Louie da fly
Everything posted by Louie da fly
  1. Aha! Here it is - Age of the Dromon page 212: "The inventories [for the Cretan expeditions of 911 and 949 A.D.] specified that for the 20 dromons there should be 120 sidera bolistika with 120 siderobolia, that is, six of each per dromon, as well as another 50 siderobolistika with 50 siderobola. This has to be the starting point . . . they also said that Department of the Vestiarion supplied another 60 “iron-throwing ropes”, scoinia siderobola, for the expedition. Since schoinia siderobola clearly implied something made of iron and equivalent to a rope, we conclude that the 120 and the 50 siderobola were the same thing and that the 120 and 50 siderobolistika/Sidera bolistika were something different. Sidera bolistika literally meant “casting irons” and these latter must therefore have been the anchors, which were “cast” into the sea, as the Leo VI and Nikephoros Ouranos both said. What then were the siderobolia/siderobola or schoinia siderobola in this context? There is no doubt that one of the scholia on Lucian’s Lexiphanes used the word siderobolion for an anchor; however, here we suggest that they were iron anchor chains attached to the anchors. The rope anchor cables would have been attached to them. When anchor cables are made of rope, as was the case in the Middle Ages, it is necessary to have the last few metres connected to the anchors made of a heavy chain because an anchor works best when the drag of the ship on it is as close as possible to parallel to the sea bottom. This causes the flukes to dig into the sea bed. But, because rope is light and floats, it tends to pull anchors upright and dislodge the flukes if attached directly to the anchors. Iron chain, on the other hand, will sink, thus causing the entire anchor system to form an arc with the anchor end as close to parallel to the bottom as possible. All modern small craft using rope anchor cables have a length of heavy chain connecting them to the anchors." As you can see, the evidence is pretty vague and subject to interpretation. I choose to follow Pryor in this, as I think his explanation makes sense. Steven
  2. That'd be good, Pat. I'll PM you my phone number. Mark, thanks for that insight. Druxey, I'll put that quote up when I find it. Steven
  3. Caravels are such beautiful vessels. I'll be following this build with interest. Steven
  4. I'm sure I remember reading somewhere that the grating came into use with the advent of below-deck guns, to disperse the powder smoke. What evidence this statement is based on, I don't know, but it seems to make sense. Beautiful work, as usual. Reconstructing a famous ship for which there are no plans or contemporary pictures (e.g. the Mathew, the Mayflower etc) can only be an educated guess based on available information, and certainly there's no way of knowing what exactly the Golden Hind looked like. But to my mind you have every justification in keeping the name - I think that with the thorough and painstaking research you've put into it your model approaches more closely the true form she would have had than any other I've ever seen. Steven
  5. Beautiful, beautiful work, Michael. The precision and detail leaves me gobsmacked. Steven
  6. The written evidence is a bit sparse, Druxey, but Pryor's book has a quote from a contemporary text (can't lay my hands on it at the moment) that he interprets as meaning there was a length of anchor chain between anchor and cable to keep the anchor weighed down so it would "bite". When I can lay my hands on the book I'll follow up with the quote. Steven
  7. About 20 links per inch, Pat, and I got another one about 15 per inch from the same place - Ishka. Just a matter of dumb luck, being in the right place at the right time, (and cost about 5 bucks as I recall) and I don't know if they'd still have the same chains. I expect you have an Ishka fairly local to you, so maybe don't have to come up to Ballarat after all - if you did though, you'd be very welcome to come and visit. Steven
  8. Yep. Seems so obvious in hindsight (don't ask me how I know). Steven
  9. I've just been working on the anchors for the dromon. I've made 5 of them. Byzantine ships seem to have had many lightweight anchors rather than a small number of large ones. This seems to be due to the limitations of manufacturing technology - they were made of relatively small pieces of wrought ir on, hammered out to remove the slag and them hammer welded in a forge to join them all together. The dotted lines in the diagram below (one of the anchors recovered from the 11th century Serce Limani wreck) denote the welds. Unfortunately, as the archaeological report on the anchors (by Frederick. H. van Doorninck Jr, illustrations by Sheila D. Matthews - see https://books.google.com.au/books?id=E6ZJ-05aC-sC&pg=PA237&lpg=PA237&dq=serce+limani+anchors&source=bl&ots=2cbB35RuzX&sig=ACfU3U1pE9YyddqSStaB-VdSDSQfXvc_nw&hl=en&sa=X&ved=2ahUKEwjgq9yX_vfmAhWlyDgGHbYRCbsQ6AEwDHoECAoQAQ#v=onepage&q=serce limani anchors&f=false ) states, The Serce Limani ship had nine anchors on board, of which six were spares stacked together in two piles on the deck. The ship had cast at least three anchors but was probably wrecked when one of them (probably the first to be cast) broke under the strain. All the Serce Limani anchors were of the same type, with minor variations due to their being made individually by blacksmiths. This was a common anchor shape at the time, so I'm using them as a model for the dromon's anchors. I've made five of them - I don't have space for more on the ship. As it is, some will be stored under the forecastle. The best of them will be mounted at the bow. I got jewellery chain for a couple of bucks from a hippy shop (with some trashy pendant attached, which I chucked away - but the chain itself is brilliant!) Steven
