Everything posted by Jack12477
A jerry can filled with water and a large can of lye - quickly sealed and dumped overboard - made even better depth charges.
Ok so the next coat of paint is a wash ? How much do you dilute the paint ? Yes, I could have chosen the chairs in the front, but the bleachers have more height; all the better to throw popcorn at you . But of course, I have to wait for SJORS or MTAYLOR to bring the popcorn machine first......
Carl, would you explain the "pin-stripe" effect you painted on the hull. I know HOW you did it but not WHY. What is the ultimate effect? I saw it in yours and Gregg's previous builds but not sure I understand why.
Bleechers - actually misspelled should be bleachers. Yes, Greg did sneak in while I was typing my response. Oh well ! bleach·er ˈblēCHər/ noun plural noun: bleachers. North American a cheap bench seat at a sports arena, typically in an outdoor uncovered stand.
Try living in the Finger Lakes region this past week. Seneca Lake, the 2nd longest (38 miles, 61 km) and largest (by volume, estimated at 3.81 cubic miles or 15.9 cubic km) lake in the Finger Lakes saw the lake level rise 10 inches between 3:30 AM and 1:00 PM on this past Tuesday after 5-9 inches of rain fell in a short period of time over the southern end of the lake. Seneca Lake, for those not familiar, holds about half the total volume of all the other Finger Lakes. Cayuga Lake, its neighbor and the longest of the lakes( just under 40 miles, 64 km), experienced a water level rise of about 3 inches. That's a lot of acre feet of water. The system sat off the New England coast pumping moisture off the Atlantic into central NY in a counter clockwise pattern, dumping most of it over the Finger Lakes area and central Pennsylvania.
Then I would say you succeeded beyond all expectations.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Outstanding job on the weathering effects, Carl. But really, Carl !?!? Would any Fleet Admiral allow one of his active duty Naval Warships to get that grungy ? I would think at the Admiral's next Inspection visit, he'd relieve the ship's Captain of his command and put the crew on latrine duty for not keeping their ship all nice and ship-shape and "purdy" <pretty>. Or is this one of those mothballed ships? But again ! Outstanding job of weathering.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
That worked well. You can play with the light intensity just by adding or removing layers of tissue. Nice work on the boat and painting.
- 467 replies
- mikasa
- wave models
CDW, try placing a single layer of Kleenex (brand or any similar brand) tissue over the built-in flash when you take the pictures. If one layer still is too bright then add another layer. The tissue will diffuse the light, make it softer and help keep from "washing out the color" in the extreme close-ups. You'll have to experiment with the number of layers of tissue until you get what you want. It's an old photographers trick.
- 467 replies
- mikasa
- wave models
Cool old sail ship request for info please
Jack12477 replied to Muskies's topic in New member Introductions
Brooklyn or Rainbow ????? -
CDW - Could be? But on my cameras, it's on the SET FUNCTION button (or FUNC SET). On yours trying selecting it and see if you get a screen with various LIGHTING settings - you are probably on AWB (Automatic White Balance) which sometimes doesn't work well when you switch between indoor and outdoor especially when you take the camera off of AUTO mode and select one of the other modes, e.g. AV (Aperature Preferred/Priority), TV (Shutter Preferred) or P (Programmed), etc. On mine when I take it off of AUTO, I manually select the Lighting mode (WB). I'm using a Canon PowerShot SX130.
- 89 replies
- independence lcs-2
- trumpeter
It is the white balance WB setting, change from indoor (tungsten) to Daylight, in Daylight the tungsten setting creates a blueish cast to the light; in contrast the Daylight setting will cause a yellowish or orangeish cast when used indoors.
- 89 replies
- trumpeter
I've purchased four books on four different occasions from Bob and had absolutely no problems and the books arrived in a very short time. I agree, contact Bobcat here on MSW. Also double check your credit card's monthly statement and see if it was actually charged for the order, it could be the order never went thru properly.
Making small nails with round head
Jack12477 replied to Aleksei Domanov's topic in Metal Work, Soldering and Metal Fittings
I used them to get parts (mostly bolts) for my ice yacht scratch build - great stuff and fast turn-around on orders. -
Ken, glad to hear that you and the model made it safely across the Bronx's Ho Chi Min trail. It hasn't changed in 20 years. I think some of those potholes could swallow a tank. Enjoy the Atlantic and Long Island Sound and your family stay - it's pretty hot and humid up here in "Upstate" Catskills also.
Great model and great diorama Piet. It is a fitting memorial to your Father. And thanks for the history lesson. Very informative, albeit a bit painful for you, but informative for all of us and very well told. Thanks
- 378 replies
- java
- pacific crossroads
You can find those in Home Depot, Kurt, except theirs are green, otherwise same.
Nice job on the rust. Looks like an old tub (rust bucket) in mothballs .....
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Ditto what everyone has said above. Fantastic job. Thanks for taking us along, I learned a lot from your restoration.
- 749 replies
- albertic
- ocean liner
