Everything posted by Canute
Excellent work with all the PE, Rob. The PE you've installed so far really improves the looks of the old girl. 👍
Bob, Tru-Color used Acetone as a thinner. I tried out a rattle can of their paint on a bare styrene kit I've been working on. Not thinking, I sprayed and the old plastic looked like it was orange peel. The newer Evergreen did not. I had read that Tru-Color needed to go over primed resin, but I'd say prime any plastics also. I love the color ranges; they've added naval colors to their railroad, aircraft and armor lines
Toni, yes I was asking about the Birchwood Casey. I had used a 50/50 mix but the black could be rubbed off. Thank you.
I was asking about the echant, Mark. The vinegar is good right out of the bottle. The liver of sulfur has a very specific formula; the Birchwood-Casey does not.
LED, welcome aboard. That's quite the resource for Vallejo paints. Looking forward to see how your build turns out.
What's your dilution ratio? 1 to 1, 1 to 2 etchant to distilled water. I use distilled water because our tap water or well water has impurities that can affect the liquid we're diluting.
Eric, maybe you could get a super-fine paint brush and dab some rust on the more egregious chips. It will add a little more color to the Cairo.
- 113 replies
- Cairo
- BlueJacket Shipcrafters
Rob, that's a vast improvement to the basic plastic superstructure. The shot damage would have been a 16" shell with a hardened nose cap penetrating the armor, but as mentioned that was a short range, point blank test shot. We still use the technique for some aerial bombs, putting a nose cap on and fuzing it with a tail fuze only Of course, there are other methods of penetrating thick armor, but I can't cover them here.
GTX Boxer and 2 MAN trucks by Baker - FINISHED - Revell - 1/72
Canute replied to Baker's topic in Non-ship/categorised builds
Looking forward to some more fine builds, Patrick. -
Looks like the Paasche gives you 3 different tips. Acrylics need the bigger nozzle than enamels and lacquers. The Micro-mark probably has a medium tip, and if you spray acrylics, you'll be cussing the tool. Can you get a larger tip from Micro-Mark?
Eric, it's a sad state of affairs when you get a kit with so many issues. I admire your stick-to-it-tive-ness.
- 113 replies
- Cairo
I remember the cattle ranch around Avon Park Gunnery Range. They roamed at will and once we got a cow running threw the tactics area. The Range Control Officer yelled himself hoarse trying to keep our guys from releasing any ordnance. Unfortunately, the cow took a hit and Uncle Sam bought a cow that was KBA -killed by air..We were pretty bummed by that.