  10. I've been working on the hatch cover. At 1:200 I don't feel capable of making the gratings using halving joints - my work is nowhere near that precise at the best of times. So I've made the grating the way I did on the original model, with one layer of thin laths of bamboo in one direction, overlaid with another layer at right angles. Not perfect, but unless you really look hard it looks like the real thing. Steven
  11. Not too much, I hope. I'm continually torn between repairing it to be the same as it was when I built it, and putting in improvements in line with what I know now. The underwater hull shape was based on Mathew Baker's late Tudor drawings while the gunport configuration is based upon the illustrations in the Anthony roll, both of which the Mary Rose discoveries have since shown to be inaccurate. The colour scheme is also based on Mathew Baker, but contemporary pictures of ships show a much simpler colour scheme for the time of the Great Harry. However, I'm afraid I'm not terribly consistent with this. I'm re-using all the existing superstructure as-is despite knowing the colours, upper structure and number of gunports aren't correct. But I've changed the shape of the underwater hull and I've made these cannons in line with the Mary Rose discoveries (not available when I was 17). The model as it stood had only one cannon. I was planning to cast a whole lot more of them but never got around to it, so I feel (somewhat) justified in adding new, more accurate ones. And the (lost - to my very great regret; I was and am very proud of what I was able to do at the tender age of 17) longboat will be double-ended instead of having a transom stern as in the original, as this seems to have been the way they were at the time. At least as far as the hull is concerned it will be possible to see the old vs new work because the colour of the wood is different. However, I'll be making the upper deck of bamboo as I did at the time, even though I could do it far more accurately now. So, it's not really Arthur or Martha - neither a pure repair nor a "renovation". Still, I'm not too concerned - it's my model after all, and I get to decide what I want to do with it. Steven
  12. I've had to make some adjustments to the ship to allow the guns to be added. For a start, the forecastle doesn't have any internal decks for the guns to sit on, so I had to think of some mans of supporting the gun barrels without having to take off the top deck. It occurred to me that I could put timbers through the relevant gunports and cut them off flush with the inside of the sides of the forecastle and just manoeuvre them so their top face was level with the bottom of the gunport, and that would form a support for the barrels. Here is the forecastle with the beam sticking out of the gunports either side, prior to being trimmed. The timbers in the forrard gunports haven't yet been trimmed, while those of the aftmost gunports have - you wouldn't be able to see anything until the guns are inserted. And here are the sternchasers: As you can see, with the built-up cannons the barrel hardly sticks out past the front of the carriage at all, so it is only barely visible sticking out of the gunport, which perhaps explains the way they sometimes appear in contemporary pictures. Steven
  13. See https://nautarch.tamu.edu/academic/alum.htm for a paper by Kendra LeeAnne Quinn called "Shipboard Lighting: A.D. 400-1900". Might be of help. Steven
  14. I agree with Banyan's interpretation of the "p" and the "r". Looks like "length of the sprit 31.10" (31 ft 10 inches?) Then "(something) of the deck 24" "below 5.3" "(extension?) of head 29.3 +2 = 31.3" "(Head?) 5.3" "New Mark 36.8" "length of the sprit 31.10" Steven
  15. Mass production of built-up cannons. Gun barrels threaded onto a wire and painted black The blanks for the carriages cut apart And trimmed down to make half-round "beds" for the barrels. And separated into individual carriages The third carriage under construction - As they won't be seen anyway, making full carriages was just to satisfy myself that I could do it. So for the rest of them I just made blocks to take the place of full carriages. More to come. Steven
  16. Very true, Götz. On the other hand, to get any sort of recognition at all young researchers are obliged to come up with something different from what has gone before, and the temptation is perhaps there to disagree with the "old masters" for the sake of saying something new - even if it doesn't make a lot of sense. There are certainly a few things about Pryor's book I disagree with, but it is still far and away the best and most comprehensively researched book on dromons in existence. The Yenikapi discoveries coming just as the book went to print made it somewhat out of date as soon as it came out, but taking that into account, just about all my other disagreements are on very minor issues indeed. And as an academic, to add to or disagree with what he's done you would have to really be on top of your material. The reconstruction of the hull itself is not bad (though even then I have my disagreements with it), but apart from that I don't think it adds to our knowledge of dromons. Steven
  17. And not just maritime subjects - almost any academic subject attracts people who seem to be more interested in proving their fellows wrong than in achieving anything useful. On the other hand I think the author was genuinely trying to arrive at a workable truth - I just find it hard to accept most of his conclusions. Well, not completely. It's always good to get another viewpoint, even if you don't agree with it. The "demountable castle" concept is attractive, given the huge scarcity (only one known example) of castles in contemporary pictures of dromons. But where would they be stored on-board? And would they be solid enough to fight from? It's an interesting idea and I haven't totally dismissed it, but as I've already built the things (though not fitted them), I expect I'll go ahead with them even though the ship will be displayed with masts and sails. And his reconstruction of the oarbenches is almost identical to what I came up with independently (though I decided not to use a fore-and-aft beam joining the benches, having decided it would interfere with free movement for the oarsmen in times of combat). Also his deck beams (lightweight crossbeams - to allow for limited headroom - supported by two intermediate fore-and-aft beams sitting on columns either side of the lower walkway) is exactly how I'd envisioned them, though I didn't put the support beams and the columns in the model because they weren't structurally necessary at that scale. Not a complete waste of time, but I feel rather a wasted opportunity in many ways - it could have been much better. Steven
