Everything posted by Jack12477
Never was any good at "circumlocution" !
- 140 replies
- the sullivans
- trumpeter
I stand corrected ! USS England is NOT at Battleship Cove. Don't know why I thought that, maybe too much of O.C.'s rum! Thanks, Lou, for the PM.
- 140 replies
- the sullivans
- trumpeter
Hi O.C. welcome aboard. Yes, we may need lots of rum for this voyage.
- 140 replies
- the sullivans
- trumpeter
That was easy! They cast it in glossy red plastic, which just had to be repainted. At least the rest is cast in dull grey.
- 140 replies
- the sullivans
- trumpeter
The real USS England is at Battleship Cove in Fall River, MA, couple hours drive from me. Maybe a road trip.! Right now I'm trying to figure out the kit instructions, which only have pictures, no prose, just a bunch of part numbers and no explanation of what the part is. Some I can figure out but not being a Navy vet (Army vet) my knowldge of ships is somewhat limited. Right now I'm trying to figure out what PE part replaces what plastic part. But I will muddle thru.
- 140 replies
- the sullivans
- trumpeter
Probably going to do her as she appears today in Buffalo, Lou, since I have some photos and can easily get more. There's a WWII Destroyer Escort (last one still floating) berthed in Albany NY, about 50 miles from me, the USS Slater, which if I can find a suitable kit, I would like to model. She was repainted a couple years back in the razzle dazzle camo. What is slowing me down right is figuring out how to do the PE mods, so I am going a lot slower than I normally would with the plastic. Wood is easy to re-do, plastic not so good.
- 140 replies
- the sullivans
- trumpeter
Pictures just for Carl ! The wood block in the center of the hull is to attach the two 1/16 inch diameter brass tubing that will support the model in the display when completed. The 3 sections of the hull/deck combo are just dry fit together for now. Some touch up is needed on the black boot. The grayish cast on the red hull bottom is the lighting for some reason, not weathering.
- 140 replies
- the sullivans
- trumpeter
Well after opening up the sealed plastic bags and examining the parts sprues most closing, it appeared I did not have any or enough anyway doors and deck hatches, so I placed an order for another sheet of Tom's MetalWorks PE; those arrived Friday (almost overnight delivery). Then I spent the weekend looking thru the online catalogs of 3 US based Hobby "stores" for paint in the colors used in WWII. Very tedious task. After hours of looking at every paint brand I could find I finally located a set from LifeColor that exact matched the colors I was seeking, comes in 2 sets of 6 colors each. Ordered them, but it will take until 11/20 (next week sometime) to ship them to me from Atlanta, Georgia. Not like the next day delivery of the PE from NJ. In the meantime, I have been painting the lower hull with Vallejo hull red (4-5 coats) and upper hull with some old Poly S (water base) Light and Dark Ghost Grey (several coats). Haven't rolled out the airbrush yet, so far just hand brushing with pretty good results.
- 140 replies
- the sullivans
- trumpeter
Kop and I cross posted. His lights are rated at 5500K aka 5500 degrees Kelvin, in other words daylight. I forgot to mention "tungsten" light is 3200-3400 Kelvin
- 467 replies
- mikasa
- wave models
I use a looooong rollup window shade in a setup like Kop is using; for lighting I use a goose neck type lamp with a 100 watt daylight rated LED. For reflectors you can use a large piece of cardboard covered in standard kitchen aluminum foil (don't make it too smooth a little crinkled is good) In my case the window shade is attached to brackets attached to the floor joists in my cellar . Kop is using background paper instead of a window shade, either will work. Use a white or very light grey shade. Yes, those umbrellas are reflector/diffusers. The tissue over the flash cuts the intensity. With Kop's setup you can control intensity by just moving the lights or using a lower watt bulb. Two lights eliminate shadows. The reason for daylight LED is so you don't have to adjust the white balance on your camera/phone which defaults to daylight. Indoor lighting, called tungsten, is rated at 3200 degrees Kelvin, daylight is 5600-5800 degrees Kelvin. If you use ordinary indoor lightbulbs (tungsten) without adjusting the white balance the photos taake on a yellow or amber cast. Just look in the lighting section of Lowes or Home Depot for the LED bulbs, check the rating on the package. They are the standard "incandesent" replacement bulb .
