Landlubber Mike
Everything posted by Landlubber Mike
  1. Thanks Spyglass - I'll add some blocks which should help. Thanks for the tip on the threads. I did do that when setting the nuts, and they turn freely thankfully. I'm also planning on adding the stern post after the second planking. For the stem, using long planking pieces I thought it would be easier to start by setting the planks into the rabbet, then work them around the hull, and filing off the excess after the second planking. It didn't seem necessary to have the planks extend and get filed back at the stem as well if you have a rabbet, but I'll find out soon whether that was a good idea
  2. I thought about doing it that way for that reason as well, and if I remember correctly, Bob Hunt's practicum recommends installing the stem after the first planking is installed. It didn't seem to make much difference to me if I installed the stem before the second planking or before the first, so I just went with installing it now. Plus, I wanted to get the keel pieces attached to fix the nuts in the main keel, and it just seemed more logical to add the stem so that the keel pieces were positioned correctly. I'm hoping the rabbet helps make for a clean joint between the planking and the stem, but we'll see. On my Badger I had a heck of a time with the planking at the stem, but I hadn't cut a rabbet nor had I pre-shaped the planks. This time I plan to pre-shape the planks which should help.
  3. Thanks guys. I didn't sand the char fully through, but it seemed to have been fine just taking off most of it. Spyglass, that's an interesting approach on installing the stem later in the build. I'll have to think about that one for my next one. On the holding blocks, my nuts are wider than the 5mm keel, so if I added blocks on either side I would likely have to carve a groove into them. The nuts are really epoxied in - I first added epoxy to the side and bottom of the nuts, and then once they were glued in tight, I added epoxy along the exterior to further seal them in. I'm using the same stuff (Gorilla Glue 5 min epoxy) on some gardening equipment, and despite all the abuse, the epoxied parts are not going anywhere. That being said, rather than putting blocks on the sides of the nut, I was thinking about small blocks of wood above the nut inside the slot on either side of the screw path. That would help restrain the nuts from popping up, which I think is more likely than the nuts popping from side to side.
  4. Quick question - the kit uses laser cut parts. I've seen some logs where the builder sands off the charred areas for the purpose of ensuring a stronger glue bond. Is that necessary? I sanded off the char on the pieces I glue to the keel thus far, but maybe I should have tested gluing them without sanding. Interesting thing is that it smells like burning wood as you sand off the char.
  5. Small update on where I am now, which mostly involved preparation of the main keel. I carved the rabbet and sanded the bearding line. The MDF is interesting to work with - it was very easy to chisel the rabbet and bearding line, as the layers just flake off with little effort. Sanding on the other hand seems much more difficult than if you were to sand plywood. That should make fairing the bulkheads a real pain - I'll probably start with a sanding block, but I have a feeling that I will end up resorting to the Dremel or other power sanding tools. I also epoxied nuts into the hull for the pedestals. I'm using two-inch #6 machine screws, which seem to work very nicely with the brass pedestals I bought from Model Expo. Installing the nuts was actually easier than I expected. The only issue that I ran into is that I goofed in installing them before I added the keel pieces. It would have been a lot easier to drill the hole in one shot, but instead, I had to guess where the line was, and then ream the hole a little larger so that the screw had a clear path to the nut. All in all, it wasn't that difficult though. You'll see that I installed the stem and keel pieces at this time. I went back and forth on whether to install them now or wait until after the first or second planking, but I thought that fitting them at this stage would make it much easier to ensure that the pieces were perfectly centered on the main keel. I also decided to go with a black stem on this build, and used the General Finishes black stain that I tested earlier. I was am happy with how it looks - a deep black, yet it doesn't have the "plastic-y" feel of a painted surface. It also is easier to apply than paint, where I just used a piece of an old t-shirt to apply the stain and then wipe off the excess. I did two coats, but I probably could have gotten away with one. It's probably hard to see in the picture, but I have to add some shim pieces to the keel at the two connecting joints. The pieces fit nicely together, but there was a slight gap. I thought it would be a stronger bond to clamp the pieces at the joints, but now there is a very slight dip along the bottom of the keel at the joint. So, I'll glue a small piece at the joint and sand the keel to a straight line. I'm still debating the timing and general approach to replacing the visible bulkhead extensions with other wood. I'm itching to glue the buikheads to the keel now, but it probably is easier to take care of replacing the extensions now, while the bulkheads are off the model.
