russ
Members-
Everything posted by russ
John: Thanks. Getting the fit on the very outer planks was not the easiest. In the center and about 5-6 strakes out, it was just about simple cuts and making a nice subtle curve. Those last two strakes were tough. Although I have seen evidence of nibbing on some schooners down here, the little contemporary photographic evidence I have seen shows none. That makes it tough to get those outer planks to fit with such a long subtle curve to cut. I wear head band magnifiers so that if the joints look good under magnification, they will look good when viewed with the naked eye. Russ
Sherry, Sam, Michael and all who "liked": Thanks for the kind words. It is much appreciated. Sam, I seriously doubt I will need to do anything about those last planks. They are in there to stay. I have done this before and never had any issues with the wood moving that much. In any event, the deck will eventually get a clear sealer of some sort and that will settle the matter. Russ
Ken: A moulding will probably take care of the problem at the tuck of the stern where the bottom planks end. The joint at the bow where the planks go into the rabbet is more important since that is more visible. The color difference is something that cannot be fixed unless you create a new stem, keel, and sternpost out of holly. Russ
- 455 replies
- fair american
- model shipways
Ken: So far the line of the planks looks okay. I am concerned about a couple of things right off the cuff. First, where the planks meet the rabbet at the bow, you are sure the angle of the ends of the planks is correct? There appear to be some gaps there. It might be the camera angle though. Second, there appears to be a dip in the planks aft at about the third bulkhead from the stern. Again, maybe it is a camera angle. Russ
- 455 replies
- fair american
- model shipways
Mike: Well done. The ornamentation and the color scheme all look great. Russ
- 150 replies
- agamemnon
- caldercraft
Raymond: I asked because it seems like you are reinventing the wheel here. I designed the project specifically for first time builders. Everything was drawn out so you would not have to experiment or have any doubts about the building process. Of course, it is your model and you can do whatever pleases you. Knock yourself out. Russ
Jack: Very well done. The model is absolutely beautiful. The case is really nice as well. Congratulations. Russ
- 152 replies
- bluenose
- model shipways
Wow. She is looking really nice. The sails really add a great deal to this model. Very well done. Russ
- 110 replies
- armed virginia sloop
- model shipways
The rigging looks good so far. It is good that you are researching the flaws in the rigging plan. The results will be much better and you will be much happier. Russ
- 52 replies
- swift
- artesania latina
Harriet McGregor by Boccherini
russ replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Grant: She is a beauty indeed. Excellent work. Russ -
Andy: Your cross section is coming out really well. Great work. Russ
- 188 replies
- constitution
- mamoli