- 467 replies
- mikasa
- wave models
Kop has the right setup, the Amazon is good for a really serious Amateur photographer. Keep it simple and inexpensive. Only thing I would add is make sure the LED light bulbs are labeled DAYLIGHT and not Cool White, affects the color rendition. BTW I am a amateur photog with experience.
- 467 replies
- mikasa
- wave models
Christmas tool gifts???
Jack12477 replied to CPDDET's topic in Modeling tools and Workshop Equipment
I found the Veritas miniature planes from Lee Valley a worthwhile investment. I use them frequently to thin planks and smooth off the hull. I have their entire miniature collection bought in ones and twos over time. Also Chuck's SYREN Seizing tool is a good investment. Also WeCheer makes a small corded and battery powered miniature drill which takes all Dremel 1/8 inch shank accessories. It's offered by WoodCraft. Excellent alternative to the larger Dremel tool -
If you're going that route, Carl, I'd prefer a Redbreast 21 year old single malt pot still! Or a Redbreast 15 year old !
- 140 replies
- the sullivans
- trumpeter
Better get yourself into a bos'un chair, Carl, it's going to be a while before the PE shows up. Wouldn't want you to lose your finger nails.
- 140 replies
- the sullivans
- trumpeter
Not only is your model impressive but so is the close-up photography. Great work on both !
Well, the "newbie" to PE just encountered his first screw-up. While looking over the kit and PE parts, I discovered that the PE enhancement kit does not include doors or deck hatches, those are in a separate package. So it's back to MegaHobbies for the remaining parts. (what's that old saw about a ship being a big hole in the ocean into which you pour money ) In the meantime, I can work on prepping the hull and deck for priming and painting while I wait for the order to come in.
- 140 replies
- the sullivans
- trumpeter
Kevin, Denis, Ken, Greg, Ryland, welcome aboard. Greg (@RGL), you've set a very high standard to follow. Glad to have you along for the build. Chris (@ccoyle), drifting a little off-topic is okay with me as long as we don't get too far adrift.
- 140 replies
- the sullivans
- trumpeter
Mark, welcome aboard. And, yes, you are correct, the brothers were from Waterloo, Iowa.
- 140 replies
- the sullivans
- trumpeter
Lou, Thanks for the history lesson. I was vaguely familiar with the overall history of the Battle of the Philippine sea and Leyte Gulf from the old TV series Victory at Sea (yes, I am that ancient of days) but not the the individual battles. And, yes, The Sullivans was decommissioned in 1946 and assigned to the Pacific Reserve Fleet. It was re-commissioned in 1951 and returned to active duty. Wikipedia has some of her history There is a second ship named The Sullivans (DDG-68) an Arleigh Burke-class Aegis guided missile destroyer commissioned in 1997. Al-Qaeda attempted to attack and blow her up in 2000 but they failed. They later successfully attacked the USS Cole in the same year. I believe I saw a model of the 2nd ship (DDG-68) offered, which I may build at a later date.
- 140 replies
- the sullivans
- trumpeter
You and Lou have me on that one. I confess I am not very up-to-date on WWII Naval battle history and even less knowledgeable about WWI Naval battles.
- 140 replies
- the sullivans
- trumpeter
Some photos of The Sullivans that I took in September 2011 showing her tied up at the wharf alongside the cruiser Little Rock at the Buffalo (NY) Naval Park. I plan to return and get some more photos and take the tour of the ship.
- 140 replies
- the sullivans
- trumpeter
Tom Welcome ! I've never done PE before either, so this will be interesting. Re: Ice boat, Thanks. But you could scratch build a ice boat, there's no hull to build or plank, just a keel aka backbone, runner plank, mast, spars.
- 140 replies
- the sullivans
- trumpeter
