Everything posted by Landlubber Mike
Glad to get your interests piqued! Would love to see your desert camo work! In other news, after some prodding by the folks on LSM, I've decided to do a second diorama of the desert Hs 129B-2. First will be the one I'm currently working on, with all the aftermarket, things opened up, etc. Second will be a recreation of this scene below of a Hs 129 B-2 "Blue C": I already have an Opel Blitz truck in the stash, and building this Hs 129 will be fairly quick as I won't need much aftermarket, particularly since the nose, cockpit, and nacelles are covered by tarps, and I won't need to include the wings. A couple of hours ago I managed to pick up an older Hasegawa B-1 kit off eBay for a really good deal. The B-1 and B-2 were very similar, and essentially the two kits are the same minus different nacelles (which will be covered up by the tarps). Along with the great price, the B-1 kit has a decal for an "O" which I can use as a template to create a mask for the Blue C. The camo is a little easier to recreate, so I can practice on this second one before the the more complicated first one.
Looks like I'm not the only one with multiple projects in the hopper This is coming along great Alan. Glad you figured out the door/ramp as a solution for the tail sitting. Did the instructions tell you how much weight to put up front? I've seem some models out there where people talk about putting all this weight in, but I never quite figured out how they knew how much to add given that they close the fuselage after the weight is added.
EG - not sure if you saw, but Roden apparently makes a 1/72 Curtiss H-16. Very similar, except has the Liberty engines, a different cockpit window configuration, and some other bits and pieces. The Roden Curtiss H-16 boxing is essentially the same as their Felixstowe boxings minus a pair of new Z sprues and the clear parts sprue. I'd love to do this fish version!
Last night, I started work on the cockpit. The CMK set has a nice replacement tub that includes the fuel tank behind the pilot's seat. To display the fuel tank, you need to cut off the part of the fuselage that covered it, which you can see in the top fuselage half below: Next up was trying to fit the CMK tub. It was a bit too big for the fuselage halves to close properly, but after sanding back some of the interior of the fuselage and portions of the tub that will not be visible, it fit nicely: Thanks for looking in!
Hey Alan, after my marathon sprint on my JRS-1, I've been catching up on everyone's build logs. This came out great! Roden kits can be really tricky from what I've heard in terms of fit and decals. You did a nice job for a difficult kit! I think I mentioned this on my JRS-1 log, but if you ever want to do your Roden Felixstowe, I have two and could build alongside you if you'd like. I think you mentioned you have a Roden Gotha as well - if you build that one, I can build my Zeppelin Staaken and we can tackle the two beasts together. A couple of things I thought I'd pass along, though feel free to ignore this unsolicited information. For filling gaps and holes, I use different materials depending on the situation mostly to deal with potential shrinkage. For small holes or cracks where shrinkage doesn't matter, I use Tamiya putty - I've also used Vallejo putty, Mr Putty, and CA (some people use black medium/thick CA so they can see what overflow needs to be sanded off which seems like a good idea). I've actually started using CA more and more for small gap filling, as you can add it to an area, and before it's fully cured you can start sanding off the excess fairly easily making cleanup fairly simple. Larger gaps are always tricky. I usually try to stuff thin pieces of plastic in the gap to fill up as much as possible. In some cases, that can be enough or you can fill the remainder with Mr. Putty, CA, etc. On my JRS-1, I also started using Tamiya's two-part epoxy putty. That is now one of my favorite approaches to larger gaps or even to build up areas where there is a depression because it (1) doesn't shrink (or at least doesn't appear to), (2) it is very strong and won't crumble, yet when dry sands very easily, (3) takes a while to dry so you can take your time working it into the area, and (4) isn't messy like Tamiya putty. I guess like all materials, it's just getting used to the strengths and weaknesses of the products and having a little experience on what works best in certain situations for you. On the metal finishes, I really love Vallejo's Metal Colors for their ease of use, clean up, etc. For me, it will spray perfect 98% of the time, but then there are times when it just doesn't look right. Sometimes that's a result of spraying too high of a pressure or too close, where it's almost like the paint doesn't want to adhere properly so you get a weird darker spot. Once I learned about the pressure/closeness issue, I made sure to avoid that and still would occasionally get those odd spots. Not sure what caused it - maybe oils from my fingers? Who knows. For my JRS-1, I tried Mr Color Super Metallic 2 series. I absolutely loved it - sprayed really easily and evenly, and as a lacquer, but on a good hard shell for decals, taping, etc. I sprayed it over a base coat of Mr Color GX 2 Ueno Black per recommendations I saw online and was very happy. So, I think that line of Mr Color will be my go-to for larger areas where you need a pristine finish like fuselages. I'll continue to use Vallejo on smaller items like engines and the like. Also, I was able to use the Vallejo paints to do some minor touch ups on the Mr Color and it worked perfectly - I found you can brush paint the Metal Color paints, but the Mr. Color paints aren't meant to be brushed. For what it's worth, apparently, there is an earlier line of Mr. Color metallic paints that are meant to be buffed, but I forget what those are. Anyway, I'm still very much in the learning phase on all this, but thought I'd pass along what I learned on my last couple of builds. Looking forward to your next one!
