Jaekon Lee
Posts posted by Jaekon Lee
  1. Copper plate & bolting on the keel
    Thank you friends as always. ;-)
    Horse shoe and fish tail copper plates were attached on the both sides of the keel. Brass wire was used to fix them on the keel. After finishing bolting work, keel, frame and outside planking strakes were oiled with the mixture of linseed oil and turpentine oil.
    Cheers,
    Lee
  2. Main deck planking
    Planking of port side main deck has been finished at the breast center line. Though it is hard to see at this moment, treenails were simulated with syringe needle tip. I hope they will be more visible after oil finishing. : )
    Windlass spindle, jeer bitt and several standards for them were attached and bolted. Small windlass will be added between the jeer bitt pins.
    Cheers, Lee
  3. It's a great pleasure to follow your building progress, Nils. Will you do planking the hull?
    One more question is that you built hull with series of blukhead to support the hull shape (so it would be plank on bulkhead, 'POB') but you write "POF" in the title. Am I incorrect?
    Lee
  4. Draft rail and rough tree rail
    Hi, Nils, Christian, David and Mike. Many thanks for your compliments.
    Long break and little progress due to busy work and trip. Draft rails on the top timbers and gun ports were joined with glue. Nailing seems to be required to reinforce the joining strength. At the aft hull side, rough tree rails were placed between extended top timbers over the draft rail. Now I'm ready to install deck planking. ;D
    Cheers, Lee
  5. Stern transom and timber structure
    Due to the complex shape of stern structure and lack of information, many trials were needed to make this part. Though it is not clear with the drawing, side counter timber was formed as double layered with recess to receive the outer top side planking boards. Outer side counter timber was made by ebony to match the color of wale. Curved shape of transoms and tafferal were formed by steam bending method.
    Cheers, Lee
