is quite thin and really lacking for those that need it. By contrast, the Granado book (my previous build) is fantastic. Build wise not much to choose difficulty wise between them; Granado is more ornate, but there is far less of the repetitive rigging of the carronades. You'll get lots of help here no matter what you choose.
