Everything posted by GuntherMT
The people have spoken! I have to remake one of them because somehow the hole on one side is way off. It must have slipped in the jig, no idea how, but I'll just call it practice, and the jig is still clamped in the mill, so not a huge deal.
- 831 replies
- Armed Virginia Sloop
- Model Shipways
Looking great Frank! I really need to sit down and practice the zip siezings, I can see a number of places in the AVS rigging where they will be very helpful. You'll also be happy to know that I broke down and made another jig tonight.
Thanks for all the input everyone. The plans for the swivels are crap. Specifically they are brittania cast metal guns with a post sticking straight out of the bottom of the gun to mount them into a hole. I've tossed the guns and already installed brass tubes for the brass mounting rod to drop into. There is no way that I'm just soldering a rod straight to the bottom of my pretty brass cannons.
- 831 replies
- Model Shipways
Opinion poll time! Assuming that I make the U shaped mount the right size (i.e. about the same size as the 'square' mount and both of them slightly narrower), which style of swivel gun mount should I go with? Square, or U?
- 831 replies
- Model Shipways
Masting is done! Well, I still need to attach one side of the parrels to the gaff and boom, but I'll just call that part of rigging. The main boom with sheave. The topsail yard and spreader yard. I did have a do-over on the topsail yard when I cut too deeply into it after I was all but finished. Oops. Oh well, only 1 do-over for all the masting (not counting the multiple bowsprits I made prior to switching to boxwood), I'll call that a win! And everything all lined up together ready to start getting rigging.
- 831 replies
- Model Shipways
To be fair, that log started over a year before I started building model ships, and there is simply no way that I could go through and read every single build log posted since this site began if I ever actually wanted to do anything except read (I do have a full time job). Thanks for the link though, I'll have to look through that one now.
- 80 replies
- choctaw
- heinkel models
I'm absolutely biased towards natural finish, I love the look of the planking without paint.
- 133 replies
Looking good! Probably a bit late now, and this is purely a novices opinion, but I used balsa for filler blocks on my first build, and found that I wished I hadn't used it. I know that some people like it because it's so easy to form, but I found that it was very difficult to keep shaped properly because it sanded so much faster than the surrounding bulkheads, and it hasn't got enough strength (hardness?) to hold pins. On my second (current) build I only used basswood for filler and reinforcement blocks, and I'm much happier with both how the wood works (bulkheads are also basswood), as the hull faired evenly when sanding, and the basswood holds pins very well while planking. The cost of basswood carving blocks at the hobby shop is comparable, or even cheaper than balsa blocks. The only downside is that the basswood is obviously harder to cut to rough size and shape compared to the balsa wood. Edit: Basswood carving blocks can be found at most hobby stores (I know Hobby Lobby carries them as does my local hobby shop), and you can also buy them in larger quantities at wood workers shops like Woodworkers Source and Woodcraft (http://www.woodcraft.com/Product/149262/Basswood-Grab-Box.aspx)
- 26 replies
- syren
- model shipways
Thanks for all the likes! All the masting is boxwood. I've done them both ways as experiments Frank. The 'axle' on all of them is brass. The larger sheaves (catsheads, bowsprit, boom) I used .032" brass rod with a brass tube that fit perfectly over it or a small piece of drilled dowel for the pulley. The smaller sheaves (jib-boom, top mast) I used the brass nails from the Carmen kit which are about .020", and nothing for pulleys to keep the slots smaller. The axles are secured by applying a small drop of CA on the brass axle and then pulling it into the sheave. Once it's dried for a while I trim the brass with end cutters and then file it smooth with a #4 barret file.
- 831 replies
- Model Shipways
In non-picture news, I got some actual ship progress done today. I have completed the main-mast. And the Gaff. I've got the Main boom shaped, with a working sheave installed instead of the 'hole' the instructions say to use, the jaws mounted and strapped. Tomorrow I'll get the chocks and cleats installed and hopefully get both the yards made and fitted out, and then I'll be ready to start rigging!
- 831 replies
- Model Shipways
That shot with you holding it really shows the scale well. I sort of thought this was a much larger model, makes the details you are putting into it that much mroe amazing to me.
I've never seen the early stages of a card model, so this is quite interesting. All the card builds I've seen before seemed to just skip over the bulkhead and keel formers and start with a mostly complete hull. Thanks for posting this!
- 80 replies
- choctaw
- heinkel models
Not really, they are all in the same directory, but they are all linked to my build log here. If for some reason you wanted to look at them there instead of the log, you could pull the file names from the build-log here and append them to the same path name as the one I provided the link for. I don't have an html index set up, nor do I have the directory open for ftp browsing. If there is some particular file that you wanted to see in giant size, I could probably get it for you, but I'd have to go back and find the original DSC image from the camera in the RAW directory and then put it up and give you a link. I've got 760 photo's from the Nikon in 6000x4000 and another 408 photo's from the prior POS Canon in 2816x2112. Of those, over 600 have been copied, cropped, sized to 1200x and uploaded to this build log. Many of them that aren't uploaded were the same images with different exposure settings, or just shots I didn't like for some reason (focus, exposure, bad composition, etc.).
