GuntherMT
Everything posted by GuntherMT
  1. Very nicely done. It's a very unique presentation that I've never seen done before, and the model is great! Also, great looking pup!
  2. I glued the masts on the Carmen (first build), but on the AVS the mast is held only by the rigging, and I see no reason to glue it, since there is no way for it to come loose without the rigging all being ripped out, at which point there is a disaster afoot that glue wouldn't have helped with!
  3. I've only done the single ship with cannons (not carronades) and I couldn't figure out a reasonable way to rig them off the ship. I did use hooks on both ends of the tackle so that I could pre-rig the tackle, and then hook it into the eyebolts and tighten them. Was still quite fiddly and time consuming, but I have no idea how I would have done it prior to fixing the carriages in place, since I wouldn't have a way to get the proper positioning of the carriages with all the ropes in the way, and also no way to get the lengths right on the ropes (the breach lines mostly) without the guns on deck. I'm sure there is a way, and I'll keep prowling build logs until I see the magic system!
  4. Welcome aboard Greg, Looking forward to seeing you start your build. It really is an enjoyable model to build. As far as sequencing, it's the rigging. There are many things that should be attached to the mast/bowsprit/boom/yards prior to them being attached. In addition there are blocks that are seized to other parts of the rigging (like the forestay and jibstay). Seizing these prior to placing the stays would make it much simpler. Basically, when you get to the rigging portion, take the two chapters (standing/running) and put them together, then go through them page by page all the way through, making notes on what items get attached to what. Whenever you see something that needs a block attached, go through the sequence and see if it could be attached before other things are placed. For example - Put all the blocks that are attached to eye-bolts on the deck in place on the deck before placing the mast, or the riding bitt! Don't put the top-mast on the main-mast until you have placed *all* of the blocks and stuff that wrap around the main mast, even though the instructions have you placing the top-mast on quite early. Speaking of the top-mast, it's impossible to assemble it per the practicum. Once the cast fitting is placed onto the main-mast, the only way the top-mast can be put through the fitting is from below, since the square 'foot' of the topmast is larger than the circular opening in the fitting. You either have to wait to place the fitting until you are mounting the top-mast (probably the right way to do it), or do like I did, and insert the top-mast from below, and place the fidd later, instead of prior to assembly. I should have probably kept detailed notes on sequencing, except that I'm very unlikely to ever build this kit again, so I didn't. Sorry about that. Having said all of the above - I really have found the practicum quite helpful at keeping me on track, as I tend to wander and lose focus, so a specific order of doing things (up until the rigging) really was a great thing for me. Even when I've ignored methods in the practicum, I was still using it as a sequence guide, and there are a lot of great tips and tricks for a new person to the hobby. When you get to the rigging if you don't do like I did and try to blindly follow it page by page, but instead read through all of it and make yourself notes and a plan, it will work great I believe.
  5. You are a lot braver than me, I went with much simpler builds for my first & second builds both! Good luck, and enjoy the journey.
  6. At this time I have no plans to add sails. I was considering doing furled sails, but I think I'm probably going to leave the poles bare on this build. I think to do sails (even furled ones) right, I'd need to understand the running rigging better, which hopefully will happen in the process of finishing this, so that I can properly plan for them and adjust accordingly when I do choose to try that in a later build.
  7. I just finished making some eye-bolts. I just used small brass rod - .020" from K&S Engineering which is typically stocked at Hobby Lobby or your local hobby shop. You can also order brass rod in whatever size you want from here - http://www.specialshapes.com/roundsolbars.html
  8. I really like that anchor, it is nice to see you making a non-western style anchor to complement the ship. Well done!
  9. Thanks all, While this may be true, the fact that *I* can figure a lot of this out now that I'm running into it and re-reading the plans/instructions again, makes me believe that if I'd realized it and had done a thorough read through with notes for the purpose of determining what could be done when, I would have eliminated a lot of the issues I'm running into. Don't get me wrong, the practicum has been a huge help throughout this build, and even with the rigging he has some great tips & tricks, but the order of the assembly in the rigging phase only is.. not well thought through, or at least not written well. Based on the photos he did quite a few things on the actual model in a different order than the writing. I'll admit that as a QA analyst, I tend to be overly critical, but I think that someone writing a practicum shouldn't expect the reader to read ahead and change the order of things on their own, especially if it's only their first or second build, which is the target audience of the practicum in the first place.
  10. I think they are probably a little large, but without any context to compare them to, I doubt that anyone would notice or think they were out of place. Of course the only thing I have to compare to myself is the AVS. Here are a couple shots of the hoop size on the plans, and how they look on the ship. These are the kit hoops.
  11. Actually the deconstruction part is already done. It's the reconstruction part I need to do now. Side note: Anyone planning to go to the San Diego Festival of Sail next weekend? I'm going to go and waste lots of time sailing multiple times per day as well as in the parade of sail on Friday and would be down for meeting up with anyone else who is going to be around sometime during the weekend if it worked out.
  12. Standing rigging was completed by adding the bowsprit shrouds, and I'm working through the running rigging now. I have already learned an important lesson in rigging. No matter how good I think my research and sources are on the rigging, walk through the entire process myself, at least a few times, and make my own 'order' and checklist. I'm running into so many things that really should have been added at a much earlier time because it would have been so much easier, whether it be the blocks that are seized to the stays, to the various blocks on the masts, or the Jeers block. All of them could have been done easier (and better) at much earlier stages in the rigging. Anyway, I've completed the following (I think): Bowsprit shrouds. Jib Halyard, downhaul, and tackle. Fore Staysail Halyard, downhaul, and tackle. Gaff rigged and mounted. Gaff Peak Halyard and tackle. I've also added a bunch of blocks to the mast and top mast, as well as some ropes that attach to those blocks which can be seen taped up into coils. Some photo's. I have also realized that the jib traveler ring is too far back on the jib boom, and because I'm an idiot I already trimmed the in-hauls that hold the traveler ring, so I removed both of those, and tomorrow I'll redo that entire thing so that the dark rope that is the farthest one out on the jib boom will be much closer to the tip of it, giving me more room for some of the other lines and tackle that have to be added.
  13. Looks good. This is the first build I've seen that uses that system of building two halves and joining them together. I wonder what the benefit is to doing it that way?
  14. Great looking rigging, and that mouse is fantastic. What do you do to get that 'tarred' effect on the served line like where the collar is around the bowsprit?
  15. You'll find that in many cases (especially the lanyards for the shrouds) that the simple act of threading them through the dead-eyes or blocks will make them pretty easy to keep taught. When I'm working on the rigging and want to hold a line in place temporarily I just use a small alligator clamp and clamp the end off to some piece of rigging that's handy in the direction I want it to go (more often then not that means clamping it back to itself). Once I'm happy with the alignment of everything, I'll seize the line in place, and then remove the alligator clamp and trim the excess.
  16. These Master Korabel kits seem to build into really fantastic little boats. Thanks for posting these logs, they are great, and your boat is looking awesome.
  17. Nice progress Martin, and she is definitely building into a spectacular model.
  18. Remind me to never say 'yes' to a request to restore some old wooden boat. Haha.. what a mess. I'm sure you'll end up with a masterpiece, but man, that looks like quite the chore.
  19. Nope. It's the name of the ship on the best sci-fi program ever created, that was sadly cancelled after only one partial season - Firefly. They did make a follow-on movie that was named "Serenity" after the ship.
