russ
Everything posted by russ
  1. This is a very fine looking model. You did a great job. Congratulations. I will look forward to your next build. Russ
  2. Pat: Thanks. There is a down side to this. I use commercially available pre milled sheets and on a larger scale model this would mean more wood to be used, but the rewards outweigh the costs. Russ
  3. The bulwark stanchions need to be trimmed down about 1/16" square or nearly square. Here is an instance where a choice that I made early on has worked in my favor. I decided to have the grain of the wood on the bulkhead frames run vertically. On the schooner model, I had it running horizontally and I had several of the bulwark stanchions snap on me. I decided in that case to make the stanchions as separate pieces that were glued to the inside of the bulwark planking. That worked but it was extremely fussy work. On this model, I really wanted to have the stanchions as part of the bulkhead frames so I chose to cut the bulkhead frames with the grain running vertically. The stanchions are much more rigid and they were fairly easy to trim using a small razor saw. This worked so well that I think I will follow this practice on subsequent models. Here is a photograph showing their appearance after trimming. Not too bad. Russ
  4. The tops of the knees need to be beveled to meet the beam. But I think you saw that. Russ
  5. Another beautiful model. Congratulations. I will look forward to work on the Halifax. Russ
  6. Kenny: Your cross section came out really well. Great display case. Congratulations on a fine model. Russ
  7. Just one photograph for now. This is a bit out of focus, but you can see the sheer line is shaping up nicely. Russ
  8. Frank: This is a good looking boat. Very good subject matter. I like the system you are using for framing. Russ
  9. I have moved ahead with the subdeck. I wanted to install this prior to finishing the sanding of the outer hull so I could have a little more rigidity while I complete the hull fairing. First I cut and fitted the paper template and then used the template to make and fit the actual subdeck. Once the subdeck is glued in place, I can proceed with hull fairing and then planking. Here are the photos. Russ
  10. That looks good. I think the blackened brass wire would do the trick. I keep some blackened annealed steel wire around for such items. Russ
  11. Congratulations on your completed Mayflower. She looks very good. Be very proud of her. Russ
  12. Bob: Beautifully done. Your rigging details are always a joy to behold. Russ
  13. Pat: The challenge here is that the inside of the pilot house will be visible, as opposed to a schooner's trunk cabin interior which is not. In this pilot house, I will need to install the interior paneling, dashboard with wheel, and the bunk. I am working it out, little by little, but it is a challenge to get it to look right. Russ
  14. Here are some pics of the early work on the pilot house. This is my first pass at the pilot house structure, but I may have another go at it. Not sure at this point. In the pics, everything is dry fitted. The framing is extra heavy because I am looking for some rigidity. It will be hidden in the finished product. Russ
  15. Very nicely done. The fly tying thread was a good choice. It gives that very light feel that is necessary at this scale. Excellent work. Russ
  16. Thanks. I have been working with the pilot house a bit the last few days. I will post some progress on that soon. Russ
  17. Wow!!! That is an incredible piece of work. Beautifully done. Congratulations. Russ
