Everything posted by GuntherMT
Excellent rigging, especially for your first go at it. I agree with you though on the seizing thread, I use some very fine thread I found, not the .008 thread, and I find that it looks much more 'to scale' for the seizing. For the future, you might consider down-sizing the blocks, as most blocks specified by kits are considerably over-size, especially the ones provided by most kits for the gun tackle.
- 270 replies
- red dragon
- artesania latina
Came out fantastic Erik! That's a gorgeous planking job.
- 222 replies
- 18th century longboat
- model shipways
You did yours the same way I did my first one. Notice how Grayarea's grating has a solid edge (or border) of grating material all the way around inside the frame, and yours has no 'border'? It was pointed out to me when I did mine the way that yours is, that it was incorrect, and should have been done the way Grayarea's is. Assuming your kit has the same materials as mine did, there is sufficient grating material to re-make that one without any problem. Edit - You can see in this post in my log how I made mine the same way yours is made the first time - http://modelshipworld.com/index.php/topic/8085-armed-virginia-sloop-by-gunthermt-model-shipways-scale-148/?p=288772 If you read the feedback following that post you'll see what I was told, and then this post is where I re-did it - http://modelshipworld.com/index.php/topic/8085-armed-virginia-sloop-by-gunthermt-model-shipways-scale-148/?p=289602 If it's good to your eye though, then it's good!
- 164 replies
- model shipways
- armed virginia sloop
Looks like you've got a good start. I really like the looks of this kit, and it's on my radar for 'some day'.
- 105 replies
- picket boat
- model shipways
Great planking job. I wouldn't have known it wasn't sanded if you hadn't told us!
- 222 replies
- model shipways
Thanks Frank. Once I get back to this I'll see what I can work out, and maybe borrow that stuff from you. I don't have a big rush to finish the guns, since they wont' be put on the ship until it's complete anyway, as I'm sure I'd break them all! After looking at Dan's Vulture build today, I may try to make rounded yokes like he did, they will probably look more realistic than my squared off one.
- 831 replies
- Armed Virginia Sloop
- Model Shipways
Those are fantastic looking joints Chuck!
- 1,051 replies
- cheerful
- Syren Ship Model Company
Cool, I've just never seen one rigged that way, so it looked 'wrong'. Certainly doesn't mean it is, as I'm sure there are a bunch of ways to do things 200+ years ago that I've never seen either. As long as you like it, then it's perfect! For my catheads & the end line, what isn't complete in the photo I posted is another hole just behind the sheaves (I had forgotten to drill it before the picture). The rope starts at this hole with a stop knot, then runs down through a double block with the hook, then back up to the first sheave, then back down to the double block then back up to the second sheave and then is belayed to a cleat or timber head on the bulkhead.
- 389 replies
- scottish maid
- artesania latina
Thanks Alistair, good idea, but the brass rod I am using is sized to fit perfectly into the brass tube that I've inserted into the pedestals to mound the guns, and using the PE would probably not fit properly (although who knows!). I think for this build I'll work on refining my yokes by shaping the tops a bit. I plan to blacken all of the assembly when done, which should mute the entire assembly to the human eye a bit. That PE yoke does look great though, definitely going to file that away in my head for the future! Feel free to leave the photo, it's fine for people to get other (better) ideas when reading through the log. Thanks also for the rope on the mast wedge trick. I haven't ever seen that done, but looking back at your photo's, it looks good! I even have dark brown rigging rope to use for that, since I was planning to leave the wedge natural walnut like all the other walnut on the boat.
- 831 replies
- Model Shipways
Good to see you around Alistair, and yea, I've stuck the bowsprit assembly and main mast on already, it's pretty awesome the size jump. I continue to put off doing the chain plates on the port side, and have done some experimentation (failed) and various small bits. First, I decided to continue on my route of replacing most of the cast pieces in the kit by making my own mast hoops out of wood. Unfortunately, this didn't work out so good, as the wooden hoops are just too fragile, and I can't get them cut off without breaking them. This is partially because of their small size, and partially (or maybe mostly) because I was using a dowel as my wood, and the grain is just too big for this sort of thing. I have an idea on how I could make it work using multiple pieces of boxwood laminated together with the grain all going the proper direction, but in the end I decided that the effort just wasn't worth it for these pieces, and the kit hoops have been primed (and now painted as well, but no photo of that). The next cast piece to get trash-binned was the strap that holds the foot of the bowsprit. This piece doesn't fit the bowsprit properly as I completed it, and it's kind of ugly anyway, so I made a new piece out of brass. This is 5 pieces soldered together, which was quite a trial, as the pieces are so small I couldn't heat one joint without breaking another one. In the end I got it done, it's not perfect, but it will do. I drilled holes for brass pins that I will make to pin the strap to the deck, and to the bowsprit. I then blackened it with Birchwood Casey Brass Black, as I can no longer get Blacken-It at the local shop. I got the mast wedge filed to fit the mast, and rounded the outside edge. Haven't decided yet on any detailing for this piece. And finally, tossing the cast swivel guns into the bin, I started work on the replacements. First I soldered the trunions in place, and began to form a 'yoke' to support the gun. I then soldered the yoke to a rod, drilled holes for the trunion, and stuck a gun on to see how it will look. Pretty happy with how these look. Worth the effort and expense. Opinion time - should the yoke drop right down against my existing post mounts I've made, or should the rod stand them up slightly from the mount base? I will also be adding a handle to the gun. I sort of completely forgot to do that. Doh! Another question. The yoke is so small, that I don't think I'll be able to solder the trunions to the yoke without breaking the existing solder joint of the yoke to the rod. Thoughts on 'fixing' the gun in place? Super glue should work I suppose, but I'm not sure how easy that will be to make invisible, and would need to be done after blackening. I'll play with some ideas, but more than open for suggestions on this!
