Everything posted by ccoyle
Fokker D.VI by ccoyle - MPModel - 1/33 - CARD - TERMINATED
ccoyle replied to ccoyle's topic in Non-ship/categorised builds
Thought I'd start this post by showing a fix for a particularly ugly seam. I first filled in the seam with some glue. After that dried, I used my AK markers for some cosmetic work. I did not try to match the lozenge colors exactly -- there's five of them, after all. The nice thing about lozenge camo is that the whole idea behind it is to break up outlines, so I simply used the markers to break up the continuous seam line. And now for another lesson in sloppy kit design. Take note of parts 17 and 18 in the image below (lower right). They're supposed to be placed on the forward fuselage between the guns. Now notice that there are five different views of the fuselage shown in the diagrams. Five! Of those five diagrams, only one shows parts 17-18 -- but only from above, not from the side. There is no way to tell exactly how the two parts should be placed. To make matters worse, since only 59 D.VIs were built, none survived to the present day. All of the color photos you can find online depict replicas, and none of them have the parts 17-18 structure. Contemporary B&W photos aren't much help either, because whatever that little structure is, it obviously wasn't interesting enough to tempt any photographers of that era to take a close-up photo or two. To top it off, I haven't found any finished examples of this model, either. Models built from other kits, whether plastic or RC, have been no help either -- most of them don't have any structure between the guns. Whatever -- onwards! -
I also moved your topic to the correct area.
So, here's the basic fuselage parts. The bulkheads and salvaged cockpit bits have already been added to the interior skins. The fuselage is kinda flimsy at this point. The main exterior skin is now added. That's it for now. -
That is a possibility, but one that should never have made it out of the barn. There are also other niggling design issues that are definitely the fault of the designer and not production issues. For example, cut-outs for the lower wing spars are marked on the exterior cockpit skins, but not the interior skins through which the spars will need to pass. And since the spars must be able to pass through the fuselage structure, that means that at least half of the lower wing, as designed, can only be skinned after the wing substructure has been added to the model. That's kinda what it is, although I believe I read somewhere that the wing area is reduced compared to the D.VII. Also, the D.VI was supposed to be mated to a more powerful engine, which as I recall never made it into large scale production. The plane thus never achieved its maximum potential, and the war ended before much could be done about that. -
I don't know exactly what you've read, but I suspect the bashing is only necessary to make the model more historically accurate, since OcCre kits tend to incorporate a lot of simplified and/or off-the-shelf fittings. It should also make an attractive model out-of-the-box, if that's the route you choose.
Upon further examination, the fix I mentioned in my previous post will not work. The assembled cockpit structure is simply too large in every dimension, making a quick fix impossible. So, I have cut the framing apart and will work on fitting most of the parts within the allowable space on the interior skins. Of course, post-assembly surgery isn't always neat, and this time that means that the side pieces cannot be reused. As I always point out, finished cockpits are a lot of work that can't be truly appreciated once the model gets zipped up, so I'm not overly upset about the parts that must be omitted. What I am annoyed about is the possibility that most or perhaps even all of my laser-cut frames set may be unusable as well -- which kind of defeats the purpose of buying the laser-cut frames in the first place. This is not exactly a ringing endorsement of MPModels. -
Marek vs. Pawel: A Hard Lesson in Competing Card Model Design Philosophies Well, it's only Day 2 of construction on this kit and I've already found the answer to the question of how Mr. Pacynski's WW1 kits stack up against his WW2 kits. Answer: They are just as fraught with unforeseen perils for the unwary and unsuspecting as any of Mr. Pacynski's designs. 😑 How did I discover this? Let's examine the attached photo: I began to suspect I was going to run into trouble when I discovered that the laminated cockpit floor (printed part + laser-cut frame) is thicker than the width of the attached side framing, with the result being that the floor protrudes below the side framing. I then checked the instructions using Google Lens to translate them. The instructions (as minimal as they are) mention that all parts with red numbers need to be laminated onto 0.5 mm card stock. That's odd, because the laser-cut frames set I purchased along with the kit is cut from 1.0 mm card, not 0.5 mm. You can see why this is a problem in the red-circled portions of the photo. The rear bulkhead of the cockpit is aligned on the aft end of the printed cockpit interior, so the glued-up cockpit framing should just reach the forward end of the printed cockpit interior. But the forward projections of the side framing, which attach to the forward bulkhead, clearly already extend beyond the printed sidewall before the forward bulkhead has even been added. If the forward bulkhead is glued to the framing without any adjustments being made, then the forward bulkhead will not be properly positioned relative to the interior skin. This is a super annoying situation to have to rectify, and there is at least one designer out there whose kits never have this problem. Here's a shot from my construction of Pawel Mistewicz's Nieuport 11c published by Kartonowa Kolekcja: The white areas of the printed parts in Mr. Mistewicz's design clearly indicate both where structural parts are to be glued together and how thick the laminated parts should be. There is no guesswork involved. Also, the entire side panel of Pawel's design is a single rigid piece of heavy card, which produces a very strong model. The D.VI is essentially designed as a tube with a number of transverse bulkheads. This is why I have always raved about Pawel's models and have completed six of them without any ending up in the trash. It's also worth mentioning that Pawel's kits are superior to Marek's on almost every metric: ease of build, logical instructions, and number and quality of diagrams. Oh, well. Back to the fun(?). I have a fix in mind for the D.VI, so we'll see how it goes. -
That is truly a work of art!