  18. Well, I’ve had a pretty good look over this new paper (which turns out to have been published in 2010 – who knew?) and though I agree with some of it – the cross-section follows the Yenikapi finds, and makes sense structurally (though if the oars were configured the way they’re drawn they would foul each other and break). The shape of the ship makes sense and is a possible interpretation of the information available from contemporary descriptions and pictures, and from the archaeological record. However, I have quite a few objections to this interpretation. One thing I do have a problem with is his contention that the lower oarbank had one man per oar, but the upper had two. This comes from a contemporary source regarding the number in the crew, and he goes into some detail as to why this would be. This or similar ideas are advanced by other academics, but Pryor interprets the data differently, saying one man per oar in each bank. I don’t follow maths of either argument – there are contradictory numbers in the original sources – but in my view this interpretation violates Occam’s razor – it’s an unnecessarily complex solution to a simple problem. The spur is interpreted as an “assault bridge” even though the spur is mentioned repeatedly in the contemporary sources, while there’s never any mention of an assault bridge. Granted that absence of evidence is not evidence of absence, nonetheless it would be surprising if an assault bridge really existed that it wouldn’t be mentioned in the manuals. It is also proposed that the spur/bridge was fixed permanently to the structure of the ship, and though I find Pryor’s interpretation somewhat lacking – the spur fixed to the hull by what the sources call a “pin” which would make it pivot around the fixing point in event of ramming - this author doesn’t answer the evidence Pryor puts forward, which is quite extensive. Though there is a case for single mast rather than two (I think I’ve covered this earlier in my build log) this paper dismisses Pryor’s arguments for two masts without answering them. It also proposes that the xylokastra (side castles) – and even the pseudopation (forecastle) would foul the lateen sails and therefore would be temporary structures erected only when rowing (masts lowered) into battle. An interesting interpretation but if so why is it never mentioned in the sources? On contrary, the contemporary descriptions suggest that these structures were permanent. Also, many other relatively contemporary pictures of galleys show a forecastle – a fact this paper does not mention. Though I don’t claim to be an expert, much of the time when sailing, a lateen yard is on a very slight angle indeed – almost horizontal – rather than on the sharp angle you often see in modern reconstruction drawings, so it wouldn’t foul the castles. And a dromon could only sail with the wind directly behind it – more than 10 degrees of heel would put the lower oarports under water – so the lower ends of the yards would normally be out to the sides of the ship. Though the paper quotes Pryor extensively, but it seems only to disagree with him. It fails to cover many issues Pryor raises which would, if properly examined, cast doubt on the ideas it advances. It raises a few new concepts, but not many that I believe improve our understanding of dromons. Steven
  19. Don't forget to allow for the overlap in the scarph joints! I've found myself having to remake items because I did and they turned out too short. Steven
  20. On the contrary, Mark. The available evidence suggests they removed sails, yards and masts before they went into battle, and one battle is quoted as having been lost because they neglected to do so. Steven.
  21. Thanks everybody for the likes and comments. Messis, yes the fires are very widespread and destructive, made worse by the shortage of water caused by the current drought. Thank you for your concern. On a more cheerful note, I've just come across a new paper from Germany outlining an updated theoretical (and practical - scaled 1:10) dromon reconstruction at https://www.academia.edu/24592168/Zur_Modellrekonstruktion_einer_Byzantinischen_Dromone_Chelandion_des_10._11._Jahrhunderts_im_Forschungsbereich_Antike_Schiffahrt_RGZM_Mainz?email_work_card=view-paper Unfortunately it's in German, and I'm currently making my way through the hodgepodge version Google Translate has presented me with, trying to make it make sense in English. Once I've done that I'll figure out whether I agree with it. So far I agree with the general shape of the reconstruction, but not with the oar arrangement. He's introduced an interesting idea - that the xylokastra (side castles) and perhaps even the pseudopation (forecastle) were demountable constructions, only put in place when the ship was going into battle. The reason given that they would interfere with the operation of the lateen sails. Interesting, but I'm not so sure he's familiar with how lateen sails work - from seeing video and still photos of them in operation, I'm not so sure the problem really exists. Also, in places where he disagrees with Pryor's book, he often simply dismisses Pryor's conclusions rather than disprove them. So - a bit unsatisfactory, but I'll suspend judgment until I've had the chance to look over his stuff properly. Interesting, though. Steven
