Elijah
Everything posted by Elijah
  1. At this rate, you will be finished within two weeks! What do you do to make all the different parts fit the right shape?
  2. I'm not very experienced with wooden ships, I am working on my first, but I do prefer wood glue over CA. I don't know how to solve your keel problems, but someone will probably have an answer for you. Good luck!
  3. There is an oddity shop in my neighborhood that has things such as giant pencils ! The one in the picture is not one of them though. My hull is about 9" long, or a bit longer than the average pencil. Here is the picture, as promised! Until next time!
  4. Nice job on the ruder Mike! Did you solder the brass wire to the pintles, or did you do something else?
  5. Hello again! Thanks for all the comments! I made and attached the cleats. I sanded them, drilled a hole on the center, inserted a wire, cut them to size, painted them, and glued them to the bulwarks. Next up will be eye bolts and hawse pipes. Until next time!
  6. Thanks Bill! I will take a look at it. I have finished sanding the cap rail, and you can see some of the cleats I am working on. I sand the cleats, drill a hole in them, insert and glue in a wire, and then cut the wire to length. The wire adds strength to the connection to the bulwarks. Until next time!
  7. The problem with leaving another ship at my other home is that there are two kittens constantly confined in my bedroom. I don't want to know what would happen to the ship in the rigging stage !
  8. She is tall! Nice work! I know that feeling when you work on a part, then it breaks, or flies away in my case.
  9. Oops! I think I may need a new pair of glasses! I think the way the lighting was made the waterway look gray, so I thought it wasn't there. Please accept my apologies!
  10. This is what I mean. The starboard side has it, but not the port. I hope his helps!
  11. Nice technique Mike! How do you keep the paint on the brass parts? I used the model expo black paint, and had a little trouble with it peeling off.
  12. Happy birthday Jerry! That deckhouse looks great! Well done.
