Posts posted by SawdustDave
Piet my friend, I thought you might enjoy this photo I took this weekend while attending Wilmington's Annual North/South Carolina Submarine Races.
This action shot was taken from the deck of the battleship USS North Carolina as they crossed the finish line.
Very intense huh?
I can get you and all of our friends tickets to next year's event.
Really beautiful work Greg.
When the mind is tired, it's time to put it down and turn out the lights Augie. Seems like we should learn that after all these years. I tend to fight it a little too long sometimes.
Like Popeye says.... "I yam wot I yam".
Thanks for dropping in.
Admiral just fed me a late breakfast....ready to roll.
Cheers
Laying in bed thinking, sometimes usually helps.
Off to a better start this morning. Looks promising so far.
Omega / Piet / Joe / Remco & Popeye.... Always good hearing from each of you.
Those little gratings are trying to kick my arsss right now. The smaller grid strips are much tougher to make .... Scrap rate about 80%! Thinkiing I should have just placed an order, but not giving up yet
Coffee set for 6:00 am....Lights out for tonight.
All caught up on your log Popeye. Looks to me like you're having way too much fun here mate. It really does look like a fun build for sure. Nice job.
Dave
You've come a long way since my last visit Omega. That is a heck of a fine job. I am blown away with the clean lines and sharp detail you have achieved at scale 1/192. Way to go!
Dave
Progress on the beakhead construction is beginning to take shape. At least I can finally enjoy seeing the last of her decorative colors now installed. Both sides of the panels have been planked with a thin vaneer of bamboo strips.
My personal opinion, this is the most challenging part of the Mayflower construction....and possibly the most fun to do.
Thought it would be a good time to show the inboard side of these stanchions at this point, prior to pressing on with completion of the grating and adding the port side top panel.
A closer view of the stanchions. I am nailing each stanchion with steel wire to add to their strength.
- riverboat, russ, popeye the sailor and 7 others
10
Good solid mechanical method Nigel. That method works best if done prior to planking the hull, or even installing the bulkhead.
I just couldn't come up with a solid way to clamp a block to the narrow deck. Thankfully....managed to carefully "creep up" on it without doing any damage.
Thank you and Pete for your visit.
My dear friend Omega....as much as I admire your pure intentions, I personally think you concern yourself too much with an issue that only you could possibly identify. Not being a purest by nature, it is difficult for me to relate to your dilemma based on what you said regarding your abilities to modify the plans of the Ticonderoga.
Besides that, I don't see that you have any other option.
What scale?
Dave
- Omega1234, Robert29 and Dimitris71
3
Very nice Klaus....not too far behind you. Your log is very inspiring....thanks.
Dave
I would bet that drill bit (mine) must be at least 20 years old. Comes in real handy once in a while. Thanks for your frequent visits Popeye. I always enjoy hearing from you.
Nice work Toni....the re-painting of the wale came out sweet.
Took a quickey shot of the re-planking of the beakhead bulkhead after I spent most of the morning drilling out the opening for the bowsprit (finally got up the courage).
Note, the shade of the bulkhead planks appears to be a little washed out....that is due to the angle of the overhead light used to get this shot. I'm not the greatest photographer.
Any of us who have ever done this knows the challenge of getting the precise angle and hole size through the planking without damaging the deck or the bulkhead. The process can definitely get a little harry.
The second photo shows the different tools I used to begin very small and work my way up to an opening large enough to insert that 18" long drill bit and begin measuring and adjusting the angle.
Final shaping was done mostly using the rat-tail file and the small Dremel rasp bit shown.
Now, we shall move forward with the entire beakhead.
- NMBROOK, SkerryAmp, usedtosail and 8 others
11
Been so deeply involved with my little project (thanks for your many visits), it took me a while to catch up from my last visit Piet.
Totally blown away here. Your log is absolutely captivating. You are such a gifted story teller, along with your amazing skills as an artist. I'm thinking it will be a day of celebration, mixed with sadness when you make your final posting and declare the O 19 done.
Along with your many friends I salute your excellence.
Dave
Omega....I think I can get by with putting a thin veneer bamboo planking over top of the walnut. Might decide to leave the doors as they are. Contrasting colors might be a nice look.
Took the Admiral out to IHOP for breakfast and grocery shopping.... About to head to the shop and attack this little setback.
Finally got around to treenailing the beakhead deck and bulkhead....then realized something ain't right here. Then it hit me....the bulkhead planking should be bamboo....the same as the hull planking.
The walnut strips seen here were applied prior to my decision to use bamboo to cover the hull.
Just another do-over walk in the park.
Hr. Ms. O 19 1938 by Piet - FINISHED - scale 1:50 - submarine of the Royal Navy Netherlands in service 1939 - 1945
Such a fun build to watch.