- 831 replies
- Model Shipways
I have no re-sizing issues, I have a number of different image manipulation programs depending no how much quality I want, but thanks for that tip. The problem I was having way back in that post in November that you are quoting was that the forum was doing some sort of compression after I uploaded the images, it wasn't my source images. This hasn't been happening in a long time, it seemed to be a fairly short-term issue with the forum. All images that I have checked recently are the same size here as they are in my source. I crop and re-size all my images for the forum, since the forum would choke on 6000x4000 RAW format images and even a HQ Jpeg is 8-12mb. I reduce everything to 1200x on the long side, and use fairly high quality settings on Jpeg. As with any form of image format that uses compression, there is some quality loss whenever an image is manipulated, as that is the nature of image compression. However, said image compression allows a site like MSW to store huge numbers of photo's without needing a Peta-byte storage array to keep them all!
- 831 replies
- Model Shipways
Really looks great. I love the dime to put it in scale.
- 222 replies
- 18th century longboat
- model shipways
For paint bleed prevention - first, use good tape, I prefer the Tamiya masking tape. Second, after you have it masked off, spray along the tape edge with the color that you are masking off (clear if you have no color being masked off). That way any bleed that occurs will be the same color as what the masking is covering, and that coat seals the edge and prevents further bleeding. Great looking planking by the way!
- 133 replies
Looking good Ed. I see you got all the stuns'l booms on as well!
- 42 replies
- fair american
- model shipways
Looks like it is progressing nicely Jerry. One thing I noticed, and it could just be a photography thing - it looks like you might be getting some gapping at the bow where the curve is the tightest. Are you beveling the edge of the planks where they lay up against each other? If not, you should consider trying that, as if the edge is properly beveled you can eliminate most or all of the gapping caused when two planks are butting against each other at an angle. Bevel just the one side of the plank you are placing so that the bevel is tight against a non-beveled plank edge to make a nice close joint.
Thanks Lawrence. It's not installed (neither is the mast), I just stuck it on and held the base with yellow tack to take the picture. I'm not going to actually mount it until I have to. The jib boom isn't actually affixed to the bowsprit yet either. I'm going to make the yards, boom and gaff, and rig as much as possible before I start the assembly to the hull. Currently working on an actual display stand, and sidetracked a bit on a very small, cheap plastic tank kit that I'm doing as part of a group build (first plastic model in 30 years, should be hilarious).
- 831 replies
- Model Shipways
Looks pretty interesting. I've never seen that ship before, and it certainly is interesting looking! I'll be watching for future updates from you on this.
- 80 replies
- choctaw
- heinkel models
Thanks all. Don - I don't plan to paint anything else on the model except for fittings and such as needed. All the boxwood will be given the wipe-on poly treatment just like the bowsprit has already received, but no paint.
- 831 replies
- Model Shipways
Fantastic model Dan. I joined your log very late in the game, but I've enjoyed every update and learned a great deal. Cheers!
Finally at a point where I am getting to 'visually' see how big this little (not so little) boat is going to be when it's completed. First I finished up the bowsprit by affixing a bunch of little cleats and sanding them to shape, and affixing the rings that support the jib boom. Bowsprit & Jib Boom: Next I mounted the cheeks and cross-trees on the main-mast, then put two of the chocks in, and made the third chock. After playing with the fitment of the third chock, and looking at the plans, I realized that the base of the topmast wouldn't fit through the round fitting at the top of the main-mast, so I removed the third chock and will place it after the topmast is placed permanently later on. I then made the topmast and cut the little hole in the base where a piece of wood called a 'fid' goes through it to rest on the cross-trees. I drilled a sheave slot in the top-mast, but haven't drilled the hole and placed the sheave yet. Here is how the main-mast and top-mast will fit together. Really happy with how this came out. And finally, dry fitting the complete bowsprit and mast assemblies to see the overall size (minus the main boom which will extend behind the ship by several inches too). It got big all of a sudden!
- 831 replies
- Model Shipways
Model Expo paints have a pretty terrible reputation. I got quite a bit of it when I purchased my kits, and it's a very mixed bag. The thickness of the same exact color paint is very inconsistent between bottles, and all of it is terribly thick and requires a huge amount of thinning. I've gotten pretty decent results with it, but I've thinned it probably more than 1:1 with distilled water, and then further thin it when doing the painting of various features and then use multiple coats. Both the bulwark red, and yellow ochre on my AVS are MS paint, but once I'm through with this kit I doubt I'll ever use ME paint again. I've switched to using Vallejo Model Air paint (also an acrylic) and primers and it's simply a much better quality product. As a bonus they have white, grey, and black primer depending on what color you are going to use over it.
- 105 replies
- picket boat
- model shipways
I know that acetone is great at dissolving CA, but I have no idea what it would do to Plexiglas. Probably nothing good.
- 188 replies
- Sherbourne
- Caldercraft