  6. Really amazing work Bob. Kudos to you for sticking with this kit through the various issues. I noticed that ME's latest catalog didn't include the Essex - hopefully they have worked out all the kinks.
  7. Very nice Joe. It sounds like it was a good decision to wait for Jeff's wood as opposed to working with the kit supplied strips. I haven't worked with his boxwood yet, but his pear has been a perfect wood to work with.
  8. Thanks for sharing Martin. I'm curious what you think about the RB guns versus Chuck's guns. I think BE and Alistair concluded that the RB guns are probably perfect to scale, but it looked to me like Chuck's guns would be fine as well. Since you used the heartwood for the capstan, are you thinking about building the gun carriages out of heartwood as well? I was hoping to avoid that, but if I'm going to use redheart for the bulwark planking, I don't know if I can stain the gun carriages to match the redheart and don't want different shades of red on my build.
  9. Thanks very much my friends, I really appreciate the kind words. This hobby is amazing, but equally amazing is the meeting of many nice friends all over the world. I feel very fortunate to have stumbled into the world of ship modeling
  10. Very nice work Martin. I like the use of the specialty wood - it gives a nice red color
  11. The golden mean sounds like a good one. I'm trying to use as much of the kit as possible too, but it seems like I find more stuff to replace. I just placed an order with Jeff at Hobbymill for the Pegasus and for some supplemental wood for my Unicorn, and the cost does add up (thankfully, I've paid significantly below retail for these kits). I think once I finish the kits on my shelf, I'm going to move towards buying good plans and go into scratch building. My Unicorn is almost looking like a complete scratch build outside of using the kit bulkheads
  12. Hi Martin, I believe that I bought the General Finishes stains from Woodcraft (online). They have lots of different shades, as you can see here: http://generalfinishes.com/retail-wood-finishing-products My best success for the black was using the "stain", rather than the "dye stain." Maybe I needed to stir the dye stain a little more. They have some interesting colors for ship building. For example, they have a yellow that seems like it could work nicely as a yellow ochre replacement. The great thing about using stains is that you don't get that painted on texture. Some people thin down paints and paint 20-30 coats, but I'd rather put on one or two coats of stain and be done. I'm not sure what I want to do with the bulkheads yet. The downside of stains is that you don't get an even color across different wood types. I'm thinking of removing the bulkhead extensions, and replacing them with stained wood of the same type that I will use for my bulwark planking and cannon carriages. Still thinking about whether to do that before the hull planking, or after it.
  13. In my quest to avoid using paint, I spent a little time experimenting with some black stains and dye stains that I had samples of - Varathane 'Ebony', General Finishes 'Black" stain, and General Finishes 'Ebony' dye stain. I also have a small amount of Fieblings Leather dye, though we all know that works well to dye pear so I didn't test it. It's always hard to accurately get the full effect of color on a digital picture, but here is a picture of the test - the big board is plywood, the small pieces are scrap pear, the longer dowel is from the Corel Unicorn kit (I think beech) and the smaller dowel is from the Pegasus kit (ramin). I didn't bother to test the Varathane on the smaller dowel as it didnt have as much penetration as you can see. The results of just trying one coat are interesting. The GF black stain worked the best - very deep black that looked like the wood had been painted. The Varathane and the GF dye stain were more like your typical stain effect, where it mostly highlighted the grain. I would have thought that the GF dye stain would be the best, as GF markets the dye stains as having deeper penetration. Maybe I needed to mix it more, I'm not sure. I really like the GF black stain - you end up with a deep painted look, yet the wood texture is not hidden under a layer of paint. Just the look I'm after. In any event, I thought I would share in case others are interested in a black look without using paint.
