ccoyle
Moderators
Everything posted by ccoyle
  1. Hello, Jase. The Dandy II is a kit once manufactured by the long-since defunct Dikar company. Billing Boats, Soclaine, and Artesania Latina all still make kits of the same type of vessel. The AL kit can be had new for well under US $100. Given the age of your kit and the availability of newer, inexpensive kits, you might be looking at around US $50 for yours. If you wish to have a crack at selling it, you can post it in the Traders & Dealers section after reading the seller's guidelines. Cheers,
  2. Lionfish, Sanding the hull to its final shape will require, as you have noted, progressively finer grades of sandpaper. Remember, each grade will remove some wood, so don't wait until until you have the correct shape before switching, otherwise you'll end up removing too much wood. Regards,
  3. Small world - my grandparents lived in Stockton and had a loquat tree in their yard. I would think that in Georgia one could keep an eye out for old orchards being rotated out.
  4. Also have a look at Bluejacket for more merchant/historic sailing vessels.
  5. Any of those ships you list is going to be a challenge to finish within a year. As for Caldercraft instructions, the comment about "as good as you can get" certainly does not apply to their early kit offerings. They only started producing detailed instructions on later kits, and the only large model from that period is HMS Victory; even with that one I'm not sure about the instructions. Hope you find what you're looking for!
  6. Please do not post any links to suspect companies in the forum. We don't want to give these guys any extra face time. If you have doubts about a company, send a PM to any of the moderating staff first, and we'll check it out. Unfortunately, if it's a Chinese firm, the odds are high it will be pirated goods.
  7. The similarity to Sherbourne is not purely coincidental. Both kits were designed by Chris Watton.
  8. Use the MSW search function to search for HMS Surprise -- you will find build logs for both the Mamoli and AL versions. See which one you like better. Cheers,
  9. Boats, Please re-read the pinned topic. Your title just needed a little tweaking to conform to the format for optimizing the site's search capabilities. Cheers,
  10. Title edited to meet search function criteria. Please see pinned topic in this forum.
  11. Title edited to meet search function criteria. Please see pinned topic in this forum.
  12. Unfortunately, it's not uncommon for some manufacturers to describe a kit as POF when it is actually POB, as is the case with the Mantua Astrolabe kit. Like Russ, I don't know of any POF kits for merchantmen other than Alvin Clark. Kit designers will tell you there just isn't enough demand for such a kit, although it would certainly be a welcome choice for kit builders.
  13. The term formers includes both the longitudinal profile piece, sometimes referred to as a false keel, an the transverse bulkheads. The kit you are describing is not a POF kit, but rather a plank-on-bulkhead kit. POF mimics actual ship construction; POB uses a smaller number of pieces to get the hull shape and is the method most often used in kits. If POB is indeed what you are looking for, then that opens up more possibilities for you.
  14. The Lumberyard (dlumberyard.com) used to have a POF kit of a Great Lakes schooner, the Alvin Clark, but I no longer see it listed at their site. Try contacting the owner, Dave (daves here at MSW), to see if he has any left.
  15. Topic moved and title edited to conform to forum guidelines. Good luck on your project!
  16. All that in 31 days? I am very impressed!
  17. I haven't been at the cardfaq page in years, but at that time it had a lot of dead links. I wonder if that is still the case?
  18. Questions: 1) Are you using any filler blocks at the bow? Those help a lot. 2) Have you had a chance to read any of the planking tutorials here? These address some of the issues you are having. Keep in mind that for the first layer of planking it is far more important to get a properly shaped and faired hull than to get the planking technique perfect. The second layer will be the one that everyone sees, so technique will be more of an issue at that point. Cheers!
  19. I usually clean up those ragged edge bits with the tip of a #11 knife blade.
  20. I am living without a table saw, band saw, scroll saw, disc sander, and scratch-building. It's hard, but my support group helps me cope.
  21. No work of art has 100% universal appeal. My wife can't understand what I find so funny about Monty Python -- go figure.
