Landlubber Mike
Everything posted by Landlubber Mike
  1. Looking really great Glen, wow! That wheel is incredible. Glad the BMF worked!
  2. Not yet Kevin. All the steps needed to address the warped keel, as well as lining the gunport, burned me out on it and I ended up trying out plastic models. At some point I plan to return to it, but likely will finish my Pegasus first. If you're looking for a nice subject, this kit is a beauty.
  3. Glen, those paddle wheels and housings are fantastic. Even more impressive at the scale you are building. Nice job man!
  4. I used Wolfpack's wing fold set for my FM-1 build. Obviously not a full kit, but I thought it was very well done. My guess is their Catalina kit will work into a nice model as well.
  5. Hi Glen, this is sure to be another stunner. Looking forward to following along! In case you are looking for adhesive foil, you could try Bare Metal Foil - car (and other) modelers use it and it comes in various metallic hues:
  6. Looking great as per your usual high build quality Chris. I've always liked the looks of this plane. Looking forward to the end result!
  7. Awesome job! Cool you could find a model for your first car! Mine was an old Nissan Sentra - not as cool as yours
  8. Really nice job Alan! I recently picked up that Dspiae stabilizer as well. I haven't had a chance to use it yet, but even though I have pretty steady hands at the moment, there have been times where this would have come in handy.
  9. Fantastic job! Really well done. Seems very fragile, so hanging from the ceiling is a good idea.
  10. Nicely done! @ccoyle - maybe we should have a SIB forum here on MSW? @Glen McGuire has a number of builds he's kindly posted already, and a few of us others have SIB builds we've posted as well.
  11. In for this one Dave. Will be interesting to see if the WNW quality transferred over to Kotare - hope it did!
  12. Just caught up with your log Dave - well done!! What a cool color scheme! I bet it attracts a lot of attention in the display case.
  13. Thanks Roger, I'll have to look into that. Appreciate the suggestion!
  14. I blame you for getting me into seaplanes 😝 The JRS-1 at 1/72 is a pretty big model with the wingspan as you know. I also have a 1/48 PBY-5a kit that I was thinking of starting soon - mostly to free up shelf space as it is a big box, but then the question is where do I put it as that’s a big one for sure. If you want a really big seaplane, Revell I think is reissuing the Bv 222. The model is really nice and doesn’t really require any aftermarket. I’ve got that one but again, will need quite a bit of space for it. One thing I was thinking was to do a cutaway on a 1/72 Emily since there is a lot of aftermarket that could make the interior look pretty impressive. One side would have full exterior and wing with mechanics, etc. and other side would be open with pilots and gunners, with only a portion of the wing attached. That would cut down on the overall size. Just need to find time!
  15. Hey Lou, the kit comes with some PE, but Eduard also separately sells (or at least used to sell) this PE set which adds PE seats, engine wiring, handles, and the details around the wheel wells. If you can find it, I think it's worth considering: https://www.eduard.com/eduard/jrs-1-upgrade-set-1-72.html?cur=2&listtype=search&searchparam=jrs-1 The cockpit area is definitely problematic. I added some plastic shims and it seems like the fit shouldn't be too bad. Other people seem to have had a devil of a time trying to fill the gaps though. It's just a little tiring spending hours to get pieces to fit right. It's also looking at pictures of the real thing and realizing that certain details are either missing or incorrect that just add to the list of things to do. And then there are lack of connection points which means you have to either add them or be very careful to not later break pieces off. You should definitely build it though, the subject is really historically important and there are plenty of schemes to choose from.
  16. Hi Lou, great to hear from you and thanks for the kind words. I have the following book which has a lot of great pictures of both the civilian craft (including the Howard Hughes plane) and the military craft. It's definitely worth buying if you're going to build this kit I think. Interestingly, the interior of the military craft looks very similar to that of the civilian craft, down to the interior curtains. I decided not to open the model up in part because I wasn't too certain about whether the interior from the kit was accurate or not. For the wheel wells, the photo etch actually adds some nice detail like the rivets and the panels which seems very consistent with the pictures I've seen of the actual wells. The PE is also really helpful to cover up that dreadful, hard to get to, ejector pin mark in the deep recess of the well. Though, this is not an issue if you use the CMK wheel well replacement parts which actually fit better. The kit is ok, and the CMK set is a nice add-on, but things like the need to clean up pretty much every piece, as well as the fit of the pieces, including the windows, the canopy, and the engine cowlings, make this a bit frustrating. There's also the issue of no interlocking connecting points for the wing and tail struts (as well as a number of other detail parts) which is annoying. Then there is the matter of certain details that are helpful to add, like the nose center rib in the book picture above, and the location and angle of the antenna mast in the center wing that is different from plane to plane. Also, the tail wheel in the kit looks nothing like either of the two versions of the tail wheel on the real thing, so of course now that I've seen the actual pictures (the book above has great close-ups) I feel obligated to scratch build a more accurate one, though not really looking forward to it. I've started to lose interest in finishing the model, but am going to try to push through to get it finished by the beginning of June for the group build on LSM. It didn't help that the model took a nose dive off the table last week and three of the interior windows fell off. Thankfully the top two pieces of the fuselage had also loosened, so I was able to take them off and reinstall the windows. If it was one of the windows further back I probably would have had to junk the model. If you end up building the kit, I'd probably try not to be as OCD as I have been and just enjoy building it.
  17. Another creative SIB build and display Glen!! Amazing job! Love the details, especially that little penguin!
  18. Just asking as I ended up getting the third of the three kits recently. I'll probably build the two alongside the kit Lou graciously gifted us in the near future.