  14. In my quest to avoid using paint, I spent a little time experimenting with some black stains and dye stains that I had samples of - Varathane 'Ebony', General Finishes 'Black" stain, and General Finishes 'Ebony' dye stain. I also have a small amount of Fieblings Leather dye, though we all know that works well to dye pear so I didn't test it. It's always hard to accurately get the full effect of color on a digital picture, but here is a picture of the test - the big board is plywood, the small pieces are scrap pear, the longer dowel is from the Corel Unicorn kit (I think beech) and the smaller dowel is from the Pegasus kit (ramin). I didn't bother to test the Varathane on the smaller dowel as it didnt have as much penetration as you can see. The results of just trying one coat are interesting. The GF black stain worked the best - very deep black that looked like the wood had been painted. The Varathane and the GF dye stain were more like your typical stain effect, where it mostly highlighted the grain. I would have thought that the GF dye stain would be the best, as GF markets the dye stains as having deeper penetration. Maybe I needed to mix it more, I'm not sure. I really like the GF black stain - you end up with a deep painted look, yet the wood texture is not hidden under a layer of paint. Just the look I'm after. In any event, I thought I would share in case others are interested in a black look without using paint.
  15. Hey Jason, thanks very much. I definitely could adjust the stem by lowering the seat a bit for the figurehead. I need to take a closer look at it, but it might be a crest or shield or insignia or some type. It might be a bit tricky to lower the seat, but I think it could work. Or, I could just build another stem
  16. Thanks SpyGlass. The barrels do seem a bit on the shorter side. The test carriages that I stained didn't take the stain too well. I might try a sanding sealer (I think that's what it's called) for better results.
  17. Really gorgeous work Mark. I was just going through your galleries - you are very skilled, thank you for sharing!
  18. Thanks John and Ian! I'm not sure what I want to do with the quarterdeck guns. I haven't found much info on the 3-pounder guns - I assume they are just smaller versions of cannons on carriages? I bought from CMB some smaller Caldercraft cannons and carriages, along with smaller versions of the Corel cannons, which might work. With the tiller on the quarterdeck, I imagine that the 3-pounders would be placed somewhere along the first three or four portholes. The fourth porthole might be a bit dicey with the mizzen mast almost in the line of the portholes.
  19. I've been playing around with the upper deck template, and put together a cannon just so that I can make sure that the upper deck sits correctly. On this kit, the bulkhead extensions have notches in them to mark the upper and lower edge of the cannon ports. While dry fitting, the upper deck template seems to be at the right height at the front and rear of the ship as the gun fits right through the middle of the framed section, but the middle seems a bit too high. I have to figure out whether this means that I need to file down the middle bulkheads so the deck template sits lower, or whether I need to run the frames at a different height from the bulkhead notches. I think this will depend on whether the bulkheads are at the right height or not. It could all just be a matter of filing the edges of the deck template so that it fits a little flatter. Unlike the vast majority of the kit that I am scratching, I have been planning on using the kit's cannon carriages as they are in one solid piece (so not as much construction) and seem to be very clean parts. I plan on using red stain on them as in my earlier pictures, and using walnut for the the bulwarks and similarly staining them. In taking a look at the test cannon, it seems like the cascable sits a bit more forward on the carriage than I would have thought. I took a look at the guns on my Badger, and the cannon cascabels are pretty much in the same location. But, in looking at other pictures, the cascabel is at the very end of the carriage or even extends beyond it. Here are some pictures: I'm curious if others have a strong reaction on the accuracy of the cannons. In some respects I'm not too concerned as most of the cannons will be hidden, even at the waist when I add the small boats. I'm also not planning on adding the 9-pounders to the quarterdeck, as the ship originally started out with 24 9-pounder guns on the upper deck, and only later (in 1756) were the four 3-pounders added to the quarterdeck. Instead, I will add the tiller and maybe some swivel guns to the quarterdeck.
