Piet
Posts posted by Piet
  1. Hello Pete and welcome to my shipyard.  Yes, this build is a little different from the O19 sub, which is now proudly displayed in my studio.  And not to forget the little lobster boat I did.  It's total departure from aircraft design, repair and flying them but I have always loved the sea and ships.
    I'm grateful for the help from Amateur Jan, Amazon Dirk and now also Hans.  Pull up a chair and join the crowd, the coffee is always fresh and hot.
    Cheers,
  2. Thanks to all for the likes!
    They are all done now Remco.  I used a short 0.5 mm brass rod clamped in a small vice and redid a few that were a tad too small.  No need to make all new ones ;)   All of the eyelets have also received a dab of solder where the wires cross to keep them is shape.
    I'm busily working on putting them on the single sheaf pulley blocks - - - 32 of them little buggers.  As mentioned before, they are very small and I'm winding up making new ones a tad larger.
    Needles to say, it's slow going.  Then comes the cleaning and blackening of the straps and installing them.
    Cheers,
  3. Again my thanks for all the likes!!!!
    Good to hear you are still busy with ship modeling Dirk.  I'm now very curious finding out what you are up to.  looking forward seeing it.
    Yeah Remco, I plumb forgot about using a drill bit for making the eyelets.  Sometimes the most obvious is overlooked.  So you mean this way  ;)
    It's still a tad too large but the next drill bit down in size is broken.
    Cheers,
  4. That's beginning to look very nice Patrick.  re Ben's comments - that's why I don't like composite structural elements in aircraft.  Even secondary structures I have my misgivings on because when they fail it'll effect the primaries.
    In any case, we don't have to worry about all that stress - load - stuff in models  ;)
    Cheers,
  5. Thanks everyone for visiting my shipyard, your comments and also for the likes.  As usual it's very much appreciated.
    Yes, for simulating the splicing of rope in this small scale is near impossible and I really didn't want to spend the time and effort to do so.  In the end I think that my method works out acceptable.
    As mentioned in my previous post I am using a different method in making the little eyelets on one end of the pulley strap.  It's done in a few seconds but I have to be careful not making the eyelets too small.  Has happened to a few of them but making new ones is now a no brainer  ;)
    Stropping the pulleys seems to be going a lot faster now with only a few redoes.  A teensy drop of soft solder on the eyelet part and after the first twist on the hook part secures the strop nicely to the pulley block.  Actually, the "splicing" of the "ropes" takes more time, go figure.
    Here is the sequence go how I am now making the strops for the single sheaf pulleys.
    Step 1. Take short piece of brass wire (I used 0.3 mm - I would have liked thinner) and make a loop.
    Step 2. Grap the loop at its end in a pair of pliers, making sure not to cover too much of the loop end other wise the eyelet will bee too large.  Conversely, too little and the eyelet will be too small for the "rope."   It all depends on the rope size.
    Step 3. Pull each end of the brass wire to tighten the loop and presto, you should have a nice eyelet.
    Here is the completed eyelet - sorry for the blurry pic, camera shake  :rolleyes:
    Cheers,
  6. Thanks everyone for the likes, it very much appreciated.
    Thought it's about time for an update.  Have been busy with other things besides ship building but dit spend some good quality time in the shipyard.  Still busy with the gun tackle, which is going very slow due to the size of the pulleys.  In retrospect I should have made them 5 mm long instead of the 3.5 or so.
    Am still thinking about redoing them but now that I have put the brass wire braces on eight of them I may just stick it out.  Perhaps a few that are really too small to handle but we'll see how it goes.
    So far I guess that it takes me about 4 to 5 hours per cannon to make the hardware but not including the actual fastening the tackle to the ship and coiling the ropes.
    I decided to make the pulley strops from brass wire instead of thread.  It's a little more difficult but it allows me to make the strop, eyelet and hook for the single sheaf pulleys from one piece of brass wire.  The double sheaf pulleys are easier because they don't need the eyelet on one end.
    Below are a few pics with explanations for my own records.  Years from now I like to know how I did things.  I did improve on them as time went by but that'll also be explained with the pics.
    This shows the method of making the eyelet on the single sheaf pulley strop.  A piece of brass rod winding the brass wire around it one turn.  I developed a simpler method the next day.  That'll be shown in tomorrow's post.
    This shows a piece of 0.3 mm brass wire being wrapped around the pulley block.  I had to keep the eyelet from unwinding by pinning it with a sewing pin.  This too I fixed the next day by spot-soldering the eyelet.  By twisting the hook-end the tension tended to untwist it.
    I tried to use only one twist on the hook-end to reduce extra bulk with too much of a brass lump.  One end will be cut off with nail clippers and the other end is bent into a hook.
    This shows the completed strop with an eyelet on one end for the pull rope and the other end with a hook to attach the pulley to the deck or bulwark.  The rope trough the eyelet is now ready to be spliced.
    How to splice scale rope fro rather thin cords.  I cut short pieces of very thin sowing thread and took it apart into its three single threads.  I removed the cotton parts to get to the nylon or Dacron threads.  I now had very fine but strong threads to use as splice material.  It looks thin here but it's about 3 X as thick as a human hair but a lot stronger.  It really blended into the "rope" to make it look like a real splice.  I'm happy with the result and simple method.
    This shows the splicing procedure being started.  I made a single overhand knot with the thin thread just behind the eyelet.  From there I continued making single knots, alternating from one side then to the opposite side  with about 10 knots.  I finished it of with a good dab of nail polish that i squeezed into the "splice" with my fingers.
    This shows the completed splice and completed pulley block.  The only thing left is the blackening, which will be done after all the pulleys are completed.
    This shows the double sheaf pulley block with it's strop installed.
    Cheers,
  7. Thank you Dave and Lawrence for your very encouraging words.  Gwen (who doesn't want to be called Admiral) seem to agree.  Her comments were mainly on the one spindle that was thinner then the others and also the very blond look of the wood.
    Sometimes we rely too much on our photos not realizing that we may have distortion and then get wrapped around the axle thinking we have to rip everything apart again.
    Yes, sometimes it's called for and as all of you know I'll be the first one to do so - - - my junk pile can attest to that.
    Well, I'm continuing with the gun tackle hardware, i.e. the straps and ropes for the guns.  It's very slow going and will post progress reports - - whenever - - - soon  :)
    Thanks also to all who clicked the like button.
    Cheers,