- 831 replies
- Model Shipways
It's looking great, and I hate to point this out after you made such nice straight holes, but I've never seen catheads with the sheaves that way. They would typically run 'along' the cathead, not side to side. Like this: Of course, there are exceptions to every rule, so maybe this is the correct way for this particular ship? If you are happy with the way they look, chances are that very few people who aren't into this hobby will ever notice, but I wanted to point it out now, before you get further along in case you decide a re-do is in order. Good luck!
- 389 replies
- scottish maid
- artesania latina
This is a beautiful model that I hope to build some day. Look forward to watching your progress on it. Looks like a nice start and you have some interesting ideas on changing the kit. I hope you can find out about the long-guns!
- 120 replies
- mercury
- victory models
Thanks Frank. I may give that process a try, modified for the length of my plates, but I'm not sure about having the wire seam on top of the dead-eye like that, might be difficult to hide, will see!
Micro Drills, Revisited.
GuntherMT replied to Modeler12's topic in Modeling tools and Workshop Equipment
I have a chart of what size each bit from #80 to #60 is supposed to be, and I just use digital calipers to measure the bits to get the right size for the hole I want. The undersize issue seems to be common with 'cheap' micro-drills no matter where they are coming from. For work on the mill or drill press, I also use the PCB bits, which can be had from Amazon or very cheaply on Ebay as well. PCB bits are the ones pictured above in rtropp's post. As Frank and others have said, they don't do sideways pressure at all, but they are great for use in a press or mill. -
Frank - I never did ask you. What sort of jig did you use for stropping the lower dead-eyes, and did you use wire? They look very neat, and I'm having a heck of a time getting even soft copper wire to form the stropping/chain plates as neatly.
Holy crap, it lives! Good to see you back, I look forward to seeing how the pear works for the deck planking. I imagine it should be very nice, I've never read a bad word about pear in ship modeling. The galley hatch looks good, you got the grating right, where I screwed up my first one and had to remake it thanks to sharp eyes here on the forum letting me know I'd done it wrong. Hope your next update doesn't take nearly as long as this one did.
- 164 replies
- model shipways
You can get similar results (or better) with hand drills and files - there are plenty of examples of that on these forums - but I'm lazy and impatient, so I like the power tools.
- 831 replies
- Model Shipways
Thanks all, appreciate the encouragement. I have no idea what it's like working with Pear, I'm using Boxwood.
- 831 replies
- Model Shipways
Thanks for the continued likes and comments everyone. Feel free to jump in with suggestions for improvement or telling me I'm making errors at any time. This is only my 2nd ship, so I've got plenty to learn still. Instead of finishing the chain plates and dead-eyes on the other side of the boat, I decided to play with power tools. The plans show a sheave in both the bowsprit, and the jib-boom, but the kit doesn't provide it, and both the plans and instructions say to just drill a hole for the line to run through. Well, the heck with that, I'm an idiot and decided to risk wrecking my bowsprit by building in the sheave! I am pretty happy with how the one for the bowsprit came out, I used a small piece of dowel with a hole drilled through it and sanded down to size for the pulley. Not super happy with how the one in the jib-boom came out, it's just so small that I had a hard time getting a clean slot cut. I didn't even try to insert a pulley. I'm hoping that with rope run through this it won't look bad. And here is a shot of the bowsprit and jib-boom together. They aren't actually glued together, I have a bunch of work left to do adding little cleats and stuff to them. Notice the length of this assembly is slightly longer than the length of the hull of the ship it will be attached to! Then I made the main mast. This is the longest piece of wood on the ship, and was somewhat challenging to shape because it was so long. Pictured here next to the remainder of the 1/2" square boxwood that it was carved from. The other pictures are close ups of the top and foot of the mast. Pretty happy that I pretty much nailed the shapes and size on my first go at it. I do have 1 spare piece of boxwood if I had totally messed it up, but glad I shouldn't need to use it.
- 831 replies
- Model Shipways
Very nice! Is the idea with the base that it's low tide and the ship is grounded, or do you intend on adding a 'water' component on top of your current base?
- 188 replies
- Sherbourne
- Caldercraft
Your drawing looks ok to me, but I've only rigged a single ship so far, and read stuff here and in books, so I'm a far cry from an expert. No idea what size rope you should be using for what, but in general the running rigging would be untarred (so tan) with only the standing rigging being tarred (dark brown or black). In theory somewhere in your plans should be a belaying plan, but again, I don't have this model so can't say for sure if it includes one. The Lennarth Petersson book on fore-and-aft rigs has a generic belaying plan for several ship types. If you don't know, a belaying plan is a plan that shows where each line will be belayed to on the deck pin-rails and such. I know that the AVS has this plan included, but my Carmen model did not.
- 98 replies
- artesania latina
- finished
The first book shows the rigging of a square rigged ship, and the second shows rigging of 4 different styles of fore-and-aft rigged ships. Yes, I absolutely recommend them, they are completely full of drawings like the one I posted, in full page format and with each line isolated to show how it works and where it goes.
- 98 replies
- artesania latina
- finished