Oh wow, a 1/32 US catapult? Do you have the Kitty Hawk kit? That would look really cool. I'm planning to put my Walrus on the NeOmega catapult, and also have the HpH catapult for my Arado and the NeOmega catapult for the Hurricane. I think these seaplanes look really cool on catapults, which ends up being a nice diorama setting for the model. For biplane yellow wings, I have some of the old 1/32 Hasegawa and Williams Brothers kits, along with some from Silver Wings and Lukgraph. I really like the interwar paint schemes.
Hey Lou! I know i complained along the build, but looking back, it wasn't too bad. Although there were lots of fit issues, particularly with the canopy and windows, I think most of it probably boiled down to me having a lack of experience on tackling these types of issues, along with the time pressures of getting it done before the expiration of the LSM group build. The scratch landing gear itself probably took me 20 hours to do, mostly because I hadn't used a lot of the materials before. All in all though, a fun build that turned out nicely that taught me a ton. This will help me go back and finish the Vindicator and Buffalo that I stalled on, as I wasn't sure how to approach certain areas of the builds. Also, I have a Pro Modeller PBY-5A kit in 1/48 in the stash that I wanted to start, but worried about hearing all the nose weight one needs to include yet the landing gear tends to collapse - now that I scratched it on the JRS-1, I think I feel comfortable scratching it for the PBY-5A. On other flying boats, you definitely gave me a case of hives with a lot of itches to scratch. I have quite a few flying boats in the stash as I find them quirky yet very interesting. Sorta like how I prefer to model IJN auxiliary ships over the typical warships you see. Except for two, I've always bought them second hand at significant discounts from retail, though the aftermarket usually ends up making up the difference and then some. Here are the ones I have in the stash - would love to see your list! US: Sikorsky S-38 and S-39 (Czech Master Resin 1/48), J2F-5 Duck (I Love Kit 1/48), Grumman Widgeon JF-1/JF-2 (Signifer 1/48), Grumman Goose (Signifer 1/48), PBY-5A (Pro Modeller 1/48), OS2U Kingfisher (Kitty Hawk 1/32) Japanese: F1M2 Pete (Hasegawa 1/48), H8K2 Emily (Hasegawa 1/72) UK: Felixstowe F.2A (Roden 1/72 and WNW 1/32), Sunderland Mk. III (Special Hobby 1/72), Walrus (Airfix 1/48 and HpH 1/32) German: Hansa Brandenburg W.29 (WnW 1/32), Dornier Do 24T (Italeri 1/72), Blohm & Voss BV222 (Revell 1/72), Arado Ar196 (Revell 1/32). I also have a Ju 52 kit that I might use a conversion set for to add floats. French: Caudron Hydravion (Copper State 1/48) Ouch, that's a lot more than I thought I had. I need to be more efficient on my builds 😵💫
Thanks Alan! Hoping it goes well! Thanks EG! It would have been fun to try and model that scene - flat tire and all - but I have a lot of aftermarket to open the plane up so I probably will just model it undergoing maintenance or something. There are some other cool pics out there of US and UK soldiers coming across fields of wrecked Hs 129s in Tunisia. That would be another fun diorama to try out.