- 399 replies
- winchelsea
- Syren Ship Model Company
Hello! While I was away on Christmas vacation for a week, my Next Project (which I ordered on my birthday back in August) still did not arrive at my house, though the Polish Post swears it is on its way. So in lieu of the Next Project I have decided to go ahead with an interim next project. I have chosen to build the Fokker D.VI from MPModel for a couple of reasons: The D.VI is mercifully short of rigging. The model is designed by Marek Pacynski. That second point needs some additional explanation. Mr. Pacynski's designs have been a mixed bag for me (see here for a prior example). I have completed two of them, but two others wound up in the trash can. The two finished models were both WW2 monoplanes; this one is a WW1 biplane. I have many of the other MPModel biplane kits designed by Mr. Pacynski in my stash, so this one is a guinea pig of sorts -- a build to see how the Pacynski WW1 kits stack up against the WW2 kits. Call me a masochist, but I'm always willing to give a designer another chance at redemption. The D.VI, of which only 59 examples were built, is a relatively small and simple aircraft, so this kit shouldn't take too long to build if everything goes together with a minimum of fuss. That's what we're here to find out if it will do. Stay tuned! P.S. Mr. Pacynski is nothing if not extremely prolific -- you'll note that this kit is #9 in the MPModels series. That line now includes a whopping 124 titles.
Charlie, I have merged your two Black Prince topics, since they are essentially duplicates, and moved them to the kit discussions area since neither of them is an actual build log. In the future, should you wish to start a build log, please refer to the "starting and naming your build log" topic pinned at the top of each build log category. Thanks!
Try clicking the 'card' tag at the top of this page. 😉
- 288 replies
- Card
- Pre-Dreadnought
(and 3 more)
A guide to using MSW
ccoyle replied to James H's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
This probably won't happen, for the simple reason that as the forum main page gets larger, it get more frustrating to sift through. This balance between too much and not enough has come up regularly in the past -- at one point, believe it or not, we used to have a significant number of additional subforums listed on the main page. Based on member input, coupled with site traffic data, a number of the lesser-utilized forums were eliminated in order to make the remaining forums easier to navigate. Ultimately, no single format will make everyone happy. -
I assume you mean the Mamoli kit?
Welcome aboard, Jeffery! Ideally, to make a 1/350 or 1/200 scale model you should work form plans in that scale. That way, you can take 1:1 measurements off the plans using a pair of dividers. Do you have plans already? What scale are they drawn in? If you know the plan scale, you can calculate a % enlargement (or reduction) to arrive at the desired scale. A print shop that handles large-size copies (such as blueprints) can probably do the scaling for you and make copies at the desired size. Cheers!
New Member Dale Mierzwik of Northern Colorado
ccoyle replied to DaleMierzwik's topic in New member Introductions
Welcome aboard! -
Intro to Card Models Intro and Table of Contents
ccoyle replied to ccoyle's topic in Card and Paper Models
Haha! That is one reason why I have avoided scratch building -- the conversions from European paper weights in gsm to US paper weights in pounds always make my head spin. But here's one web site where they've done the work for you: https://www.papersizes.org/us-international-weights.htm