  20. One other difference between the two ships is the figureheads - the Lyme's is a lion. I might try scratching a figurehead, but in the event that I fail at producing a good enough one, I searched around for a suitable figurehead as a backup. It was a bit hard to find one that was the appropriate size and style, but I ended up ordering the Mordaunt figurehead from Euromodel. They were kind enough to let me order one even though I didn't meet the minimum order requirement on their website. And to boot, I got to correspond with Peter on here who lives in Australia and helps out on customer service - a really nice fellow who has been kind enough to post his practicums on the Euromodel website. Well, the figurehead arrived today and looks like it will work perfectly! I will likely need to tweak the stem a bit and maybe the figurehead a tad as the lion is holding something between its paws that I might consider removing (and a crown as well, that I might think about removing), but overall, it looks like it will work out very nicely. Most importantly, the figurehead comes with a cut out in the back and bottom to slot it onto the stem. The cut out is 5mm wide, so it fits my 5mm stem perfectly. The problem with the Unicorn figurehead is that in some areas, the figurehead is 5mm or less in width, making it harder, if not impossible, to cut a slot to fit it onto the stem. So, the kit's instructions have you simply glue it to the front end of the stem, which is not really correct as figureheads sat on or straddled the stem. It's rare that things work out so nicely like that, so I'm very happy right now. Here are some pictures showing the details of the figurehead relative to the Unicorn's figurehead (minus half a horn!), and also a test fit on the stem. The figurehead should actually sit a little lower, but the thing between the lion's paws is preventing it from moving further down. But, this gives a good idea of what the figurehead will look like.
  21. So, I made the decision to build the ship as the HMS Lyme, the sister ship to the Unicorn of the Lyme Class (the Unicorn and the Lyme were the only two of the class). Although I liked the idea of building a beakhead ship, I decided on the Lyme for a few reasons. I liked the shape of the galleries of the Lyme, which have less of the cathedral look than the Unicorn (and I think they would be easier to scratch build), and I liked the transom decorations a little more. The fact that I have the NMM plans also makes me more likely (hopefully!) to build a more accurate model. Finally, building the Lyme with the full plans helps me to avoid some of the issues associated with the Corel kit - namely, the fact that the first bulkhead is too far back as Ian pointed out, and what to do on the quarterdeck rails, or lack thereof. Of course, another good reason is that I think I will have the only Lyme out there, and so my work won't be compared as easily to the really good work of Ian, John, ZyXuz, Olly, Peter, etc. - or at least I can always use the excuse that I'm building the Lyme and not the Unicorn
  22. Hi Frank, hope you are feeling better. Really gorgeous work. Is the lighter wood you used for the upper hull planking from the kit? I have a Corel Unicorn kit that I'm working on where I'm going to go with pear for the hull planking, but in seeing your pictures, I'm going to have to save those planking strips in my kit (if my kit came with them) for another build
  23. It might help knowing what ships you're thinking of. I've bought directly from Caldercraft and Model Expo before with no problems whatsoever. I also have ordered parts from Cornwall Model Boats in the UK, and have had a very good experience with them as well.
  24. Hey Ian, welcome back. Thanks for all the tips on the small boats. Interestingly, the AOTS Pandora shows the ship with five small boats - a 28' pinnace, a 24' launch, two 22' yawls and an 18' jolly boat. Going from port to starboard, the ships sat three abreast in the following order: (1) 24' launch with 22' yawl nested inside; (2) 28' pinnace; and (3) 22' yawl with 18' jolly boat nested inside. Looking at B.E.'s log, if I scratched 5 small boats I would probably be looking at an extra five years to my build The other issue is that having three small boats abreast like that substantially covers the entire area of the waist, so one would not be able to see all the details.
  25. Higher quality lamps are definitely not cheap. I spent a little more money and bought Electrix brand lamps off ebay to save money (I think the 7122 and the 2246 models). One is just purely a 100 watt bulb, the other has an incandescent and circular fluorescent bulb with a built in magnifier. I really like them, and haven't found any of the clamp issues that are reported on Amazon with mine. When I did research on lamps with extending arms, the biggest complaint was that the cheap ones wont stay locked in position. To me that was annoying, if not potentially dangerous when using power equipment.
